Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman 917270821 will not start. Battery OK, new spark plugs. Turn key, ammeter drops down but nothing happens.
rockitman187
  • 2559 Answers
SOURCE: Craftsman 15.5 lawn tractor (917.271061) won't start
Here is a link to the manual wiring schematics on page 31
Please rate this a fixya
Posted on May 21, 2009
erpaalai
  • 999 Answers
SOURCE: LT2000 had been working fine, but trying to start
Make sure there is no corrosion on the battery terminal connections and check the fuse and safety switches clutch, brake,seat.
Eric
Posted on Jun 29, 2009
  • 13 Answers
SOURCE: nothing happens when you turn on the lawn mower
Check your seat, drive safety switches. Can you turn the engine with jumper cables attached to the starter? It won't start, but should turn over, one of your safety switches is not working.
Posted on Apr 16, 2010
  • 760 Answers
SOURCE: Craftsman 54 in lawn tractor W/ 26 hp Kohler engine
Could be, but test each item with your tester. Test key switch (12V in and 12 V out when turned to start., operator present switch 12V in 12V out (seat) Clutch switch, etc. till finally you test for 12V on the small terminal on the starter solonoid. Happy testing!
Posted on Jul 19, 2010
  • 640 Answers
SOURCE: 19.5 hp twin craftsman serial number 917259560
Check that the blades are not engaged. If they are not engaged and you still have nothing, check battery cables tight. Then check the starting solinoid.
If you have any questions on how to do this or other related, just reply.
Posted on Jul 14, 2011
With key my riding lawn mower does not start, not even crank. Nothing happened.
Are you positive that the battery is fully charged? If so check for current reaching the starter motor. If current is there then it appears that the starter motor is no good. If no current reaches motor it is possible the ignition switch is no good.
Aug 27, 2015 | Craftsman Garden
Why is my Craftsman lawn tractor so hard to start?
Most likely needs valves adjusted. If you can give model number off of the engine, i can try to find the manual or instructions on how to do this for you.
Jun 28, 2014 | Craftsman 21 HP 42 in. Zero Turn Tractor...
19.5hp 42" will barely turn over when spark plug is in when I take it out it spins over just fine. What do I look for next?
Have the battery load tested. Autozone like stores do this for free. If the battery passes the load test, then check all of the electrical connections from the battery terminals tomtje starter (including the solenoid). the most likely problem os that you have a voltage drop on the circuit there. Google voltage drop test. If you are certain that your connections are ok, check again. Nothing loose or dirty/corroded/rusted/frayed. If it really is ok then get the started checked at the parts store. It is probably a poor connection somewhere.
Jan 20, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My car wont start. I replaced my battery but it still wont start. Tested the alternator and it is good. Something might be draining the battery but not sure what?
Does the engine spin over and not start? Or turn the key and nothing happens?
New spark plugs and wires won't have anything to do with the starter and battery keeping the engine from spinning when you turn the key.
Need more specific explanation. Thanks,
Scott
Jan 22, 2013 | 1987 Mercury Grand Marquis
19.5 hp twin craftsman serial number 917259560 turn key nothing happens battery new, switch uner seat in ok position
Jul 13, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Tractor will not turn over even with new battery
try taking the spark plug out and spinning it over, it your still not getting anything does it even make a noise when you turn the key if your hearing a click and nothing else you could have locked up motor, a bad starter solenoid, or a bad starter, let me know what happens
madminibiker@gmail.com
M.Woodring
Apr 19, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine won't crank on a 18.5hp 4000. I checked mechanical interlocks, charged battery and put in fresh gas. New carb and fuel lines put in last year. When I turn the key, there is a click and the ammeter...
The starter solenoid is most likely the clicking you hear. It has contacts inside which go bad. These are about $10 and easily replaced. Just follow the + battery cable and it will lead you to the solenoid.
Jun 05, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Battery is new. I turn the key and nothing comes on. I can jump it off and an hour later it wont start again
take the battery in to have it tested it may be defective. if the battery tests ok your alternator isn't charging. if you have a volt meter , your battery voltage should be no lower than 12.5 volts dc and with the motor running you should see no lower than 13.5 volts dc with everything turned on (lights, ac on fan on high) if the voltage drops below that your alternator is bad.
Jan 28, 2010 | 1990 Lincoln Town Car
My riding mower won't start. It's a Craftsman
Check your seat switch and brake switch for loose wires.Most likely brake switch do to no spark at plugs,see if PTO switch/lever isnt on.
Nov 22, 2009 | Craftsman Garden
Craftsman mower will start with pull but not with
When it turns over, is it somewhat sluggish (not as fast as before)? I would suspect your battery is weak, and the voltage drops so low that the engine does not spin fast enough to start. Also, without knowing what type mower this is (which model) it could be the voltage drops too low to generate spark (if equipped with an ignition module)
Whereby pull starting it, you aren't loading the voltage down with the starter, and the ignition module still works... So it starts.
Charge the battery per the owners manual. If that doesn't help, you may need a new battery, or you may have a bad connection between the battery and starter solenoid (heavy cables). If a connection has high resistance, it will drop more voltage at a given current.
Jul 30, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
136 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
