Question about Flotec Simer//Omni 2957 Submersible Sump Pump with Piggyback Tethered Vertic
Float doesn't activate sump pump
When i lift the float to activate the pump it doesn't start the pump. what do i have to look for to resolve the problem.
  • John Higbee May 11, 2010
    First verify you've got power to the pump. Circuit breaker on? Power at outlet (or to where pump is hard-wired)? If so, problem is either with float switch or pump. Float switches fail more frequently than pumps, but with a sealed combination unit (which is what this one looks like) it's a moot point -- you'll probably have to replace the entire unit. If you can disassemble and get to the wiring between the switch and pump, you could connect the two switch wires together and see if the pump runs, but if you then put it back in service you'd likely have an electrocution hazard due to water leaking in where you disassembled. If/when you replace with new, you might consider a pump without a built-in switch, combined with a separate float switch, with both their cords running to the electrical outlet. That way you can replace either, without having to replace both.
5 Suggested Answers
  • 323 Answers
SOURCE: Are the genius switches any better than the float switches?
If you are placing a sump pump in a smaller, more confined area then yes. They both have their downfalls, and either can fail without notice. The ones that slide up and down the rod can get stuck or jammed, sometimes even due to build up on the rod. I tend to favor the genius switches, but either needs to be checked out periodically.
Posted on Nov 03, 2009
SOURCE: sump pump float adjustment
This really depends entirely on you. the higher the water level the less frequently it will run. most motors use more power to start than they do to run so starting less should save you money.
Posted on Nov 21, 2009
  • 5603 Answers
The switch has failed. Replace it with a new mercury type rated to handle the pump.
Posted on Dec 29, 2009
SOURCE: Flotec Sump Pump Tethered Float - Float seems faulty. Easy fix?
I have the same problem. It's not the float but the switch. My float goes up but not with enough pressure to flick the switch. I am trying to find a fix for this now.
Posted on Mar 07, 2010
I have a 12 volt emergency sump pump system SD-BSP. Sensor float failure.
If it is anything like mine the sensor is on a cord So what I do
is get some plastic wire ties and tie the cord part lower on the pump
so the float part does not have to move so far. cheap fix
oh BTW if you cannot secure it to the pump then maybe you have some vertical part you can secure it to .
GL
edward edwardaustinassociates
May 12, 2016 | Dehumidifiers
Sump pump
I am presuming you're asking about a basement sump pump, the kind that keeps your basement dry. Well, those things are not meant to run all the time. They are usually triggered by a float valve. That is a device that moves according to the water level in the sump (in other words, the hole). When the water gets high enough, the float activates a switch, the pump kicks in, the water is flushed away, the float falls and that turns the pump off until the cycle starts all over again. The frequency of the cycle depends on how fast the sump fills itself. I have one that kicks in five times a minute. Another might have a much longer off time. But don't be worrying about yours not being on all the time... that is how they are supposed to behave. Of course, if you have water flowing out the top of the sump, that is a sign things are not right with the pump. Then you really need help.
Jun 25, 2014 | Health & Beauty
Sump pump doesn't shut off
The floats could be binding on the pump or may have developed leaks so they don't float. Another possibility is that the switch mechanism is defective
Apr 01, 2013 | Flotec 1 3 HP Submersible Sump Pump -...
Backup never came on
Check that the battery is fully charged, keep a trickle charger on it so you don't have to worry. More importantly, test the backup pump float to make sure it doesn't bind on the other things (primary float, piping) in the sump crock. With the primary pump turned off, fill the crock and see if the float rises freely.
Aug 28, 2011 | ESP Wayne Battery Back-Up Sump Pump System...
I have a Zoeller Water Ridd'r II Model 48 Sump pump. The pump comes on okay, but will nit shutoff. The float is not impededd, it's just laying on the bottom of the sump. Is this a defective...
If I undrestand your description, when the resevoir is empty, the float lays on the bottom of the resevoir but, the pump doesn't shut off, after water is pumped out? You have to look at this as opposite of a toilet tank filling with water. In a toilet, the water rises and the foat turn the water flow off. In a sump the water will rise, and the float will turnthe pump on until the resevoir is empty, then it will open the system and turn off the pump. If the float doesn't rise, the resevoir will overflow and the pump won't come on at all. If the float rises and the pump comes on but, the float does "not" drop, the pump will continue to run after the resevoir is empty.
http://www.zoellerpumps.com/ProductByCategory.aspx?CategoryID=3
This is Zoellers link. I don't see your pump but they do have a support link. If the float rises and falls with the height of the water, turns pump on, then drops "all the way" and pump doesn't turn off, the switch is bad not the float. Make sure there is nothing in the way of the float dropping to it's full down position.
