Question about Gateway GT5220 PC Desktop
The print in our emails is not very big and not very dark; how do you correct this?
    President:
  • 1,768 Answers
1. You can copy the contents of the emails to Word and enlarge the font and the click "bold" set the font to 11,12 or 14. this should be large enough to visualize properly.
Posted on Apr 29, 2010
I am printing a picture of a item someone email to me when I review this item on my computer it has a white back ground and the item is green and yellow. But when I print the picture the green part is now...
it depends, either the printer is faulty or has a modified color shceme loaded or the monitor is not displaying true colors but inhanced colors. try to first use one of the online screen calibration test to verify the colors on your monitor are correct if so then check the color scheme on the printer.
Mar 08, 2011 | HP Photosmart C8180 InkJet Printer
Konika Minolta Copier prints half dark pages
If it is only causing an image problem when you copy and not when you print, then there is something wrong with the optics under the glass. Check and see if you have any mirrors out of place or if the scanner looks crooked. If you have the machine set up to scan try and scan to SMB or email to see if it still has the problem. If everything looks correct under the glass and scans to SMB and email look bad like the copies, you may have a bad CCD assembly, or a bad board.
May 10, 2010 | Konica Minolta Office Equipment & Supplies
Zebra Z4MPlus not printing dark enough
In your label software there should be a setting option for print darkness (I assume it adjusts the head temperature) In ours (bartender) you can get to it when you select 'print' and a window appears with a 'documents properties' button. Click on this and select options and a darkness bar appears which you can adjust. You may also need to slow the label print speed if the darkness adjustment is not enough. I suspect it isn't in the printers best interest to run the print head at maximum darkness/heat so a sensible balance of darkness and print speed is best.
Another, less likely, possibility is an incompatability between the label material or surface finish, and the ribbon type. We did have a problem once whem Homebase changed their price label design and we had to test a load of other ribbon types until we got one that did the job. A chat with the label or ribbon supplier is always usefull, they sent us several sample bits to test.
Sep 30, 2009 | Zebra Z4Mplus Label Printer
No print /No error message
First, you need to make sure the ribbon and labels are loaded correctly. Follow the diagrams on the inside of the door. Once this is done, check the print speed and darkness from the front panel. If you have a high print speed and a low darkness, depending on the media you are using, it may not show the print. Try either slowing the print speed down or raising the darkness.
Aug 28, 2009 | Zebra Stripe S600 Thermal Label Printer
Hi there! I have a lexmark x5150. The problem is that I couldn't print black. So what I did was I opened up a word document, and changed the text from black, to dark gray... it worked!!!!!!!!!!!!! But...
Don't put your e-mail up for hackers to send you a virus!
Try to print from another program. It can't be as obvious as low(or completely dry) black cartridge could it? worth a shot? You can make a dark grey from the color cartridge just not dark black.
Aug 20, 2009 | Office Equipment & Supplies
Can't save the printer darkness in the printer
go to printer driver properties.. 1.click printing preferences set it to USE PRINTER CONFIGURATION 2.go to advance click Printing Defaults set it to USE PRINTER CONFIGURATION
you must set this two configuration note: fresh installed driver defaulth to software control
Oct 14, 2008 | Zebra Z4Mplus Label Printer
Printing too dark.
Check the MAC driver setting and look for the in intensity control.
Mar 29, 2008 | HP PSC 950 All-In-One InkJet Printer
Hp laserjet 1100
When the paper gets low in the storage tray the printer starts pulling several sheets at one time.
Mar 28, 2008 | HP LaserJet 1100 Printer
Can't I print with only one black ink
I have a similar machine ip5000. Currently have a problem getting the big one to print and have posted for a solution elsewhere. If I print withjust the small tank it does some black work i.e. type but it needs the other big tank to give full photo pictures.
If you are just looking to print typing try changing your font collour to a dark blue or other. This gets round the black problem but you will need the 2nd black cartridge for full colour work.
Hope this helps.
Mike
Mar 07, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Gateway GT5220 PC Desktop Logo
124 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
