Question about Panasonic Viera TH-42PZ80U Plasma TV
Screen has a long black line down the center.
  • 4 Answers
I also have the TH42PZ80U and I just had the certified Panasonic repair person out. The problem is this is the THIRD time in two years. Any quesses on what's wrong? It's a bad panel, again. That's right, three bad panels in the two years I've own this tv. I am now one month out of the panel warranty and guess how much the bid is to replace the panel. $1542! I only paid $1300 for it. Panasonic better make this right. I think a whole new tv is in order just for my trouble. After reading about so many of us having this problem, we are probably getting close to a class action law suit.
Posted on May 19, 2010
So I am having the same problem with my Panasonic TH-42PZ80U, a black bar the width of the ribbon cable down the center of my screen. I removed the back and pinpointed the problem to ribbon CB5. Unplugged the ribbon and plugged it back in but there was no change. Any suggestions?
Posted on Jan 19, 2012
    Problem Solver:
  • 9 Answers
You may have a bad drive board. poor connection on a cable or a defective panel. This set had a 2 year warranty on the plasma panel. You should call Panasonic to let them know.
Posted on Apr 29, 2010
SOURCE: Black Line down center of screen
Had the same problem.  Was quoted $800 to fix.  Searched the internet for 6 months and found this thread on avforums.com
http://www.avforums.com/forums/showthread.php?t=462873&highlight=black+line+on+plasma&page=4
Read through all the posts.  Very simple fix, but you have to have some mechanical inclinations or you can cause more problems than you started with.  I was up to 5 of the black lines, but decided to attempt the soldering these guys did and fixed it all for the cost of a soldering iron!
Posted on Oct 12, 2007
thaurfen
  • 623 Answers
SOURCE: Black Line Down Center of Screen
Dry solder joints on the pins of the vertical integrated circuit may have caused this problem Tap each I/C lightly with a plastic screwdriver handle to find the intermittent one. It is the one with a heat sink attached.
Posted on Aug 10, 2008
SOURCE: Black line down the center of screen
I had the same problem to and I fixed it.
At the bottom of the plasma there are six or seven ribbon cabbles that come out of the panel and connect to like driver boards. Each ribbon drives that section of the panel. Mine had it down the centre so I unplugged that ribbon cable and on the underside of a metal plate attached to it there are four big resistors and four small ones. The big ones labelled 100 required resoldering. Once they were resoldered it worked just fine.
Posted on Sep 24, 2008
SOURCE: red static in black background ~ thin line running down center
Robjrpena,
Did you find a solution to your "red dot" problem? I'm having the same issue :(
Thanks John
Posted on Jun 18, 2009
vinnyq
  • 157 Answers
SOURCE: Have LG 42 inch plasma, 1 inch black line down
Sounds like the middle scalar board is defective. Since the issue comes and goes it could just be a loose connection to the between the scalar board and the PDP Module (plasma panel).
Great caution needs to be taken when checking this connection because it is a ribbon cable connection it and needs to be put in correctly aligned or it could cause a short in one of the circuit boards.
Posted on Oct 07, 2009
Display with black Spot in center and irregular lines Up & Down
Your display is damaged from pressure. Something put enough pressure on the center of your screen that it touched the LCD.
Aug 03, 2015 | Nokia 6300 Cellular Phone
TH-42PX75U horizontal lines (flickering black and white)
The controller board for the screen is going bad. check shopjimmy.com for replacement parts. It's not a difficult job to do. Once the back of the TV is removed, you'll see it near the center of the screen.
Feb 21, 2014 | Panasonic VIERA Televison & Video
Have LG 42 inch plasma, 1 inch black line down center of screen, picture good other than black line blocking center of screen, comes and goes sometimes
Oct 07, 2009 | LG 42LC2D 42 in. LCD HDTV
Black line in centr of Screen
sounds like a bad panel, try reseating any cables you can on the buffers . the buffers would be on the lower edge right where the black line appears. unfortunately Vizio does not supply panels.
E
Jul 28, 2009 | Televison & Video
Red static in black background ~ thin line running down center
Robjrpena,
Thanks John
Jun 17, 2009 | Hitachi 50HDA39 50 in. Plasma HDTV
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
Nov 09, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Aug 10, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
BLACK LINE
same problem 2 inch vertical line in center of screen! could this be something loose in the back??
Mar 13, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Usually this means pixel, but I would question if the line is mostly near right side or left side of screen? If more to one side this could be a bad board inside. for more info ctechnicians.com
Dec 31, 2007 | Hitachi CMP4201U 42 in. HD-Ready Plasma...
Panasonic Viera TH-42PZ80U Plasma TV Logo
363 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
