Question about GE 97985 Mouse
How do i connect my ge wireless mouse to my laptop
    Problem Solver:
  • 9 Answers
There are two parts to the mouse - the mouse itself and the receiver. The receiver looks like a thumb drive. Plug the receiver into one of your USB ports (I assume you already have a battery in the mouse). Some laptops show that you have plugged in the receiver and automatically installs the driver. Look on the receiver and see if there is a flashing light. If so, that means the receiver is attempting to sync to the mouse. Look on the sides or bottom of the mouse and there should be a small button. Press that button and it will sync the mouse with the receiver. Let me know if this helps!
Posted on Apr 29, 2010
2 Suggested Answers
joeguest2
  • 2080 Answers
SOURCE: my ge wireless mouse 98552 won't hold a
Assuming the batteries in the mouse and keyboard are fully charged, next make sure all your cables are inserted correctly.
Check that the data cables leading from the base unit to the computer are securely inserted into the proper connectors at the rear of the case.
Next make sure the power cord for the base unit is plugged into a live power outlet and that the other end is securely plugged into the back of the base unit. Often times this plug will come out halfway and so will look plugged in but will cause intermittent problems.
Next make sure your mouse is not too far away from the base unit when you try to use it. Normally 8 or 10 feet is the maximum distance these units will function properly at. Also make sure there are no obstructions between the mouse and the base unit. You can also clean any dust or debris from the small LED bulb on the underside of the mouse with a dry QTip to ensure that is not the problem.
Now depress the CONNECT button on the base unit, then while the light is flashing depress the small CONNECT button on the bottom of the mouse.
Now try using the mouse.
If the unit still does not function after that, then leave them plugged in and RESTART your computer.
Repeat the CONNECT procedure for the mouse after your computer restarts if necessary.
You may have to do the connect procedure 3 or 4 times before it connects properly so just keep trying the connect process until it works. Make sure you have the mouse right right beside the receiver when you do the connect procedure. Also make sure you use a mouse pad under the mouse, some surfaces do not work well with certain mice. Also make sure there are no other wireless mice in the same room when you do this. Also make sure you don't have a regular mouse plugged into the computer at the same time. Try switching the receiver to a different USB port on your computer just in case the one you are currently using is faulty.
Please comment back here to this page if you have any questions, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Joe.
Posted on May 06, 2011
Do I need a receiver plug-in for my Gateway laptop to use a GE wireless optical mouse model 98763?
Garrett, Yes, plug in the receiver that came with mouse. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
GE Wireless Mouse and Driver Problem Fix
http://techin.oureverydaylife.com/ge-wireless-optical-mini-mouse-stepbystep-setup-13706.html
GE 98796 Wireless Optical Mouse Manual
Aug 22, 2016 | Gateway Computers & Internet
I have a GE mouse 98543, it has been an issue since day one, it seldomly works and ive about had it, the laser does not turn on the bottom, and I have tried switching the batteries but still does not work,...
It could well be a duff mouse. I have had several GE Wireless mice, and a few just failed to connect up correctly however much you push the connect buttons.
But, it is worth trying different batteries. 2 or 3 of my mice refused to work. Like you, I tried everything, including swapping out batteries. After so may attempts I gave up, but then, by chance, tried a different type of battery (may be not Alkaline). Don't use re-chargeables. They have too low output voltage. If you have a test meter, find a couple of batteries that are putting out at least 1.6v each - more if poss. Then go through the press connect on USB plug, then on mouse (within 2 seconds) and if lucky, the LED on the USB plug will go off as soon as you press the connect on the mouse, and you will be in business. If not, may be just a dead mouse!
Aug 21, 2013 | GE Wireless Optical Mouse
No connection after changing the batteries and pressing the connect button.
You could try reinstalling the drivers that came with your mouse, also try pluging the wireless receiver into a differnet USB port. Check that the batteries are indeed the correct way round. It is possible that the batteries are not strong enough, try another set. Move the mouse as close to the receiver as possible.
Sometimes there is a connect button on the receiver as well as on the mouse, push them together if this is the case.
An additional test would be to try htis mouse set in another computer/laptop.
Take care!
damnor01
Jul 01, 2011 | GE Wireless Optical Mouse
I have a ge 98563 ergonomic wireless mini mouse and my laptop wont recognize it
I have had no problems with my compaq laptop and the mini mouse. It recognized it even after OS downgrade to XP. The reset buttons on the mouse and the transceiver need to be activated or reset when sitting idle for a while. Once you get them both "blinking" it works great. Good mouse for the price... Your laptop should recognize it. Just check the reset and make sure the lites are on and communicating.
Nov 21, 2010 | GE Wireless Optical Mouse
Laptop wont sense wireless mouse
1. Check to see if there is a Connect Sync Button (small) on the bottom of the Mouse. Probably one one the USB Receiver as well... press both at the same time or within 10 seconds.
2. Or Try a different USB Port.
3. Make sure you see the Laser Mouse Red Light at the bottom... if not check battery positions.
Jan 09, 2010 | GE Wireless Optical Mouse
I havve a HP G60*230US notebook and have purchased the GE wireless mouse, I can not seem to get it to work with my laptop..
To activate the mouse press the connect button on the receiver and look underneath the mouse for the connect button and press that.
All you have to do then is right click on the mouse to activate it.
Regards.
Sep 29, 2009 | GE Wireless Optical Mouse
I am unable to get the wireless mouse to work. How do I make it work? It is a GE 98811 Ergonomic wireless mouse. The batteries are in correctly.
be sure to push the connect button on the mousr itself and also the connect button on the little piece that plugs into your USB port
Aug 08, 2009 | GE Wireless Optical Mouse
My GE mouse doesn't work anymore
First thing to do is check the device manager. If it shows up there, make sure that there are no icons saying there is a problem.
Jul 29, 2017 | GE JASHO97985 Mouse
GE 97985 Mouse Logo
390 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
