Question about Kenmore Elite Oasis 27052 Top Load Washer
Codef1 start washer the lid locks stop flashes f1,start again no code?
  • 299 Answers
This is a known problem with this model. Call 800-847-9083 and give them the model and serial number to see if your unit is covered by a recall on the control board. I called a few weeks ago and they sent the part and a tech to install it for free on my 3 year old machine.
Posted on Apr 29, 2010
Lid locked light on, will not release
The lid lock light won't stop blinking. - Fixya
www.fixya.com/.../t14714916-lid_lock_light_won_39_t_stop_blinking
Oct 21, 2012 - The lid locked keeps blinking and I can not start a cycle. - WhirlpoolLSB6200KQ Top Load Washer question. ... Whirpool cabrio wtw5500xw top loadwasher will not start lid light flashes then goes out and into flashing pause ...
Whirlpool washing machine_ lock light flashing_ nothing ...
? 1:53
www.youtube.com/watch?v=zrV9w6Z5LAU
Mar 3, 2012 - Uploaded by briantaylor62 Whirlpool washer wont start a cycle, lid does lock and the locklight ... a cabrio as well that just has the lid lock flashing and nothing happens , I ...
Flashing Lid Lock Light: How to Troubleshoot Errors on Your ...
? 1:23
www.youtube.com/watch?v=nttHsAX2_OM
Mar 27, 2015 - Uploaded by searspartsdirect
The lid lock light on VMW washers, made by Whirlpool, Kenmore and Maytag, will flash whenever there is a ...
Oct 12, 2015 | Washing Machines
Amana washer lid lock wont quit blinking
Your washer lid lock button is locked and lid was not put down before it locked, which is why the light is flashing. Therefore, push the "START" button until you see the lid lock button is off (Approx 3 seconds). Once it is off, then you can put the lid down and push the start button again, which will lock the lid into place. The washer will NOT drain or wash or spin unless the lid itself is in the locked position. If you were able to get the lid down and locked and it still doesn't work, then you need a technician to replace a wiring harness. However, you mentioned that the lid lock button was flashing, therefore, it stands to reason that your lid is NOT locked down.
Apr 13, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
Maytag centennial washer
When lid lock flashes, that is an indication of a bad lid lock in some of the mvw washers.(depending on your unit and model number &error codes)
Nov 03, 2013 | Washing Machines
Lid lock flashing
There are two issue needs considering. Should you have very less load and get wrong setting so the sensor can not weight. Do you have any error code like F1, F51, etc...
Try to turn the drum by hand see if it is freely turn to make sure nothing was caught in between.
This motor has a nut that was loosen by time or by working with large load for long. Lift over the washer to the wall, then you can kneel down and look at the bottom. There is a 1/4 hex head nut-see if it is loosen and reset the unit again.
F1 code - the control board dead, need to call Wp for replacement, as far as I know, they cover 1 time part and labor for this code.
F51 code-motor issue or weight sensor, need to figure out which one cause problem.
Oct 21, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Lid lock button is flashing and wont unlock
I u unplugged the machine and it stopped blinking, the lid unlocked but when I tried starting it again the same thing happened. I cleaned the contacts on the lock but that did not help.
Jan 08, 2013 | Maytag Bravos MTW6600T Top Load Washer
F1 code coming up on my Oasis HE washer
YES! Serious problem...more annoying than anything else. Wait until your machine stops at the spin cycle and displays "F1" again. We just had a repair tech out today and received a quote of $384+ to fix/replace the circuit board. Kenmore & Sears are fully aware of this problem and have issued a recall on a model that is one digit off of the model I have yet they will not do anything about this even though it is the same problem. These machines are huge dogs!
Jan 15, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis HE getting F1 code. What does this indicate?
your board is confused and cannot read water level, very easy fix, pull off console(three screws on rear) and remove clear hose on right side of main control. blow into with your mouth and clear tube. reconnect hose and try, if F1 continues main control will need to be replaced, Sears is offering this for free if your unit falls within a certain serial number range, Also a biggie.....You must use he soap only with the oasis....no exceptions.....
Apr 25, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis HE/ Error Code F1
f-1 error code,, replace main contol board ,,pressure swtich is loacted inside board would not fill drain and spin once replaced there will be no more problems, if machine is 2 yrs should be covered under warranty
Nov 24, 2008 | Kenmore Elite HE4 Electric Dryer
Sorry to tell you but you have a faulty control board. It is a bad part from the factory. They know that its bad too! They have completely remanufactured the part. There is lawsuit against whirlpool (whirlpool made the oasis) for the problem. Some people have been able to call and complain to whirlpool and got them to pay for the repair. Complain a lot. Good luck. sorry for the bad news.
Nov 20, 2008 | Washing Machines
repl/ main control board reason for error code F 1 ,,,nothing else
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Oasis 27052 Top Load Washer Logo
136 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
