Question about E-Machines eMachines T3830 PC Desktop
I have a w3503. I am trying to add a second monitor. hen I install the card noether monitor will work.
    Genius:
  • 1,584 Answers
You need to "clone" it in the video sofware.
Posted on Apr 30, 2010
How to add a 2nd monitor
Most laptops have a VGA port so an external monitor can be added. Then you might have to press a Fn key combination to get the other monitor to display.
If you want to add a second monitor to a Desktop computer, you'll need to install another graphics card. A USB adapter card is available; do a search for different models available.
If neither of these answer your question, please explain exactly what you need a monitor to display from; you posted to the Network and Wireless Adapters section, which is confusing..
Mar 06, 2016 | Computers & Internet
New display detected vista
Boot-up in safe mode; add the MSI video drivers and re-boot normally
Mar 07, 2014 | MSI Computers & Internet
I would like to hook up my old monitor, product LT782s, model 700P, to my new monitor so I can have duel monitors. The cord has 2 screws to attach. The new monitor does not have any place for a "scr
You need to connect both monitors to a computer. Monitors do not daisy-chain (in general). The exception are some SCART-enabled monitors.
What is your source (desktop)? What is the make/model of your new monitor? Please add a comment with the video outputs/inputs for your source and second monitor.
Many newer desktops have two or three outputs. (Some video cards have display port outputs which with active adapters can support 2 monitors each.)
If your computer has two or more outputs and your new monitor has an input compatible with the extra output, get the appropriate DVI, DVI-HDMI or HDMI cable for your new monitor. See the next section if both monitors have VGA input.
If you have a desktop with only one video output, you may be able add a video card to support two monitors. (Depending on your computer, you may need to upgrade the power supply to support a video card.) Then get the appropriate adapter or cables to add the second monitor. (Note: if both of your monitors have only VGA inputs, check the specs for video cards carefully. Not all modern cards support analog outputs on their DVI, HDMI or Display Port connections. These digital outputs would require a digital to analog converter to give the VGA out.) However, if one of your monitors will accept DVI digital signals and the other VGA, add a card with one of each of these connections and a DVI cable to match. (This is an if needed extra; many monitors still ship with only a VGA cable.)
Then turn off your computer, open it and add the video card. Install the drivers with only one monitor attached. Then power down the computer and connect the second monitor. Turn on both monitors before turning on the computer again. Most of the time, the second monitor should be recognized (by Windows) and the appropriate refresh rate and resolution chosen. If not, you may need to enter the Display settings to set the monitor up.
I have seen some computers/video cards where only one output is initially enabled. You may have to go into the device settings to enable it. (Laptops often need their external video ports enabled in the BIOS.) Bad video ports/cards/cables do happen so RMA if needed.
The USB video adapter, http://www.newegg.com/Product/Product.aspx?Item=N82E16812225007 , can be added to a desktop to give a second VGA output but it isn't the best solution. USB bandwidth limits are significantly lower than those for a PCIe x16 slot or an old AGP slot.
I hope this helps. Please add more information about your system if you want more assistance with this problem.
(who has done dual monitors with older and newer computers. My old Pentium 4 with a Radeon x1350 video card was fine for driving a VGA monitor and an HDMI monitor (using a DVI to HDMI cable). My second generation i5 and P8Z68 motherboard system is also fine using the on-CPU video graphics for those same monitors. A video card would improve gaming but isn't required.)
Dec 13, 2012 | Computers & Internet
How to add a second monitor to my aspire az1620
If the graphics card has only a single video connection then it is not possible to add a second monitor.
If it has two video connectors the you can add a second monitor otherwise you need to replace the existing video card with one that supports dual monitors..
Dec 04, 2012 | Acer Aspire AZ1620-UR31P G530 All-In-One...
PL191M works for 10 seconds, then goes off with small green light blinking. If I turn it off and back on again, it works for 2 seconds and goes back off. The owner's manual says to push the upper...
There is a couple of possibilities and things to eliminate.
Your monitor is acting like it's not getting a signal. First make sure your video cable is plugged in and tightly connected with the screws fully torqued down. Test the video card by wiggling the connected cord to see if the monitor comes on even temporarily. Try opening the case and re-seating the video card.
If you can get the monitor to stay on long enough go into the control panel and the properties page and make sure you screen saver or power management for energy savings is not set to zero.
If it's new you may have to go the your control panels add remove components and un-install the video card then re-install the driver again. Windows is famous for this requirement.
If you are using this as a second monitor connected to a laptop you will have to hit the corresponding function key on the top row of your keypad, F4 or ?...., to open the port to avail the signal.
On a mechanical level at the monitor depress the Menu button and try a few sizing adjustments to bring the picture back to shape.
Cable - HDMI, USB, VGA ? You may need an adapter to get the signal VGA to HDMI etc.
We need more information but try these things to start.
  • New Monitor
  • 2nd Monitor for laptop
  • PC or Mac
  • Type Cable
  • What happened when it quit working
  • Has it ever worked.
Let us know how we can help further.
TF
Sep 16, 2011 | Planar PL191M 19 in. Flat Panel LCD...
Amber colored power light on eMachine W3503
The amber power light indicates that your computer has been "sleeping" or "hibernating" and usually all it takes to restart the computer is tapping a key on the keyboard. If this is not the case, try holding the Power switch down for 6-10 seconds to force the system off. Restart in Safe Mode and try to find the settings for Sleep/hibernate, open the control panel and open the Screen Saver. Select "Change Power Settings" and set it for "Never" on sleep and hybernate.
Nov 10, 2009 | E-Machines W3503 PC Desktop
No monitor display
there is something wrong with your ram....take it out n clean it with rubber....den agin hook it up in its place...after dat it ll work....otherwise u need to replace ur ram
Sep 01, 2009 | Intel D101GGC Motherboard
Ok, i have two things to ask 1: Where is the video card on a emachines W3503? 2: Could a video card swap be done between a W3503 and a W3052? Thank you for viewing :)
1. The emachines W3503 has an integrated ATI Radeon™ X300 based graphics card. It has also a PCI Express (PCIe x16) slot available.
2. The emachines W3052 has a NVIDIA® GeForce®4™ MX graphics card. I'm not sure whether it is integrated or not, but I'm sure that if it is not, it will be an AGP graphics card. Since The emachines W3503 has a PCI Express (PCIe x16) slot available for installing a graphics card, the swapping of graphics cards between the 2 machines is not possible since they support different types of graphics cards.
Jul 11, 2009 | Computers & Internet
E-Machines eMachines T3830 PC Desktop Logo
37 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
