Question about Sanyo DVW-7200 DVD/VCR
Won't turn on video tape stuck halfway inside
  • 417 Answers
Stuck halfway inside could indicate that the actual tape is stuck in the capstan/heads. It may have never fully released from the mechanisms and returned to casing. Basically it ate your tape. You could try taking the cover off the unit and manually and carefully remove jammed tape. Unplug the unit first. Hope this is helpful.
Posted on Apr 29, 2010
Remove stuck cassette tape
To remove the tape you will need to pull the whole unit out of the dash and disassemble it.
Jun 11, 2017 | Kenwood Car Audio & Video
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
Cassette does not eject
Either the tape is jamed round sound head, or the door is stuck with somthing like a handle of the case on side of camera, but sounds like tape stuck, run film backward a little (not forward) as more tape will get stuck in forward motion.
May 24, 2010 | Sony Handycam DCR-TRV280 Digital Camcorder
Tape seems to be stuck to itself, I can't free it up
I think you are refering to the tape itself in the VHS cassette and it not being stuck inside the Video itself!
So if you are... don't use the spray... video cassettes have a brake system inside them. It sometimes breaks. If you turn the cassette upside down so you can see the white reels, inbetween them near the bottom (where the side label goes) you will see a small hole. If you put a pen inside it should release the reels so you can turn them with your finger. If they don't turn it may be broken. In which case... Get hold of a blank tape, the same length as yours. Carefully remove the screws (5) on the bottom. See how it's put together. Once you understand how the tape moves etc. Take out the reels with the tape, then dismantle your video and put the reels with the old tape into the new holder. It should work as good as new.
PS try not to touch with fingers the tape.
Sep 27, 2009 | Panasonic AG-1330 VHS VCR
JVC DV800GU Cassett stuck halfway in while loading new tape
try taking in out with a sharp object, while off
Jun 18, 2009 | Video Cameras
Tape won't eject from CCD-TRV608
There is a little plastic piece on the tape and it is getting stuck, you have to maually move this piece, witha paper clip or something else. it might break the piece off, but that is the only way I know to get it out.
Dec 18, 2008 | Sony Handycam CCD-TRV608 Camcorder
Tape will not eject
If you remove the power while the basket is halfway up, you should be able to remove the door. Then look to see if the reels are turning when you try to elect the tape. The error code you are getting indicates the reels are not turning for some reason. You can ssist the reels turning as the tape is ejected if you have a small plastic pick or a toothpick into the reels to assist the reels turning and tehn you may be able to remove the tape.
There is a tape stuck in my camera.
there may have been a spring that pulled on a tab in these places that will unlock the the tape , and if is not unlocking it will go back to close position
Oct 24, 2008 | Samsung VP-D10 Mini DV Digital Camcorder
How can I remove a stuck video tape from out of a VCR?
You will have to take the cover off. ( un-plug the AC cord)
Look for the loading motor at the back right side.
Rotate the motor and you will see the tray moving thru its cycle to un-load the tape, it does take quite a few turns, its slow.
Let me know if you run into a problem?
Apr 08, 2008 | Panasonic PV-V4523S VHS VCR
Canon ZR 45 Won't Eject Tape
That would be the take up or supply reel fault. It may also be a mode position error. Try here for advice but I don't advise tackling this job without full service instruction manual for the deck. No idea of your country so try here first;
https://www.usa.canon.com/internet/portal/us/home/support/details/camcorders/support-minidv-camcorders/zr
Apr 15, 2017 | Video Cameras
Televison & Video Logo
214 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
