Question about Husqvarna Chain Saw 20" Bar
Husqavarna chain saw wont start it all checks out good its a 460
Has a lot of campreshon
  • DamnYankee76 May 11, 2010
    What model is it? Will it do anything at all?
    Brigadier General:
  • 4,088 Answers
Remove the spark plug and pull the engine through a number times to expel any accumulated fuel from the crankcase and cylinder. Hold the throttle wide open and choke off while doing this. Lay the spark plug on engine metal (wire attached) and check for spark--it should be blue and snappy. If the engine has a compression release, it may be plugged with carbon--clean or replace. Check the air cleaner and muffler for any plugging. With luck, this should get you running. Hope this helps!
Posted on Apr 29, 2010
Husqavarna chain saw pull cord sticks in out position until loosen screws on housing then retracts to normal position
Check for burrs on pals attached to flywheel that would catch on pulley when trying to retract rope.
Dec 26, 2016 | Husqvarna Garden
Chainsaw runs fine but the blade slows down to stop when i cut
too much load (too large a cut), dull chain, no lubrication oil on chain, slipping clutch.. lots of reasons.. need more information and you need to check all the points I mentioned. The clutch is RPM dependant- once the RPM drops- the clutch will start to slip. Look for oil or grease on clutch shoes also
Aug 01, 2014 | Garden
What causes my 460 chain saw to tear up the teeth on the chain in the clutch
wrong pitch of chain for that saw . sometimes folks bring me a saw that they have no idea what the correct pitch chain is for saw , im lucky n that respect as I got dozzens and dozzens of old chains laying about so I grab a few a try em for size on the ole saw . so my suggestions to you if your unable to do that is to go to a ole chainsaw shop and ask to test fit a few chains for size , saves you from tearin up a clutch sprocket
Jun 29, 2014 | Husqvarna 20" 60cc Rancher Chain Saw 460
My chain wont tighten on my stihl 044 chainsaw
Assuming you have the right length chain and its not just running out of adjustment, it would then probably be a stripped or snapped chain adjuster. Can be coursed when the bar nuts aren't dun up before starting to cut, the force of the chain saw will snap an adjuster no problems. If its striped it might smear like its adjusting in but when it gets to a point it will just stop
Nov 20, 2013 | Stihl 440 044 460 046 Chainsaw Clutch Drum
SAW AND BLADE SMOKING
Not enough oil getting to the chain, check the oil flow, hold the tip of the bar close to a tree stump rev the saw, you should see a good line of oil on the stump srayed from the end of the bar, if not the machine is not oiling, drain the oil tank, fill with a suitable cleaning fluid, give it a good rinse out, and try again.
Jul 18, 2011 | Husqvarna 20" 60cc Rancher Chain Saw 460
Hi, my name is chris and i own a 460 rancher. just today the saw started to bog down when a load was added to it. seems to run at max rpm with no load however once touching the wood it will start to bog...
Hi Chris,
Check the air filter is clean and the choke plate is working ok.
Ensure the chain is sharp.
Check the chain isn't damaged and dragging in the guide bar.
A blocked muffler/silencer can cause loss of power.
Try screwing the "H" mixture adjustment screw in with the engine running at full power to reduce the richness of the mixture. Do this 1/4 turn at a time. Ensure you count the number of turns so you can get back to where you started.
Apr 28, 2011 | Husqvarna 20" 60cc Rancher Chain Saw 460
New 460 rancher 20" bar and chain cuts at an
It sounds like your chain is just dull.Or might not be sharpened right.This usually happens when the chain is getting dull.
Mar 09, 2011 | Husqvarna 20" 60cc Rancher Chain Saw 460
Husqavarna chain saw cover
make sure the air filter is properly installed if it is the top cover.
make sure the chain is properly installed if it is the side cover. also make sure the chain is not too tight, as they could put the bar at the wrong angle
Jun 29, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna Chain Saw 20" Bar Logo
268 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
