Question about Yamaha RX-V457 Receiver
Yamaha rx-v457 intermittent power problem
This unit has an intermittent power problem. Sometimes it turns on and sometimes it doesn't.
5 Suggested Answers
simplemitch
  • 752 Answers
SOURCE: Yamaha RX-V1 Power
The amp is blown. Unhook all speakers and try it again. If it still shuts down it will have to be repaired.
Posted on Nov 29, 2007
  • 4234 Answers
SOURCE: yamaha rx-1500 av receiver
The unit is in protect mode. There is a problem with the last stage of the amplifier section and the unit shuts down to prevent further damage. The most common cause if this is shorted output transistors. If you are comfortable with soldering, you should be able to repair this. Check the transistors attached to the heatsink for a shorted condition. Replace them in pairs.
Keep us posted.
Dan
Posted on May 20, 2008
  • 125 Answers
SOURCE: Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Posted on Feb 03, 2009
Bennytechkid
  • 99 Answers
SOURCE: Yamaha RX-V750 AV receiver power problem
G'day i have had the Same Problem With a Yamaha RX-V750 That i have Repaired...You need to Replace the Three Capacitors On the Sub-Transformer Board...They Hold a Small amount of current to use to turn over the transistors and in turn trip a relay that boots the unit these go dry all the time in these units..replace them and it will work again no prob's
Components As Follows:
2x 2.2 uF 100V (C402) (C403)
1x 1uF 50V (C401)
The relay also could be damaged...or the diode across the Coil you may have to replace these too these faults could have been caused by a surge...or just faulty cheap and nasty components!!
Ben M
Posted on Jul 09, 2009
Intermittent starting
Possible bad ground or battery terminal connector.
Jan 22, 2014 | Chevrolet 3500 Cars & Trucks
One speaker doesn't work on my bose wave radio/cd?
I can only get one speaker to work continuously. The other works intermittently. If I move the power cord a bit, I can sometimes to get the one "bad" speaker to work. When it's working, the speaker sounds fine. This is driving me crazy. The power cord is new, so I think it has something to do with the power supply. The unit is a '95 Bose Acoustic Wave CD-2000.
Nov 04, 2012 | Bose & Wave& Music System
Sony kv hw21m80/h sometimes wont turn on. pulling the plug sometime help.
Check its main power supply regulator section for any loose solder terminals. Resolder all suspected solder terminals, by applying a little more fresh solder.
Jul 13, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My 1996 Olds LSS doesn't idle properly,idling surges sometimes,the temp. gauge doesn't work and sometimes the heater doesn't work.It may stall while driving.If I get in and the power seats...
Your first problem is to find out why the intermittent no-power problem. Honestly, that sounds like a loose conmnection somewhere. check all your grounds for clean and tight conditions Also, battery connections and alternator connections. Double check your power distribution center for any loose wires or poor connections. Once you solve that problem, then you can diagnose the other problems with poor idle and temp. gauge.
Oct 17, 2011 | 1996 Oldsmobile LSS
My 1995 olds 88 starts most of the time but sometimes i try to start it and the starter doesn't work. There is power to the dash but nothing to the starter. Ican sometimes get it to start by moving the...
This intermittent kind of "no start" problem can often be a result of a failing anti theft system. Read this link and compare you symptoms. If you see a light that reads "security" when this happens, then this is definitely your problem. http://vatspasslockpasskeysecurityhelp.yolasite.com/
Jul 04, 2011 | 1995 Oldsmobile Cutlass Supreme
INTERMITTENT POWER PROBLEMS
Sounds like you have intermittent contact between the constant 12v and the ACC 12v power inputs. Remove the head unit, and make sure that the connections are properly insulated. (using inline **** connectors preferably)
Aug 25, 2008 | Clarion DXZ375MP CD Player
Sony DSR-PD170 Color Problem
sounds like a problem with the image sensor, or an intermittent cable connection to the sensor.
Jan 06, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Yamaha RX-V457 Receiver Logo
382 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
