Question about Xerox Phaser 8200DP Thermal Printer
Xerox 8200 dp - custom paper size
Hi, How can i use a custom paper size on this printer? i need to print on 13 x 26 cm sheets.
Thanks.
  • cardgarden Mar 24, 2008
    only solution that i use for now is 2 sheets of paper, the exact and a a4 on the top.... i need a more elegant way to doing this.
  • 35 Answers
SOURCE: Setting Usier defined paper size
Hey osmund, You want to use your paper size which is 8.5 x 13" but in the custom paper size you are finding 8.4 x 14". Am I right. So, where is the problem my dear. Be sure, that your document size is in 8.5 x 13". Give Print command with custom size, it will print on that size you want.
Posted on Sep 25, 2007
  • 2072 Answers
SOURCE: Problem printing in color on Xerox Phaser 8200 from Mac
That actually should make magazine quality color.
What are you experiencing? Do the colors not match? Are there smears or light streaks?
I will gladly work with you to revolve your problem, I just need a frame of reference to start.
Let me know.
You may simply need to download and install a different driver.
They are on www.xerox.com you should be running the PS version of a driver for better graphics.
Posted on Apr 02, 2008
  • 36 Answers
SOURCE: do i can customize my paper size in MS Excel 2003
When you are in Excel, go to Print Preview, then Printer Properties. There should be a box that says "Custom Size." There you can input your paper size and name it so you can recall it anytime you want.
Posted on Jan 05, 2009
SOURCE: Xerox Phaser 8200 false "Replace Paper Tray" message
I've had a similar problem with a client's 8200 printer, and looking at the right hand side of the tray someone had previously put some tape over the topmost 'slot' (above where the green slider goes across).
I put some new tape over the top slot and the 'replace paper tray' message went away.
Admittedly, the tape gets pushed in so I don't know how long it will be before the tape gets dislodged and the error re-appears.
The printer is well out of warranty and they don't want to pay anything to get it fixed... so this solution is fine with them.
Hope this helps someone else out there :-)
Posted on Jan 28, 2009
SOURCE: printer is not recognizing the new custom paper size
You also have to create a form the same size in "server properties".
Click on "printers and faxes"
Click on "file" top left of screen, choose "server properties"
Click on "create new form"
type in width and height of paper
(my HP printer will not recognize any paper less than 5' in height and less than 3" in width)
If your create a form less than 5" in height ' and/or less than 3" in width - chances are that's why your printer won't recognize new form. Height HAS to be at least 5" and width HAS to be at least 3"
type in name of new form
save form and close
It should now be in your printer paper options.
Posted on Mar 25, 2009
Hi I have a Stylus Epson DX5000
Online Best Epson printer support by toll free phone number 1-800-204-4427 to fix troubleshooting issues. We provide Epson printer technical customer service ...
Apr 13, 2017 | Epson Computers & Internet
My printer displays the message " put custom in manual tray",and I can't print.I have both paper and toner. What do I need to do to solve this?
it sounds like either in the drivers or the printer settings, you have a custom size paper specifications. I would recommend you check both settings and set it at plain paper with letter size, if that is what you are trying to print.
thanks adi
Jan 13, 2010 | Xerox Phaser 3100MFP/S Laser Printer
Using Phaser 8200 with Windows XP SP3 - when selecting CUSTOM paper size - Windows Explorer crashes
This happens most frequently with a bad driver install. You should go to Xerox.com and download the latest version of the device driver. Then reinstall the approrpaite driver and check to see how things go.
Oct 23, 2009 | Xerox Phaser 8200DP Thermal Printer
Printing a custom size card with a C7280,
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Jun 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
Paper size mismatch - c5280 hp all-in-one printer
I got around this problem by tricking the printer. The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job. What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job. Here is the tricky part... one the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11 I hope this helps.
Deny When the 8.5x11
Jun 03, 2009 | HP Photosmart C5180 All-In-One InkJet...
Can not figure out how to print on any custom size paper
If you go to your printer properties, preferences or advanced, on the Main menu, is paper sizes,
click the little tab, look at the sizes list,
scroll to the bottom, and you will see.
Custom sizes by User, create your User Defined cusom size.
check your paper tray is setup correctly.
should be good now.
Regards
Richard.
Apr 20, 2009 | HP Photosmart C7280 Laser Printer
Xerox 8200
There are special cleaning sheets that you need to get for this printer. Ask the company you get your ink from, they should be able to get you some.
Sep 23, 2008 | Xerox Phaser 8500N Printer
Phaser 8200
Have you loaded both trays? The bottom tray and the upper tray ? The one that folds into the machine. Something may be trying to run from tray 1. Upper tray
Jul 17, 2008 | Xerox Phaser 8200 Laser Printer
Problem Priniting on a Non Standard Paper Format with IP5200
the issue here is whether your canon can handle that size of paper. is it running on the manual insert tray?
when you choose paper source, you'll need to identify where the paper is coming from..
try that..
of course, up to date drivers are here
Feb 28, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Xerox Phaser 8200DP Thermal Printer Logo
504 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
