Question about HP Pavilion dv5000t Notebook
Hp pavilion dv5000 hard drive problems
Computer says hard drive failure about to happen. It is still working so far with only one glitch on startup.
    President:
  • 2,049 Answers
It is rare that you get notice of impending harddrive failure so heed the warning now. If it were me, I would back up all files to an external drive, and better yet, use a program such as Norton Ghost or Acronis and make a drive image. That way you can blow the image back on a new drve and be up and running right away. The alternative is to back up docs, pics, etc and reload every program including operating system, which is very time consuming.
Posted on Apr 29, 2010
    President:
  • 1,768 Answers
1. I suggest you purchase a portable 2.5 usb case. there should be instruction the the portable case.
2. Remove the hard drive from the laptop and put it into the portable case and back up the contents to another PC with enough hard drive space to accommodate.
3. Go to Repair4laptops ( do a Google search) it should show how to remove the hard drive step by step from your laptop.
4. To replace with a new hard drive reverse the steps.
Hard drive from dv5020us to dv5000
Made sure that both HHDD connections are the same Sata or IDE and the processor has to be the same Intel or AMD you should be able but will need to update some drivers.... tekgods
Oct 24, 2013 | HP Pavilion dv5020us Notebook
I need to replace the hard drive of a dv5-2129wm
Step 1:
How-to Replace the Hard Drive for an SSD on a HP Pavilion dv6 http://www.youtube.com/watch?v=QQx7PlIXFuE How to Change A Hard Drive In A HP Laptop http://www.youtube.com/watch?v=650mXGa-kDY
Feb 04, 2013 | HEWLETT-PACKARD Garden Dreams Pavilion...
Why is it when i go to start my computer it doesnt wanna load windows, it says disk boot failure, insert system disk and press enter. My computer was working fine right before. can someone please tell me...
Hi, the computer is not detecting the hard drive or the hard drive is corrupt. At startup you are likely to hear a knocking sound if the hard drive is physically damaged. You can go to bios setup at startup ( could be F1 or Esc). Once there it should indicate if there is a harddrive or not. If it indicates none there the harddrive might have crashed and will need repalcing. I hope this helps.
Aug 12, 2010 | HP Pavilion a706n PC Desktop
All usb ports on my HP Pavilion dv5000 do not recognise any device attached to them. Hoevevr when thr same devices in pugged into another computer they work perfectly.
Unistalled the USB Generic Root Hub Drivers from the Device Manager by right clicking on the generic root hubs and then restart the notebook and This will fix this issue for you....:)
May 02, 2010 | HP Pavilion dv5000z Notebook
My pavilion dv5000 says on startup media test failure check cable
Computers can start-up ("boot") from many different devices:
* 3.5" diskette,
* CD-ROM,
* USB memory-stick,
* disk-drive,
* network,
* external USB CD-ROM
and so on.
Your computer is trying to use the network adapter to download a bootable image through a connection with a network-cable to a "network-boot-server" computer.
In your case, "check cable" means that your computer's network-port is either *NOT* connected to a network, or that no "network-boot-server" responded to the request to download to your computer.
First, check the "boot-order", i.e., the priority of each of the bootable devices, to ensure that "boot from network" has a LOWER priority than booting from your diskette, your CD-ROM, and your disk-drive.
Second, check that your disk-drive *IS* one of the bootable devices.
Is there any bootable media in the diskette?
Is there any bootable disk in the CD-ROM?
If not, then your computer has *TRIED* and *FAILED* to boot from your disk-drive, and then tried and failed to boot from the network.
So, it's possible that your disk-drive has failed.
Take the computer to a qualified technician, and get them to remove the disk-drive from your computer, and to connect it to another computer, to see if the disk-drive still is in working-order.
Nov 05, 2009 | HP Pavilion dv5000t Notebook
Battery with HP Pavillion DV5000 won't work. Do I need to replace the battery or is there a battery charger I could use to recharge the battery? Dianne
You can order a power cable online or pick one up at your local computer store. They should run between $80-150. The battery itself is very expensive to purchase but is rechargeable.
Oct 22, 2009 | HP Pavilion DV4015cl Notebook
HP Pavilion dv1000 blank screen
It may not even be caused by the graphics display driver at all. Your Hard Drive may hae BAD SECTORS and the computer is battling to read the system area of the hard drive... Make alse sure that the hard drive commections are fine
Jul 08, 2009 | HP Pavilion dv1000 Notebook
I need from HP pavilion dv5000 sound card driver.
i don't know which dv5000 model it's so, here they are
HP Pavilion dv5000 CTO Notebook PC
HP Pavilion dv5000ea Notebook PC
HP Pavilion dv5000t CTO Notebook PC
Step 1: Software & Driver downloads
Step 2: Select Operating System
Step 3: Driver - Audio (Select your sound car brand)
Don't forget to rate my comment.. Thanks!... (=
Jul 05, 2009 | HP Computers & Internet
Hard Drive
just get an external hard disk man.......they go upto 1 TB
Oct 09, 2008 | HP Pavilion dv5020us Notebook
HP Pavilion dv5000t Notebook Logo
411 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
