Question about Maytag Neptune MAH5500B Front Load Washer
Have to unplug the machine to get it to shut off and unlock the door at the end of a cycle
    Scholar:
  • 126 Answers
WHAT WOULD YOU LIKE TO KNOW? IF YOU NEED HELP UNLOCKING THE DOOR. THIS IS WHAT YOU DO. IN TH FRONT RIGHT OR LEFT CORNER OF THE DETERGENT AREA THERE IS RED, GREEN, ORANGE LIKE FISHINGHave to unplug the machine to get it to shut off - 2_bing.gif LINE FOR YOU TO MANUALLY RELEASE DOOR. THIS IS EASIER WITH PLYERS. PULL THE LINE DIAGONALLY TO THE LEFT BACK WHILE IN FRONT OF THE MACHINE AT THE SAME TIME PULL OPEN DOOR. IF YOU WANT TO DO MORE THAN GET YOUR CLOTHING2_bing.gif OUT . I WILL HELP YOU FUTHER IF YOU WANT.
Posted on Apr 29, 2010
How do I unlock a whirlpool duet washer
from a previous discussion:
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
Jan 04, 2015 | Whirlpool Washing Machines
Tip
LG Washing Machine has DE Error code
<span><b>A DE Error Code is indicative of a "Door Error". This indicates that the washing machine </b></span><span><b>door is not shutting, locking or opening</b></span><br /><br /><span style="font-weight: bold;">Is this happening mid-cycle or at the end of the cycle?</span><br /><br />If this is happening mid-cycle or at the end of the cycle, try powering off the unit and unplugging it. Leave it unplugged for about five (5) minutes. Plug the machine back in, power it on and see if the door latch releases. If it does not, service will be required.<br /><br /><span style="font-weight: bold;">Is any item caught in the door?</span><br /><br />If an item is caught in the door, this could cause e DE error code to appear. Unplug for about five (5) minutes. Plug the machine back in, power it on. If the door will not unlock still, it could be that the item caught in the door could be pushing up or down on the door, preventing the latch from unlocking. May need service. <br /><br /><span style="font-weight: bold;">Has unit been paused in cycle to allow item to be added?</span><br /><br />During the Cycle, the unit will draw in hot water to help activate detergent, even on a cold cycle (no damage to clothing will result, as it is a small amount). When the unit is paused, if it detects that the water in the unit is to warm, it will not unlock the door immediately (takes a minutes) This is a safety feature.<br /><br /><span style="font-weight: bold;">Is the door or gasket warped or damaged?</span><br /><br />If the door is warped, it will prevent the unit form latching or locking properly. This can result in DE error code. Also, if the gasket is damaged it could cause this problem as well. Make certain the latch on the door is not broken. Refer to warranty policy to determine coverage under the LG warranty.<br />
on Jun 02, 2011 | Washing Machines
How do I reset and unlock the door on my Kenmore Elite quiet pak 4 washer?
Press and hold "end of cycle" at the right end of your panel for 3 - 5 seconds. The machine power should be on.
Try the door 2 minutes after this.
Mar 29, 2013 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet washer door will not unlock or complete the cycle
  • Oct 13, 2011 | Whirlpool Washing Machines
    The control locked is on on my machine
    The control can be unlocked by pressing and holding the End of Cycle button for 3 seconds or until the Control Locked indicator turns off. Unplug the machine for at least 30 minutes to forcibly reset the control and make sure and eliminate the possibility of an electronic glitch if the End of Cycle button does not unlock it. Replace the control if unplugging and the End of Cycle button fail to unlock it. Indicate the exact model number of the machine for the right replacement part number and for specific replacement procedure should you require it.
    Aug 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Washing machine will not turn on it shut off
    Have you tried unplugging the unit and waiting for a minute and then plug it back in. The load might have been off balance and caused that condition. Once it has been reset you might be able top end the cycle.
    Dec 07, 2017 | Kenmore HE2 Plus Front Load Washer
    Maytag neptune MLG2000AWW does not turn off at end of spin cycle
    d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
    Mar 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Control locked
    is any thing on or working check to make sure door is latched
    Dec 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
    Washer will not restart.
    unplug it wait a few mins---- that should solve it sometimes these machines go in to a a "soft lock" condition
    Sep 30, 2007 | Whirlpool GHW9100L Front Load Washer
    Maytag Neptune MAH5500B Front Load Washer Logo
    62 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
