Question about Canon PIXMA MP150 All-In-One InkJet Printer
Print my paper won't go through the printer straight and it is stopping
  • 4,041 Answers
Hello there It could be some thing droped inside the printer.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 29, 2010
Sam4s er-260 the ink has stopped working, how do I fix please
If you are using the right paper maybe it is just up side down. It only prints one side. Get a thermal paper. Good luck
Jan 08, 2015 | Retail Supplies
Will not print paper jam light comes on
if the printer take in one side of the paper and then stop or jam, then most probably something, small item was caught or trapped in between the roller or wheel
Feb 23, 2012 | Canon PIXMA iP1600 Printer
My canon pixma mx320 won't feed paper properly it seems to grab one side of paper and feeds it crooked then stops
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Jul 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
My hp officejet pro k8600 won't print straight.
Jul 20, 2011 | HP OfficeJet Pro K8600 Printer
My sharp cash register ER-A550S stop working
The letter H appears in the screen. The register will not respond. Any idea to what the Letter H means?
Apr 10, 2010 | Sharp XE-A402 Electronic Cash Register
Doesn't want to print
Try unplugging from the wall for 5 minutes / plug in and retry, cancels / resets printer memory.
Feb 17, 2010 | Canon BJC 3000 InkJet Printer
My HP Deskjet 400 won`t properly print a straight vertical line
check the print head belt.......belt that moves the cartridge from left to rite
check to see if all the teething grooves on the belt is intact...and that its all there..if this belt slips a teeth it wont print in a straight line....
Nov 09, 2008 | HP Office Equipment & Supplies
Canon PIXMA MP150 All-In-One InkJet Printer Logo
old marine
old marine
