Question about Creative Labs ZEN Vision:M Digital Media Player
My zen v i pod is in something called recovery mode and it will not play music. it says I have "firmware" problems...what do i do now?
  • 593 Answers
Http://support.creative.com/Products/Products.aspx?catid=213
Go to this page at the top right is a red square called MP3 recovery tool, Down load and run the program, follow all instructions.
Posted on Apr 29, 2010
Listen to music and when into recovery mode
You will have to download new firmware onto your player. You can download it from here and if you scroll down, it will give you instructions on how to do it correctly: http://drivers.softpedia.com/get/FIRMWARE/Creative/Creative-ZEN-V-Plus-Firmware-1-32-01e.shtml
Aug 05, 2009 | Creative Labs ZEN V Plus MP3 Player
Getting out of recovery mode
The recovery tool mentioned above is not designed for the sleek photo. You need to download the firmware for the sleek photo from creative's site. Now we need to get your player recognized to get the firmware loaded. If you have Windows Media Player 11, it needs to be removed. Also remove WMP runtime. After that, restart the pc and your player should be recognized. You can then double click on the firmware program to run it. It might say something like, this firmaware is already installed...do you want to reload it? Click yes to reload.
I had the same problem with my sleek photo. Once I got rid of WMP and the runtime everything worked like a charm.
Jul 02, 2008 | Creative Labs ZEN SLEEK MP3 Player
Creative Zen Touch stuck in "recovery mode"
Have you tried to load the firmware? First you'll need to download the firmware to your PC from Creative's website: Click here. After you've downloaded it, connect your Zen via USB to your PC and open the firmware icon, then click "Upgrade."
For more detailed instructions on how to troubleshoot your Zen, click here
Jun 03, 2008 | Creative Labs Zen Touch MP3 Player
Creative zen mp3 help please
You will need to put the Zen into recovery mode and erase the firmware, then reload the firmware. Follow these steps:
To Erase the Firmware:
1. Get a paperclip and straighten it out.
2. Hold down the Play/Pause button, and put the paperclip through the reset hole. Release the paperclip while continuing to press the Play/Pause button until you see the screen change.
3. Select "Reload Firmware."
To Load the new Firmware:
Go to www.Creative.com/support --> downloads. Click through the navigation and download the latest Zen Touch firmware. Reboot your computer, then plug in your Zen via USB cable. Double-click the firmware icon and then click upgrade.
Apr 02, 2008 | Creative Labs Zen Touch MP3 Player
Recovery problem
Stuck in recovery mode Zen v
Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
2. Press and hold the Play button while powering on your player.
3. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All)
Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware
Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
I actually had this exact problem a little while ago with my Zen Sleek-- Booting straight to the Recovery menu, and only getting a generic "Harddisk problem" error screen any time I would try to do anything.
I decided to open it up to check out the hard drive to see what kind I would need so I could try replacing it. The data plug that attaches to the hard drive itself was partially unplugged. So, I pushed it back in all the way, put it all back together again, and turned it on just to see if something different might happen. (I had it set in my mind that the hard drive failed and I would need a new one, so I didn't expect anything different to happen) And to my surprise, it worked just like new again.
Before you go off and invest in a new hard drive, I suggest opening it up and make sure that plug is in all the way. Since you'll be opening it up in any case, it wouldn't hurt.
Mar 18, 2008 | Creative Labs Zen Micro MP3 Player
Stuck in recovery mode, never been used, screen states firmware problem . everything i have tried has not worked. Tried cleaning mode, reload firmware mode, noting. HELP
Clean Up
Format (All)
Reload OS/ Firmware
good luck
please mark the post with a fixya
Mar 16, 2008 | Creative Labs Zen V MP3 Player
Problems
Clean Up
Format (All)
Reload OS/ Firmware
good luck
Feb 18, 2008 | Creative Labs ZEN V Plus MP3 Player
Zen creative micro mp3 player
If it won't exit recovery mode and you know the hard drive is good, then you've got to reload the firmware. Do you know the hard drive is okay?
Be careful, though -- you can NOT reload the firmware on an XP machine that has WMP11 installed. It HAS to be WMP10. If you search on Zen firmware, you'll find dozens of articles on the subject.
Feb 13, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Hard disk prob
hard disk is bad.
can you format?
  1. Detach the Zen player from your PC , and ensure that the Zen Sleek is turned off.
2. Connect the power supply to the player.
3. Hold down the Play/Pause button while inserting a paper clip into the Reset hole
underneath your player, beside the data/power connector. Keep on holding the
Play/Pause button while you release the Reset button. The Rescue Mode screen will
then appear.
4. After the recovery mode has started, release the Play/Pause button
It will display the following options.
Clean Up Scans the player and removes invalid links from its music library.
Format (All) Caution! Erases all content!
Reload OS/ Firmware Caution! Erases your player's firmware.
Dec 04, 2007 | Creative Labs Zen Touch MP3 Player
Recovery Mode
The same problem happened to my sister when she reformatted. All you have to do is go on the internet fine the latest firwire software and download it on to your Zen V Plus.
Sep 05, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative Labs ZEN Vision:M Digital Media Player Logo
342 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
