Question about Kyocera Slider Remix KX5 / Sonic Cellular Phone
Power how do i turn the phone on?
  • 30 Answers
Hold the END button for about 3 seconds, or the SEND button.
Posted on Jul 14, 2008
SOURCE:
Power button on my phone won't work
i think your power button is broken
Mar 22, 2014 | Pantech Cell Phones
I put my U5i to charge and when I woke up in the morning it was shut down and I can't turn it on...In two words the phone died.
Did you drop the phone in water recently? Did you get it wet in the rain? Apart from the likely possibility that the phone is actually damaged/battery damaged, this happens if the power button gets damaged. When you put the phone to charge, in the middle of the night the power button "acted" as if it was pressed and held and the phone turned off. Now when you press the power button, nothing happens because the power button is damaged.
Take it to a repair shop and check the power button for damage. It is replaceable and should not cost a lot.
Does your phone have a removable battery? If yes then you might be in luck. If not, then just take the phone to repair shop and get the power button checked and repaired.
If battery is removable I know that it is possible to turn on the phone this way:
1) Plug in the charger to the phone
2) Remove the battery and insert it immediately. Do this multiple times and the phone should turn on without having to press the power button.
Hope that works.
Sep 27, 2013 | Sony Ericsson Vivaz U5i ruby Red Unlocked,...
My cell phone turned off and it won't turn back on. How do I get it to turn back on? I've tried the power button and already tried the volume, home button and power button at the same time trick.
Plug the phone into the charger. With or without the battery the phone should turn on when you hold the power button for more then 2 seconds. If the phone does not turn on then you should check with the manufacturer about getting a replacement under the Manufacturer's Warranty.
Feb 28, 2011 | LG Ally Cell Phone
My power button is broken and my phone wont turn on
plug in the phone to charger. after you see the verizon sign, wait two seconds and unplug it quickly. it should turn on.
May 20, 2010 | LG Dare VX9700 Cell Phone
Need to turn phone on but the power button is broke. It charges and turns on but just the charging screen
you need to replace the power button so that you can power your phone well again.
But there is another way by which you can power the phone without the power switch. This will involve you opening the phone cover so that you can gain access to the power button area on the phone board/panel.
Get a phone screw driver, open the phone, insert the battery into the phone, get a tiny wire and bridge the power switch panel and the phone will power on.
Try this, and it will work. I am very sure about this.
Take care.
Mar 18, 2010 | Samsung Blast Cellular Phone
My i880 turns off when i put it in the charger
the power IC is dfected, because the power IC is controlling POWER, SIGNAL SIM READER & CHARGING,, so replace the power IC
Apr 09, 2009 | Motorola Mobility i880 Cellular Phone
My nokia n95 turn to white screen.
Power off phone. Press and hold Green, * and 3 and keep them held whilst powering on and for a few seconds after
man the code written is hard reset for n95 **** .there is a hardware problem in the cell phone you need to change the strip of ur cell phone which connect the upper and lower portion.
Jan 30, 2009 | Nokia N95 Cellular Phone
Out of Range
Do you have power to the base? I've seen this message on several cordless phones if the base is unplugged, the power brick has failed or the power adapter was plugged into a power strip (or surge protector) that has been turned off. It can also happen if the circuit breaker for that outlet has tripped.
First check that the power adapter is plugged into an outlet and the other end is plugged into the base. If the power brick is cold, check that the outlet has power by plugging in a different device (like a lamp) and turning that device on. If there is power, than you need to replace the power adapter or the entire phone (if you can't match the amperage output of the adapter). If there is no power at the outlet and the adapter is plugged directly into the wall outlet, check your circuit breaker for that outlet.
If you used a power strip or surge protector, check if it is on. For a surge protector, check if the surge protection circuit light is on. Replace bad surge protector.
I hope this helps.
(I have seen someone intentionally turn off a surge protector during an extended power outage and then fail to turn it back on after power returned. The individual forgot that they had turned things off before they called for assistance with their phone.)
Aug 17, 2017 | GE -25893GE3 Cordless Phone
Turn on
what you have to do is to replace the power buttton you broke with a new one the power button you broke doesnt make contact with the phone.advice by dogy
Dec 21, 2007 | Nokia 6233 Cellular Phone
Kyocera Slider Remix KX5 / Sonic Cellular Phone Logo
50 people viewed this question
Top Kyocera Cell Phones Experts
Jeffrey
Level 1 Expert
Mufaddal  Kurlawala
Mufaddal Kurlawala
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
