Question about NRS Hoveround MPV 5 - Used Power Wheelchair
How can I get a manual for the Hoverround MPV5?
We don't know how the Hoveround MPV5 that was given to my wife should be operated. The 2 batteries were charged at a gas station because looks like the MPV5 charger is not workin but still it does not turn ON.
  • Donna Angelo
    Donna Angelo Oct 04, 2010
    Are there any blinking lights on the controller? How long has it been since the power chair was able to be operated properly? have you checked the fueses in the battery cover?
    Novelist:
    Champion:
  • 232 Answers
If the power chair was stored for a while, the batteries may have gone bad. There is a gel inside them that needs to be put on a current regularly or it will solidify. When you connect the charger, you get a green light because it senses the batteries are full; unfortunately they are full of crud, not power. Try replacing the batteries to see if that solves the issue. You can probably take them to an auto parts store or Interstate Batteries to have them volt tested. The type of battery you need is a U1, 12volt, 33amp and you will need 2 of them.
Posted on Oct 20, 2010
How to locate and replace a fuse or fuses in a Hoveround MPV5
Here is te user manual to replace the battery where you can also find the fuse:
https://www.hoveround.com/Hoveround/media/Document-Library/how-to-install-batteries-for-mpv5-mk3-power-chair.pdf
May 03, 2017 | Health & Beauty
Wt is the tire psi for mpv5 middle tire
The pressure is 50 PSI, but 45 PSI worked better for me.
Sep 30, 2014 | NRS Hoveround MPV 5 - Used Power...
How do you change batteries on hoveround mpv5 ?
Disconnect cables going from battery boxes to the control box. There is probably a catch that needs to be squeezed in, then pull and wigglt the connection block until it disengages. Release the straps over the battery boxes then remove batteries and covers. Lift up on the cover (you may need to push some cable back into the box) and put cover aside. Disconnect cables from batteries and attach to the new batteries. Same procedure, in reverse, gets you back to an operational MPV5.
Sep 27, 2014 | Hoveround MPV5 Electric Wheelchair - Used...
My hoverround barely turns left and makes weird noises when it goes
This is almost certainly either bad motor brushes on the right motor, a bad right motor connection, or a bad right motor itself. Check the motor brushes, if the look good(good springs, no discoloring, etc.) Then you need a multimeter to check the motor connections to isolate the problem.
Mar 23, 2013 | Hoveround MPV5 Electric Wheelchair - Used...
Used hoveround power chair
mcdevito75 here, The control switch could be bad, Contact Hoverround online at Hoveround .com You can also check with any Medixal Supply store in your area.
Jun 20, 2010 | NRS Hoveround MPV 5 - Used Power...
I lost the Hoveround MPV5 manuals
Hello. Call the company directly to get what you need
1-800-542-7236
Mar 22, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
Where can I get a manual for a Hoveround MPV5 wheelchair? I bought a used one, but no manual.
This manual is a hard one to get. You will have to call Hoveround. If you would like, Click the link below and it will take you to Hoveround's web site.
http://www.hoveround.com/wp/products/power-chairs/mp5-power-wheel-chair/
Feb 07, 2010 | NRS Hoveround MPV 5 - Used Power...
My hoveround MPV5 will not operate. fully charged battery charger light turns green. the brakes are in run position and when the unit is turned on the charge bar just flashes and the chair will not...
You will need to take it in for repair. 8 bar flash usually means you have a bad joystick/controller. They can sometimes send it in to the manufacturer to have it repaired. Find a reputable dealer and relay this info to them.
Apr 14, 2009 | NRS Hoveround MPV 5 - Used Power...
I need an instruction manual for a Hoveround MPV 4 Power Wheelcha
Call 1-800-771-6565 extention 5000. You will need the serial number of the chair and then they will get you a manual.
Mar 30, 2009 | NRS Hoveround MPV 5 - Used Power...
NRS Hoveround MPV 5 - Used Power Wheelchair Logo
396 people viewed this question
Top NRS Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
