Question about IBM P 202 21" CRT Monitor
One of my HP L2045w screens started flickering and vibrating
Today, one of my HP L2045w screens (The one about 4 years old) just started flickering wildly and basically "vibrating up and down" and then turned off. I could not access the reset function since the monitor would not stay on.
I have eliminated the cords at the issue, both the monitor cords and the power cords since when I swap them out, the problems stays with that monitor and does not transfer to the other monitor.
I have UltraMon on the system to allow the use of two monitors and until today both HP monitors (both the same)were working perfectly. Nothing had been downloaded. I can still send an Excel or Word file across from the other monitor, and you can see it on the malfunctioning screen, but it just jumps up and down and turns off.
I had another monitor, and I swaped it out for the malfunctioning one, and it works well, but I much prefer the HP monitor. Any thoughts about how to "reset it" without having access to the on screen tools? If not, is it worth fixing?
  • 86 Answers
SOURCE: check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Posted on Mar 31, 2007
SOURCE: Dell monitor
Try holding down the Ctrl+Alt and then press the left arrow key. Each arrow key pressed will turn the screen that way.
Posted on Oct 24, 2007
SOURCE: I was adjusting picture on monitor and now picture completely messed up
  • Signal out of Range.
  • Out Of Scan Range
  • Horizontal frequency is out of range.
  • Cannot Display This Video Mode Out of Sync
This issue may occur if the signal from the video adapter exceeds the scan range of the monitor. The video adapter setting for updating the screen (the refresh rate) is incompatible with the monitor.
you should reinstall your video drivers in safe mode.
To restart in safe mode repeatedly press the F8 key during the computer startup. This will bring a menu where you'll be able to choose safe mode.
LCD monitor 60 - 75 Hz
Posted on Jan 25, 2008
russolini
  • 47 Answers
SOURCE: Many screens on one monitor!
Your monitor is malfunctioning and requires servicing. Unfortunately there is no software solution, and no monitor adjustment buttons will control this problem. Due to the high cost of replacement parts and service technicians, it may be more cost effective to buy a new LCD monitor. Sorry to be the bearer of bad news :(
Posted on Jun 10, 2008
SOURCE: IBM ThinkVision 17" Monitor displays for 1 second then black
This seems to be a common problem with these monitors. Have a look very closely and see if you can still see something there. From there, either send it to get repaired, or, if you are handy with a soldering iron, open it up and replace the 4 main capacitors (at least one of them will be "popped", but it is handy to replace them all.
In order to open the monitor, you will need to remove the stand, and make sure you get all of the screws out before attacking it with a screwdriver.
I have 5 IBM monitors at work with the same problem, and opening them up has shown the popped capacitors.
Again, only recommended if you know what you are doing. Screwing it up will leave you with nothing.
Posted on Feb 03, 2009
What is Causing my My Samsung la40d503 to flicker green
5 month old TV should be under manufacturers warranty - do not attempt repairs yourself it will void warranty
Dec 05, 2013 | Samsung LA-40D503 40" Multi System World...
I have a 48" vizio that is 5 or 6 years old and
What has gone wrong can be checked only once you open the rear cover. Did any liquid peep in at that point? Anyhow, only a qualified service technician can assess the damage. Please do not switch on the TV, switch off the power and remove the plug until then.
Jul 25, 2012 | Televison & Video
HP Pavilion g series g7 black screen but occasion flicker shows it is up and running.
Hook a spare monitor to the video output usually on the back, if picture is okay! the problem lies in the inverter board, "just below the screen" or the backlight behind the LCD display, or the video cable from the screen to the motherboard has come loose from the plugin. But if both show the same symptom it means the Video Graphics Card is defective, normally built into the motherboard.
Apr 01, 2012 | HP Computers & Internet
Hp 2509m screen flicker
Hi Kevin,
My daughter has the same problem with her laptop, do you find that when you move the screen slowly back and forth it either stops or gets worse ?
You will need to take your laptop in to an HP dealer and let them have a look at it.
Regards :)
Feb 06, 2012 | Computers & Internet
MY 2 WEEK OLD HP pavilion DV6 SCREEN IS FLICKERING It's start to flickers , did my virus scan everything was working so i restart and while it began to shut down to restart it started to...
wow, no OS stated, FROM VISTA to W10, impossible post this..
why say its new, its only new to you?, its really old, or is it and ENVY?
DV6 tells the helpers zero. or is it DV6-1000 very old ?
what DV6 ?, if you read the service tag, it has long model numer
like DV6-1234us?
that tells what it is.
Virus (1) tells you nothing, we run over 20 scanners to and malwarebytes to clean it, and more, if reloading OS is too painful
the you suffer virus cleaning pain, can take all day that.
see this list of DV6, see, it means near NOTHING.
its a notebook
and can be as old as...2009 so all are supported still, in the 10 year window of support.
the newest one is windows 8.1
example of one.
HP ENVY dv6-7300 Select Edition Notebook PC series
now Ill answer based on ZERO inputs, generic
all PC;s or notebooks
if the screen LCD has lines the LCD is bad.
if you gently twist the screen and it gets worse BINGO LCD
if not, then the LP has bad GPU. is this a 2008 Laptop
many that year had solder Ball failure on all GPUs.
if you go to bios , and press f1 (mine does to INFO PAGE)
tells you all years, there, see those years, tells you when its made.
see this one, (no ball problem here EVERY)
its 2009/10 bios and video card stamped dates.
http://pcdied.com/top-coveroff.JPG
see the read of your PC< see that VGA jack
does and external VGA desk top display fail there.
yes, GPU is bad (or the driver mangled) put back the HP driver now.
its free, on same page. as yours, at HP.com
here is a wild guess page, no pc stated so here,
see this. , go there and find yours, ITS THERE.
https://support.hp.com/us-en/drivers/selfservice/hp-envy-dv6-7300-select-edition-notebook-pc-series/5363721
May 25, 2017 | HP Computers & Internet
Monitor goes fuzzy and then blank
Contact HP at 1-800-HP-INVENT
-=/ Daft Tech /=-
Oct 22, 2009 | HP Computers & Internet
My HP w1907 monitor less than a year old is turning pink!
A flickering screen with pink colour is a sign of a CCFL lamp problem.
The CCFL lamp is a mini fluro tube and it provides the back-lighting, it is definitely faulty and about to fail completely.
You need to get it repaired while it is still under warranty.
Oct 05, 2009 | HP w1907 LCD Monitor
Hp Laptop screen flicker
Hi, i noticed that when I unplugged my HP the screen stopped flickering. I then re-plugged in the power, when to the Nvidia control settings, to PowerMizer, and changed 'ac outlet' to Maximum Power Saving.
Not the world's greatest solution, but hey, working laptop now.
Cheers,
Andy.
Nov 21, 2007 | HP Pavilion zd8000 Notebook
Flickering crispy screen
maybe ur screen was put into a lot of magnetic interference. so check for any magnetic rays emitting devices like speaker adapters etc. a simple check would be to degauss( its in the screen properties). raja
Feb 28, 2007 | LaCie Electron IV 19" CRT Monitor
IBM P 202 21" CRT Monitor Logo
456 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
