Question about Cell Phones
HOW CAN I GET A REPLACEMENT HANDSET? - Cell Phones
  • jshield1 May 04, 2010
    We have a Panasonic phone with 4 hand sets, one of which is missing. On the bottom of the phone the model number is KX-TG6051B. Does that make sense to you? The phone is a talking model and we really like it. It is driving me nuts to not have the 4th hand set. How do we get a replacement? Hoping to hear from you soon. We are in Alberta, Canada, by the way, but travel often to the U.S. L Shields
  • 5,081 Answers
Where did you buy it. So that i can help you how to get replacement. What brand mobile do you use.
Posted on Apr 29, 2010
  • INDIRA KUMAR
    INDIRA KUMAR May 04, 2010
    https://panasonic.ca/english/customercar...
    Go to the above link and givw your complete address details . You will get the nearest showroom contact them and if it is under replacement period then you can get it replaced..
    Donot forget to rate and accept my answer.
Can I buy a replacement hand set for an AT&T cordless model #SL82218
Yes, a "google search" for SL82218 returns quite a few loose handsets being sold on eBay. But then you'll have to deregister
the new handset from its old base and re-register it to your base...
1. When the new handset says "Connecting..." and goes nowhere
else, enter *331734 [menu] and it will soon beep and display
"Not registered"
2. To register the new handset to your base: on the base press
the "Handset Locator" button and hold it until the "in use" light
comes on ( ~ 4 seconds ), then release the button and set the
new handset into the base phone cradle. After ~ 30 seconds
it will beep and display its "Handset #" (next in sequence).
3: Note: the base has a limit to how many handsets it can handle,
if your system was fully populated you will have to clear all the
handsets from the base and re-register them ( it is the only way
to 'rescue' the place occupied by the lost handset ). The manual
describes how to "Register a HS" in Appendix C, pages 60-61
and it is available from: www.manualslib.com
Good luck !
Apr 30, 2016 | AT&T Lands Phones
Have a replacement handset, base is cs6729-2 handset is cs6729-3 how do i set up new handset to see base?
This sounds like a registration problem, the new
handset must be de-registered from its original
base and then registered to your base.
NOTE: the CS6729 handles a maximum of 5
handsets. If you have a handset displaying
"Handset #5" then you have a 'fully populated system'
even if you actually have only one or two handsets.
You will need to clear each handset ( I ) then clear
the base of all registrations ( II ) before re-registering
each handset ( III ) up to the maximum of five.
( I ). First, to de-register a handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( II.) To clear the base of all handset registrations
( if needed, else skip ahead to ( III ). )
1. press [Find Handset] on the base and hold
past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink. 2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration ===============================
( III.) To register each handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
Good luck !!
Oct 29, 2015 | Vtech Lands Phones
How can i register my hanset. it says error.
Please use the below link to assist you with handset registration.
http://service.us.panasonic.com/OPERMANPDF/KXTG5621S.PDF#page=35
May 06, 2014 | Panasonic KX-TGA560 Cordless Expansion...
Uniden 5.8 cordless phone - replaced batteries, but now the phones don't ring....help?
up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones.
Jan 26, 2011 | Uniden Cordless Phone
Bought a replacement battery for extra handset and used the adaptor from the base unit to try to charge the battery. This did not work. Charging notice did not appear in the display window and the charge...
:.. extra handset ..." implies you have another handset. Try the battery from that handset in the "extra." If it works, the replacement battery you bought is defective.
Sep 17, 2017 | Panasonic KX-TG6072B Twin Cordless Phone
Speaker works but handset does not. replaced
Make sure to use a new handset cord as well. Also, make sure the handset is plugged into the handset jack under the phone. The 3102 phone has a headset jack that will not work with the handset. There is also a button mapped by default in the upper right corner that toggles from handset to headset. If the light is on, then it is set for headset and the handset won't work.
Dec 18, 2009 | 3Com NBX 3102 IP Phone
Mother board
hi for a total handset replacement if u are in warranty period u can claim this with the purchase bill in any of the sony ericsson authorised showrooms.. and they will replace u with new handset... thank u rate me!!!
Feb 09, 2009 | Sony Ericsson K850i Mobile Phone
Handsets wont work at all
it may be that the handset is registred to another base unit-
we had one base and one handset replaced by uniden, but the second (old) handset was still registred to the old base, therefore everytime we tried to deregister the handset it was looking for the old (replaced) base and of course could not connect and therefore wouldnt deregister. still havent figured out what to do yet
Dec 20, 2008 | Lands Phones
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
