Question about Whirlpool LSB6000PQ Top Load Washer
Why is the drum of my washer moving/not steadt? after washer a big load the drum inside now moves freely in case
  • 33 Answers
Couple things one the self leving water ring is broke The arms on out side of tub ether came off or snapped Open the top with a putty knife two clipps one on each side open and look at arms first one might have just came off you can put that back on real easy
Posted on Apr 29, 2010
My washer was smoking when I went to remove washed clothes. Could this be a belt???
Sounds like a Coupling. Too much loading. Or blankets/ carpets were washing. A big no no --- most washers have no belts motor to transmation coupling sounds like your prob
Feb 15, 2015 | Miele Washing Machines
Maytag Neptune tl FAV8600AWW wont spin CCW ON FINGER TEST
Possible that the spindle or the bearings are jammed in this case. Check this link and reset the drum and bearings: Drum
Jan 19, 2013 | Maytag Neptune FAV6800AW Top Load Washer
Zanussi zwf 1221 will not turn drum, the end light flashes the water goes into the drum and drains out when a program is selected but the drum will not turn at all. You can turn it by hand and it moves...
you need to check the pressure switch inside the washing machine there a small hose connected with the pressure switch to sense that the level of water inside the drum is ok if this hose blocked the machine will not run
Oct 10, 2011 | Zanussi ZWF1430W Front Load Washer
While finishing a load of laundry, during the final spin/rinse cycle the washer made an aweful pounding and banging noise. It was so loud I heard it from the other side of the house and went running to see...
Yes I do know unfortunely the basket support broke. This support is mounted on to the back of the basket and goes through the rear bearing and the back half of the outer tub. This is a very extensive repair .the unit has to be totally disassembled ,if it only broke the support it is about 100.00 , but if the rear tub bearing is also damaged you may consider replacing the unit with a new one either way this is an expensive and extensive repair...
Sep 17, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My top loading washer the water come in but it want move and" there is a smoke smell
It sounds like you have a bad belt, possibly because the drum is stuck. Make sure the drum turns freely and then change the belt.
Jan 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Drum in kenmore top loaded washer is moving freely, loud in spin
YOU HAVE RUBBER WHEELS THAT RIDE ALONG THE BASKET HOW OLD IS THE DRYER MAY NEED TO REPLACE ESPECIALLY IF IT IS A OLDER MODEL
May 03, 2009 | Kenmore 24632 Top Load Washer
Maytag Washer
It is the big container where you put the clothes inside, and you have an outer tube and an inner tube often called drum.
Move the mause on top of this diagram to identify washer parts.
Mar 03, 2009 | Maytag HAV3460AWW Top Load Washer
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
If the machine pumps water inside but does not start :
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details , see: It doesn't spin
See also a general diagram here: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Jan 06, 2009 | Hotpoint WMA30 Front Load Washer
Kenmore 4025090 washer spins but will not agatate
problem solved ,agitater dogs were broken up inside the agitater hub replaced these and works fine now ,
Dec 10, 2008 | Maytag Atlantis MAV6260AWW Top Load Washer
Whirlpool LSB6000PQ Top Load Washer Logo
64 people viewed this question
Dan Webster
Dan Webster
Sal De
