Question about GE WDSR2080D Top Load Washer
Washer want spin
Oscillator will nott turn and washer want spin
  • 33 Answers
Belt needs to be replaced
Posted on Apr 29, 2010
I have a kenmore 110.82372110 70 series heavy duty plus washing machine that drains but will not spin. Belt is intact and spinning. 'Wigwag' is oscillating
Hello.
WOW you have a old washer its been a few years since i even heard "wigwag"
now then their are a few possiblities;
1) the belt is loose/streched..is their more than a 1/2inch play in it...if yes try adjusting it by loosing top bolt on motor bracket and tighten belt by using hammer and push motor bracket to the left
2) are the plungers on the wigwag straight..if they are bent the plungers need replacing
3) is a wire on the wigwag broken..after years of "oscillating" a wire will break..the side with the red and white wire is for the spin
4) the lever that is pulled by the red wire side of the wigwag hanging up..check spring on back part of transmission to be good and pulling down the plate it attaches to when wigwag has positioned that lever in spin position
5) finally..when the above mentioned lever is in spin position( lever moves toward the rear) is the pulley above and in the center of the transmission spinning free or is it turning...if it spins free when lever is set to spin it should not spin free but move the tub to spin
Here are the part numbers;
BELT...95405
WIGWAG w/the plungers...89814
SPIN TUBE...285897
Thanks for taking me down a trip on memeory lane..its been since 1987 that Whirlpool has made a washer with a belt all are direct drive and its been a few years (several) since i have worked on on as "vintage" as the one you have...but like riding a bicycle i have never forgot :)
GENE
Aug 30, 2011 | Kenmore Washing Machines
Top load washer filling, emptying but tub not oscillating or spinning. Motor sounds like it is running fine. Colin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 27, 2010 | GE Washing Machines
GE washer will only turn in the clockwise direction instead of back and forth for the oscilation. as a result the drum just spins freely durnig the wash cycle
either a broken belt or the drive gear is stuck in spin mode If you are not a handy person who can take the back off and look/fix you will need to call in a service tech
Jul 31, 2009 | Washing Machines
I own two Marvin Floor / Box Electric Fans. It's
its extremely simple... when it does that put your hand on the oscollator cover and hold it with light pressure for a couple seconds then let go. it should work
Jul 10, 2009 | Marvin Dryers
The wife needs her washer fixed !!
First tilt this machine back and examine the belt assembly and then start the timer at spin and note the action. If you see one pulley **** and try to turn check to see if it is the motor. Then try it with the belt off. If the motor spins free let it for 2 minutes to ensure it is not failing. The worse case is the gearcase has failed and will need professional help.
Nov 02, 2008 | Admiral AAV7000A
Hotpoint washing machine vibrate/oscillates violently when on spin mode. Installation instructions tell you to adjust the feet, which I have done. I have also tried different sizes of load - no difference...
have you removed the transit bolts? this is the usual cause of violent vibration. if not, do not use the machine till this is done as you can cause a lot of damage
Sep 03, 2008 | Washing Machines
New timer on my washer still won't cycle properly.
SOUNDS LIKE THE MOTOR THAT ADVANCES THE TIMER IS NOT WORKING OR NOT GETTING VOTAGE TO IT. CHECK VOTAGE TO TIMER MOTOR
Jun 01, 2008 | Frigidaire Washing Machines
TRANSMISSION PROBLEMS...
Take the agitator off and see if the shaft still oscilates while in wash
Feb 06, 2008 | Washing Machines
Banging during high speed spin cycle
Laco, drop the bottom front panel and see if all of the shocks are in tact on the tub assy. They just insert and lock by turning. If these are ok, check the back belt pulley. Sometimes one of the tines will split or crack and you will get this symptom. Catriver..post back.
Mar 04, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
GE WDSR2080D Top Load Washer Logo
147 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
