Question about Nespresso Essenza C100 Espresso Machine/Coffee Maker
Nespresso Essenza - water is not coming out of the spout
I put in the capsule, push the button and no water comes out.
  • Jemma Jan 31, 2012
    Just got my machine and found your site. When you say hit start button it that one of the cup signs either side? Or the off and on switch?
    Thanks for help anyway
  • 21 Answers
Try...Hit the start button then Lift the lever and push back as far as possible and hold for 3 seconds. hit stop button, then close lever. this should restart machine.
Posted on May 08, 2010
  • 4 more comments
  • dman152 Nov 11, 2010
    right on! I got lucky and bought a used Essenza at a thrift store for 10 bucks. It had the same problems as described above. I used your advice with the pulling back of the handle, and sure enough-there is water yet again! Thanks for the advice!!
  • fida hasan Dec 06, 2011
    nice,,i pulled mine out after 5 years...after fiddling for an hour,,used your advice and presto!!
  • nergish manecksha Apr 22, 2013
    I have tried pulling the handle back holding for 3 sec etc. but problem is still the same, coffee doesn't pour out of nozzle
  • Ricky Gerbilsky
    Ricky Gerbilsky Jul 14, 2014
    It worked! The first one I bought I returned cause I didn't think it would be solved so easily. When I brought the second one, it had the same problem, so I said, it's not possible, there has to be a way to fix this easily. So I saw this fixya link and voila! It worked! Thanks!
  • Sergii Udianskyi
    Sergii Udianskyi Jun 05, 2015
    it worked! Thank you! God bless!
  • ogyen
    ogyen Nov 22, 2016
    Thanks a lot, it works!! :D
    New Friend:
Happened the same with mine and it was a blockage in the tip. Easy to take apart, give a good rinse and it should work
Posted on May 05, 2014
Nespresso Essenza 90 leaking at the bottom seam underneath the used capsule holder, HELP
Try gluing the seam with lock tight glue or similar plastic gluing compound. Let it dry overnight and try again.
Oct 16, 2014 | Nespresso Essenza C90 Espresso Machine
Nespresso U coffee does not come through the spout
There are two nozzles in front of the machine attached together, the nose of the bigger one on the top slides into the smaller one on the bottom. When it makes coffee, the spout outside the machine becomes lower so coffee can come out. When it is done making coffee, the spout goes up so water/coffee drips in the drip tray. If one of the nozzles breaks, the spout on the smaller one will not go down and the inside end is lower and coffee goes inside the drip tray. It has nothing to do with cleaning.
Jan 20, 2014 | Nespresso Coffee Makers & Espresso...
Nespresso essenza lever stuck
My Nespresso lever won't push back and it won't produce any coffee from capsule that is stuck in machine.
Jun 13, 2012 | Nespresso Essenza C100 Espresso...
When i turn machine on and put the capsule in i press the start button and the water leak out the bottom instead of the spout
Turn the machine off with the Power button, and pump the pod receptacle latch on top 3-5 times. Turn machine back on. Ta-Da!
Jun 01, 2011 | Nespresso Essenza C100 Espresso...
Our machine does not puncture the Nespresso capsule - so we only get murky water.
I just had the same problem with my new (less than one month use) Nespresso U. (the top of the capsule doesnt puncture and only water comes through). I called Nespresso customer service and a very helpful man suggested I run water through three times by pushing the top slider open with the Longa button pushed and then closed without a capsule in the chamber. That released the air bubble and now I am enjoying a wonderful cappuccino again! The customer service is fabulous, there was never a suggestion of charging me and I was told that Nespresso will send me a free loaner machine if anything goes wrong in the future that can be readily fixed over the phone. The Nespresso U is the best thing I ever bought.
Aug 25, 2010 | Nespresso C100B Essenza Single-Serve...
Water not coming through nozzle of nespresso essenza
I have had this issue. I have removed round silver plastic piece from around coffee spout,(gently -do not crack it) I then removed and washed the black spout, I even used a toothpick once, to remove the stubborn coffee ground, Once it was cleaned - it worked perfect. If you run water from the faucet into spout it should flow smoothly. I warn you though, not sure what this does to any warranty, but don't mess with my morning coffee! I hope this helps.
Jan 09, 2010 | Nespresso Essenza C100 Espresso...
Nespresso essenza problem
It's not supposed to make holes in the capsule until the water comes through. So, basically, when you put the capsule in, it pierces the capsule in three spots, on the top. The aluminum part will not pierce until you press the button and water comes through. If water is not coming through, then you can clear the air bubble by opening the lever on top of the machine, pressing the coffee button, and then closing the lever once the water begins to come through.
Jul 30, 2009 | Nespresso Essenza C100 Espresso...
Nespresso Essenza C100 Espresso Machine/Coffee Maker Logo
13,126 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
