Question about Mitsubishi VS-60603 60" Rear Projection Television
Vs60603 60in turns off unexpectally
Turns off every once in a while have to wait a few minutes to turn back on
  • Mitsubishi Master
  • 12,061 Answers
Ok, this is happening because the set's "Brain" and Switchmode Power Supply, have detected a "Fault" condition, that were it to "Fail" it may cause a fire, and explosion,or both, and "it" is Shutting down the set for safety reasons. When it cools dawn, the affected part, works again, the fault clears temporarily, and the set will again power up, until the fault "Comes On" again,and it shuts down. This fault, would very soon, go "Hard ON" and cause total failure. Below is a service manual, so you can get an ideas of what maybe wrong, and a possible fix. I actually recommend though, that you get a professional, to attend to this matter. Contact Mitsubishi, head office and ask for an authorised repairer. You will save $$ in the long run.
http://elektrotanya.com/mitsubishi_wd-52525,62525,52725,62725,52825,62825_chassis_v26_sm.pdf/download.html
Posted on Apr 29, 2010
The refrigerator is not cooling and is there a reset switch that I can use to start the compressor
Just turn it off and wait a few minutes, then turn it back on again. Or just decrease the temp setting as low as it goes, then reset it once the compressor starts.
Mar 22, 2015 | Sub-Zero Refrigerators
Tip
Alignment of Throttle Body
put the key and put it into the position just before the starter turns (do not start the car) push the gas peddle all the way wait 3 seconds and turn the key all the way back but do not take it out, now release the gas peddle and wait 2 minutes! remove key than put it back in and start the car! you should notice a better response while pressing the gas do this once every few weeks!
on May 19, 2008 | 2002 Audi A4
I accidently turned the pilot off and I can't get it to turn on Williams Model# 2001622
Turn the control valve to the PILOT position and push down and hold it in. Press the Ignitor Button and continue to hold the Control knob down, once the pilot lights. Wait one minute, release the Control Knob and if the pilot remains burning, turn the Control Knob counterclockwise to the ON Position. If after the burners light and burn for a few minutes, you can turn the Control Knob back (Clockwise) to the Pilot position (if you don't want the heater to come on automatically) and the pilot should remain lit.
Hope this helped to get you back up and burning.
Mar 30, 2011 | Williams Heating & Cooling
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
Model PJ556D will run for a few minutes and then shuts off. Once it cools down it will start back up, but shuts off again a few minutes later.
Hello, Greg.
The most common reasons are the temperature is too high or the ventilation holes are blocked.
Unplug the AC power cord, wait 5 or 10 minutes then turn back on.
There could be dust or the air filter needs to be changed.
Take the lamp cover off the bottom. It's possible that the screws holding the lamp are loose.
Hope this helps.
Apr 05, 2010 | ViewSonic PJ556D DLP Projector
Power turns off by itself once in a while. i turn
There can be several causes for this, few of which you can do anything about. However, a few things to try.
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
Good luck with your problem...I hope you can work it out.
Feb 25, 2010 | Mitsubishi WS-65311 65" Rear Projection...
Satellite a300 wont install windows (brand new)
turn off the computer and disconnect the battery . wait like half an hour. put it back in you have to wait a few minutes for the battery to finish charging then turn it on . this should help. the menu will pop up after you type your password in .
Mar 15, 2009 | Toshiba Satellite A300-0CF035 Notebook
RCA HDTV model#HD52W59. When I turn the power on it stays on for a few seconds and then goes off by itself.
TV turns off unexpectedly
• Sleep timer may have been activated.
• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then turn on again. If this
happens frequently, the voltage in your house may be abnormally high or low.
• Unplug the TV. Wait ten minutes. Then, plug the TV in again.
Jan 05, 2009 | Televison & Video
Printer turns off unexpectedly after few minutes then back on?
defective main printer board. needs replacing. if machine is still in warranty call brother. otherwise get rid of it because spare part is very expensive.
May 04, 2008 | Brother MFC-5840CN All-In-One InkJet...
Televison & Video Logo
116 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
