Question about HP Photosmart C5180 All-In-One InkJet Printer
Ink system failure
Hp photosmart C5180 show ink system failure. cannot print or copy anything
  • pippincp Apr 08, 2008
    Exactly the same problem as linroze error code is 0xc18a0501.
    Trouble shoot guide at HP advised switching off printer, unpluggint it and removing cartridges. Leave for 2 mins plug back in and wait for prompt to install carts again. Made no difference. Any other Ideas?
    Problem Solver:
  • 10 Answers
The main thing to do is to ensure that you have it plugged directly into the wall for power. It sounds silly, I know, but humor me.
The other thing you can try, is replacing the cartridges or power module which unfortunately is not the most cost effective method of finding out your printer is no longer functional.
If those steps do not resolve it, you have a hardware issue that will need to be serviced.
Posted on Mar 24, 2008
My photosmart printer says ink system failed unable to printer.refer to printer documentation
Ink system failure is mostly caused by print heads. i do apologize but with issues like this, the best resolution is to replace the printer. it will only cost you buying new ink cartridges but it will not resolve the issue. :(
Sep 19, 2014 | HP Photosmart C5180 All-In-One InkJet...
Hp photosmart C5180 and windows XP. I have been gettikng message on window of printer: Ink system failure. I turned the printer on and of several times to no avail. Took back of printer off and looked...
The ink system failure is caused by air in the ink cartridges, You need to do a purge on the system to clear it. We have a step by step guide to do this procedure posted at:
http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/
This should get you back printing in about 10 minutes.
I hope this helps, if so please rate our solution.
BuddyMc
Feb 04, 2011 | HP Photosmart D7160 InkJet Printer
Error ink system failure on photosmart c5180
The "ink system failure is a common error on HP printers, it is caused by air in the ink cartridges or ink feed tubes. YOu will need to do a ink purge routine to clear the error. We have several pages on our web site explaining what causes the problem and how to clear it. The link is: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/
This should get you up and printing in no time at all.
I hope this helps you, if so please rate our solution.
CCL Tech
Corporate Computer
www.ccl-la.com
Oct 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
Error Ink System Failure 0xc18a0201
remove the ink cartridge and print head and then do a power drain. after that insert the print head and ink cartridge.. if it still shows the 0xc. error try by replacing the print head .. first
Jul 28, 2010 | HP Photosmart C5180 All-In-One InkJet...
My HP Photosmart C5180 printer keeps coming up with an error message 'Ink System Failure. Does anybody know what is needed to solve the problem.
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com, click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Nov 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
I have an Hp c5180 and I am unable to print.
Look here: http://www.out-of-warranty.com/ink-system-failure-error-0xc18a-hp
Oct 04, 2009 | HP Photosmart C5180 All-In-One InkJet...
Oxc18a0201 ink system failure. Apparently failed due to using non HP ink. HP recomends buying a refurbished replacement. The printer is HP photosmart C5180
1.-press key * # 2.-enter code 123 and select a Hardware faliure status 3.- Press clear OK and finish cancel for end restart print
May 23, 2009 | HP Photosmart C5180 All-In-One InkJet...
Used copy ink now it wont print
see if this works, its worth a shot. not correct code but may help . Shut down your printer by pressing Simultaneously Cancel + OK + Black + Color
Apr 29, 2009 | HP Photosmart C5180 All-In-One InkJet...
Ink System Failure HP C5180
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jan 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink System Failure on HP Photosmart c5180
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
Dec 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
122 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