Jul 03, 2011 | Home
Hello I have a Bosch dishwasher model no:
Hello Zub,
It's most likely a fault with the control module or the drain pump. Please follow these instructions to detemine the likely cause of the fault and, therefore, what to do next:
1. Turn the programme selector to any wash cycle but don't press start.
2. Open the door and pull out the lower rack
3. If the washer is dry, pour roughly a pint of water into the sump in the bottom of the washer
4. Locate the float (the mushroom) and lift it . . .
When the float is fully lifted (about 3/4 of an inch) the drain pump should start and drain any water from the washer. This activates the anti-flood safety feature and the pump should continue to run as long as the float is lifted. The power supply to the drain pump bypasses the controller so this is the best way to determine if the drain pump is faulty.
If the water drains when you lift the float . . .
The drain pump is working but it's not receiving the signal to start from the controller during a wash cycle. It may be a wiring problem, but more likely that your control module will likely need to be repaired or replaced. These cost about £100 - if you replace it yourself.
If you can hear the pump humming but water does not drain when you lift the float . . .
There may be a blockage somewhere or the pump impeller may have jammed or broken away from the driveshaft. Try lifting and dropping the float rapidly about 10-20 times. Repeated stop/start signals to the pump motor can free a stuck impeller.
If nothing happens when you lift the float . . .
There is either no power to the pump motor or, more likely, the pump motor has failed. You will need to test the motor to determine whether or not it needs to be replaced. You will need a Torx T20 screwdriver or screwdriver bit to remove the kickplate under the door and an ohm / multi-meter to test the motor.
The drain pump motor should give a resistance reading of between 110 and 260 ohms across the live/hot and neutral/common terminals if the motor is good. In most cases, the reading is about 160-170 ohms.
I'd suggest testing the drain pump using the float as detailed above, then let me know the results. I'm happy to provide further assistance once the likely cause of the fault has been determined.
Hope this helps.
Regards,
BElectric
Apr 10, 2011 | Bosch Dishwashers
Pumps has power , want run
Is it under water, at least a foot deep?
Lift the float, does it start?
If you plug the pump directly into the outlet without the plug from the float, does it run?
Gary
Feb 18, 2011 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Just purchased a home with water ace sump pump.
That's the idea; if you lift the float the water starts pumping because it works off of that float. That type of pump is usually meant for water that is in a tub or bucket, so that when the water reaches a certain height and causes the float to rise allowing the pump to kick on. I use a pump like that to pump our the drained water from my washing machine in my basement, i let the water go into a big 50 gallon drum and then once the drum is half full i have it set so the float rises and pumps out the water. That being said, if you are putting this in your basement at floor level, you would need to get a 10 gallon bucket meant for sump pumps (you can get one at your local home store) and rent a jackhammer if your basement is concrete and put the bucket in the floor and the sump pump in the bucket, this is called a sump pit. Another option is to get whats often called a "floor ******" pump. Its a pump that sucks the water out when it reaches around a half inch of depth and it can be used in several feet of water (I've used these as well, there is no float involved), and it can be set on level ground there is no sump pit needed. The one thing with my pump you may not want, is that it's constantly running because its constantly monitoring for water so that a lot of water will not build up (especially if water can damage some thing in the surrounding area) . You can check out all the types at your local home store.
May 27, 2010 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Pump does not turn on
Make sure there is power to the pump by checking the outlet the pump is plugged into. If power exists then manually lift up on float to activate switch (this sometimes sticks) if pump does not turn on then problem is the motor and needs to be replaced if pump turns on make sure nothing is prohibiting the float from moving up and down fully. I hope this has been helpful to you if it has please rate on how helplful it was. Good Luck and have a great weekend.
Apr 01, 2010 | Ridgid 85937 SP-500 1/2 HP Submersible...
Same issue, one of two pumps
I'm assuming the switch in Question is a Float-switch that is positioned in-line of the Power-supply to the Pump. The hinge that activates the switch inside the Float could be faulty. You can check it by connecting a dif-
ferent device to the plug, activate the switch
(Float upright) and deactivate (Float horizontal)
Mounting the switch with zip ties is a good
idea.The Float should be dangeling about 3"
above the Pumphead, thus keeping it submersed. Hope it helps.
Jul 14, 2009 | Genius Wayne Submersible Sump Pump With ...
Flotec Simer//Omni 2957 Submersible Sump Pump with Piggyback Tethered Vertic Logo
89 people viewed this question
Top Flotec Electrical Supplies Experts
 Kenneth
Kenneth
Paul Nielson
Paul Nielson
Are you a Flotec Electrical Supply Expert? Answer questions, earn points and help others
