Question about Samsung DVD-VR357
Disc is in wont play wont open - Samsung DVD-VR357
Cd's appear to burn but do not play
change your burn software and file formats /if there are music files/
Apr 24, 2012 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
Discs will not play. After loading for about 1 minute no disc note comes up. Discs have been cleaned and neither dvds or neo discs play.
The reason the player wont play the disc is either because the lens is weak or dirty.
Try to clean the lens with a lens cleaner and test with a DVD disc.
If it does not work, then it means the lens is weak and needs replacement.
To replace the lens, open the player with the appropriate screwdriver, open the disc tray, and replace the lens with a new lens, test it with a DVD disc.
Take care.
Jun 15, 2010 | Televison & Video
Dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would...
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
Oct 12, 2009 | Cyberhome CH-DVD 300 DVD Player
Dvd wont eject when you try to open it. or dvd wont play
i think the cd or dcd disc inside stuck-up you have to insert the tiny hole located at the dvd rom and insert a needle or something that is similiar or smaller of the hole size of that locted in your dvd rom.usually its new the LED blinking when opening or inserting the disc. and now you can now eject your disc manually regarding your question about it won't play a dvd try first to clean your DVD disc with a micro fiber cloth, avoid you'll scratch it, if still the same i think you're dvd room is defective.
Oct 08, 2009 | Bose (321GS) System
Toshiba sd 4800 dvd plater not opening and playing
There is a small belt that has become worn or has broken. Open the DVD palyer, press the open key push on the silver disc, the tray will open, . On the tray pul the two tabs up gently, remove tray. Belt is located there
Oct 04, 2009 | Toshiba SD-4800 DVD Player
Disc wont eject
wat player are u using and wat is the model... wat was d cd u wer playing....
Jun 04, 2008 | Philips MX5060D System
Wont play
same here when ever i put in a brand new game just opened into my brand new xbox it reads for 5 seconds and then says sorry please clean disc and it was clean brand new.
Jun 02, 2008 | Microsoft Xbox 360 Console
Samsung DVD-VR357 Logo
132 people viewed this question
Jerry Greenberg
Jerry Greenberg
