Question about HP Pavilion dv6000z Notebook
My pavillion dv6000 will not boot/power-up, when the power button is pressed(no matter if I am working on battery or a/c power.It did power up a couple of weeks ago but now it just flashes the boot-up lights on the unit , Any Ideas ?? Thanks for your time
    Problem Solver:
  • 14 Answers
The problem sounds like a common one. So common in fact that I have replaced several power chord ends or replaced the whole adapter itself. Go to www.amazon.com and search for the model on your power chord ( located on the power pack part ).
I usally buy bulk when I can but they only range from $10.00's up to $43.00's.
The reason why I believe its the power chord itself is because the needle or pin in the tip doesnt make contact with the dc adapter in the laptop.
I replaced a few DC Adapters thinking that it was the problem when in fact it was just the power chord. The model you have is actualy an easier one, it doesnt need to be soldered if it is the DC jack that is busted.
Hope this helped.
Corey
www.appliancesplus.net
Posted on Apr 29, 2010
    President:
  • 1,768 Answers
You may have a defective on/off micro switch.
the mother board may need replacement.
contact HP tech support and or customer support they may be able to repair it under warranty for for a small repair fee.
there is a diy for this repair online.
http://www.youtube.com/watch?v=JEpnqhRYGLw
hope this helps!
4 beeps on my Hp pavillion dv6000, blank screen
No Screen on Pavilion DV2000T
I had this problem before. Tere is a good chance this may work.
First of all remove the ram memory.
-remove battery pack and wait 10 mins
-now start charging laptop without battery pack for 2 mins
-unplUg the power AND press and hold the power button for 45 seconds
-REPLUG THE POWER CABLE BUT DONT PUT THE BATTERY PACK YET
NOW OPEN THE LID WIDER YOU CAN PRESS POWER BUTTON YOU WILL SEE YOUR SYSTEM WILL START. ONCE YOUR SYSTEM IS READY SHUT IT DOWN PUT THE RAM AND BATTERY PACK BACK AND CONTINUE TO USE YOUR LAPTOP.
It hope fully will work as if you get one or more beeps, the POST is completing alright.
Hope that helps.
Dec 10, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook: My hp pavillion dv6000 dims while having the ac ad...
Go to Control Panel > Power Options
You will need to change the setting for when it is connected on battery and when it is connected on power.
May 14, 2010 | HP Pavilion dv6000z Notebook
HP Pavillion dv2500 laptop will not boot up.
Pressing the f8 key doesn't work either? This should boot the laptop to safe mode, if it doesn't then check the memory cards before you do anything else, try to get somebody with the same type of memory card to lend it to you. If that doesn't work, then your HDD is corrupted, and to re-install Windows.
Sep 05, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Unit is 3 years old. No help from HP (@$^@@*). Turn unit on, screen does not come on. dv6000 pavillion. can it be motherboard? dan
It could be the motherboard and it could be a few other things. When was the last time you had the notebook powered on? Did you notice any problems then? If you have power but no video, try taking the battery out, uplug the AC cable and press the power button a few times. Reinstall the battery and AC cable and power on your pc. Give it a bit of time to boot, must in case it needs to finish booting from the last time it worked.
Good Luck
C2Solutions
Aug 07, 2009 | Computers & Internet
HP Pavillion entertainment dv6000 - Power goes
it is problem your laptop ram is rough position or demage change it then your laptop is active
Jul 17, 2009 | Computers & Internet
My battery is at 0% and does not charge and whenever i take out the power chord my computer automatically turns off. Any help
here is a good resource I found:
Solution for HP Pavilion DV6000 Battery Not Charge
  • Reinstalling the power management software has just fixed it for me. Go to device manager and under batteries, unistall the Microsoft ACPI Compliant Control Method Battery. Go to Actions on the menu bar and select ’scan for hardware changes’. It will reinstall it and hopefully start charging immediately (mine did anyway).
  • If your HP Pavillion dv6000 has a battery that won’t charge yet still turns on when plugged in, turn off the laptop and remove the battery then wait for around 30 seconds, re-insert it and turn it back on, the charging update should say, plugged in, charging.
  • I made the bios update, and works for me. My Dv6000 battery problems were fixed. The battery led always blinking every time and the battery didn’t charge. Now it’s ok !
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&lang=en&dlc=en&product=3245619
  • If it is still under warranty you can chat with an online hp tech who will check it out over the internet and send you a replacement for free. the dv 6000 laptops have a recall on a few problems and there is a bios update to fix it before it happens but will not correct it after the fact the recall on specific problems extends the warranty to 24 months http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&lang=en&dlc=en&product=3245619 should get you to the warranty page.
  • Just got it to charge again.While the laptop is powered and in Windows XP, press and hold the POWER button until it dies. Then, remove the dv6000 laptop battery. Power it back up and enter Windows. Then, re-insert the battery.
  • So I always remove the Hp dv6000 battery after I have powered down the laptop, and I have not had any battery problems since then!
  • I had the same issue my fix was a new cmos battery that was only $10.00 and install updated bios software from HP
  • I had the dv6000 battery problem where it showed my battery NOT CHARGING. I took it apart because my QUICKPLAY would not work either and the QUICKPLAY lights stayed on even after I shut down the laptop. I found that the black ribbon cable on the right (the other looks the same but you can see it is for the power button) was slightly kiltered in the flat socket it goes to underneath the area where the quickplay button is. I straightened it out and made sure it was pushed all the way in and locked and put it all back together and everything worked perfectly after that. About a month before that my POWER and SOUND didn`t work. I did the same thing to fix those problems. MAKE SURE YOU HAVE THOSE CABLES EXACTLY RIGHT in there, IT MAY JUST BE YOUR PROBLEM TOO.
  • Some people dont realise that you should avoid short charges and discharges, if your batery does not go above 40% mabe its charge memory thinks its full. to fix this problem let the batery run fully down, then charge it all the way again. try it a few times if it doesnt work. and you have to go all the way, not let windows go into hibernation. to do that you need to get the batery low, then boot to some boot disk and let it sit till the batery dies.
  • HP has posted BIOS updates to address battery problems as well as the auto startup on some.If you will post the full model number,someone can help you find your driver/updates page.
Hope this helps, please rate! ^_^
Jun 23, 2009 | HP Pavilion dv6000z Notebook
Hp Pavillion dv6000
Hi
It is indicating battery low. Power is not passing to laptop check power card or adopter....
Thanks
Jul 10, 2008 | HP Pavilion dv6000z Notebook
No sound in speakers
Sometimes the speaker internally disables itself when another audio device is connected (i.e. headphones or external speakers) and need to be reenabled from Control Panel. Try this.
Mar 07, 2008 | HP Combo Case HP PAVILION Speakers, Mouse,...
HP Pavilion dv6000z Notebook Logo
145 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
