Question about Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner
I have a Cub cadet LT 1024 which will not start. The solenoid clicks like it is trying and lights will come on but that is only reaction. Battery is brand new and hooked up properly.
  • 61 Answers
Solenoid clicks, only tess you the coil is working inside the solenoid. disconnect cable from battery to starter. with ohm meter check for continuty across main terminals of solenoid while holding key to start. if no continuity, solenoid is defective.
Posted on Apr 29, 2010
Will a model OEM 190-621 snowblower fit on a cub cadet LT 1024
Have you tried the cub cadet forum? If not, give it a click:
http://onlycubcadets.net/forum/forumdisplay.php?f=42
Nov 21, 2014 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Why does cub cadet lt 1024 drive belt keep coming off belt
Once the drive belt comes off once - it's probably stretched and twisted and won't stay on. You'll need a new belt - be sure to get one that's Kevlar so you won't be replacing as often.
May 03, 2014 | Cub Cadet Garden
Cub Cadet Riding Mower LT 1046 have to jump, but won't stay running
Check the bottom of the carburetor for a little solenoid. If it has one, the battery may be dead enough that it can't keep the solenoid open causing the carb to shut off the fuel flow causing the unit to die. The easiest way to check if it works is by turning the key to the run position and listen and/or feel for the solenoid to click. If it clicks it is working and there is another problem, if it doesn't then replace it. I recommend having the battery tested or replaced too
Jan 03, 2013 | Garden
I have a cub cadet series 1000 LT 1024 need to replace drive belt, how do i get the pto clutch off?
You donot get PTO of to change the belt. if you want to take the pto
clutch Need to turn the opesit way left
May 31, 2012 | Cub Cadet Garden
Cub Cadet LT 1045 - Not starting, the engine does not turn.
remove the starter...use jumper cables to "run the starter manually...red to big lug, black to body (anywhere is fine) should torque hard at initial run and continue to run smooth...if it buzzes or vibrates, it's bad...replace...
Apr 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
CUB CADET LT 1046 WONT CRANK
If the head lights come on, check the PTO switch connector. Very often the connector comes loose.
If no headlights, check the fuse. If blowen look for shorted wiring: Mice may have chewed wires inside the flywheel cover; check the head light cable. Often it rubs through at the hood pivot; check the lead on the carburetor solenoid, sometimes they rub through at the wire ties holding the red lead to the solenoid.
I am a certified Cub service tech,and those are the common problems I have run into.
Oh, one more thing, make sure the battery is good. Load test it or have it load tested if you don't have a tester. Don't just check it with a volt meter. That wont load the battery to check for dead cells.
Jul 05, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 1024 wont turn over
try taking an insulated screw driver and jumping across both terminals on the solenoid, if the engine turns over, the solenoid is bad and will need to be replaced
May 02, 2009 | Garden
I have a Cub Cadet LT 1024 Series 1000 riding mower. It has been starting hard and it is not the battery. Now it tried to start and when I tried a second time to start it there was no sound at all. I'm...
Try lifting the hood on the mower and turning the flywheel, back & forth by hand, this will release the starter gear from the flywheel.
It could be the starter, but I would load test the battery first.
Apr 14, 2009 | Garden
Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner Logo
1,308 people viewed this question
Top Oregon Scientific Garden Experts
Dan Connors
Dan Connors
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
