Question about LG LN790 GPS Receiver
I can't get my gps to move from my last location. I tried the reset button and nothing.
    President:
  • 1,851 Answers
There is a safety security feature to cause the GPS to stop working until you drive to the place the code was entered and reenter the password. Then it will work - OR call the manufacturer.
Posted on Apr 29, 2010
My tom tom is unable to locate a satellite for the last two weeks. I have tried rebooting but that has not worked. If I input a new route it just says searching for a satellite and nothing happens.
connect to tomtom home. check if any updates available. install if any available. start the unit, when turned on completely press and hold the reset button for atleast 8 secs and then go outside under the open skies and see what happens.
let me know, good luck.
Jul 29, 2010 | Tomtom GO 910 GPS Receiver
Gps won,t move from last location
When you put in a new location how are you entering it? If you are using the "Where to?" menu then you will need to click on the "Map" button instead of GO when you find the point you are looking for, may it be an address or a Point of Interest. This will show the location on the map. If you want that to be your current location you must have the GPS turned off. Then on some units you will Have the option to set as your current location.
I hope this was some help.
Cheers
Jul 14, 2010 | Garmin StreetPilot C330 GPS Receiver
My Navigon 7100 doesn't turn on! It does get charged though...
I had a similar problem with my 2100Max. I took the SD card out, plug it into my computer and then reinstall it. It works like a charm these last months still.
Jun 08, 2009 | Navigon 7100 GPS Navigator GPS Receiver
Lost gps and then found 6 months later and cant remember password
To reset your ONE XL, use a straightened paper clip, or something similar, to push the reset button. The reset button is next to the memory card slot, on the bottom of your ONE XL. Then turn your ONE XL on it will be back to it's factory settings.
May 11, 2009 | Tomtom ONE XL GPS
Touch Screen on my Garmin doesn't work
I believe simply pushing the reset button will fix your problem. The reset is located under the frame around the screen. To remove the frame, use your finger nail to carefully lift it off the screen. Then just push the reset button and you should be back in business.
please rate my answer as a fixya! Thanks.
Feb 14, 2009 | Garmin nuvi 200W GPS Receiver
D3 navigation reads the wrong location of vehicle/radio
for some strange reason these units need the navigation/GPS antenna to get accurate range i had this problem with a install in Canada it said i was driving on water..........installed a GPS pioneer antenna and i was in my zone 2ft from actual location and no longer in the water ....this unit like all gets glitches from time to time and can reset sometimes on there own but because you are surrounded by water it is confused with actual location ....hope i was able to help you
Jan 12, 2009 | Pioneer AVIC-D3 Car DVD Player
Garmin c330 gps will not turn on
try this just worked for mine
1.Under the face plate by the Garmin Logo.Use your thumbnail to remove the plate.
2.Press the reset button.
Information located on page 28 of the owners manual if you need a diagram.
Nov 14, 2008 | Garmin StreetPilot C330 GPS Receiver
Navigon 2100 problem
2 things that might help...use a paperclip and press the reset button (small hole on side, you'll feel a click) hold it for 5 seconds. THEN hold down the power on button for over 10 secs (keep holding while it shows version number) and it will perform a factory reset. You will possibly lose any settings and addresses, but better that than a locked GPS unit.
Oct 10, 2008 | Navigon 2110 Series Satellie GPS Receiver
Satellite
Are you outdoors, open view to the sky? The GPS needs to relocate itself if it's been reset or moved far away from the last location it was used. It stores it's last location in memory just before you power down, so it can relocate quickly after you switch on.....presuming you are near where you switched it off.
And there's nothing wrong with checking if all the software on the GPS is up to date with the webupdater at garmins website
Apr 24, 2008 | Garmin nuvi 250W GPS Receiver
Adding addresses
Have you tried resetting unit to the factory default? To get to this, press the snake button, then settings, then user settings. On the last page you will see reset to factory defaults. This will erase all info on the device as if it were new.
Jan 12, 2008 | Cobra NavOne 4500 GPS Receiver
LG LN790 GPS Receiver Logo
111 people viewed this question
Top LG GPS Experts
ray gallant
Are you a LG GPS Expert? Answer questions, earn points and help others
