Question about Minolta magicolor 2400W Laser Printer
Magicolor 2400W toner cartridges not empty
We have had this printer for about two years and have had to change the color cartridges 4 times. We do very little color printing, when I pull out the cartridges they have plenty of toner left, they are clear full cause I opened one to look inside. But the printer will not print anything untill I put in a brand new one. Is there any way to trick the printer into thinking the old ones are new? Kind of a dumb question, but this printer is costing alot of money to keep running. I try to go into the Status Display but when I click on it the screen just goes blank it doesn't bring up anything. I was hoping I could change the state of the" toner empty mode" But I can't even get into that part.? Any suggestions?
  • 99 Answers
Have you tried taking the toner cartridge out of the printer and shaking it up a bit? Just make sure you do it outside or over a trash can. Shake it side to side.
Sometimes the toner bunches up and you can get some more life out of it by shaking it up.
Hope this helps
Thanks
Posted on Mar 24, 2008
3 Suggested Answers
  • 118 Answers
SOURCE: error
The only way to reset the toner error is to replace the counter chip on the toner cartridge. These should go for about $10 a piece. Otherwise, you can set the engine to continue on error, and ignore the blinking light. Better yet, I put a piece of electrical tape over it. You can still read the status on the LED's, but not have your wife complain about it. Saves you $40.
Posted on Jan 03, 2009
SOURCE: will the magicolor 2400w stop if one toner
Removed each toner cartridge, shake it and replace it.
I don't know if this is the real fix but it worked for me at this time..
Posted on Sep 04, 2009
How do you clean the drum on a Minolta magicolor 2400W Laser Printer?
HI, I think you would be wise not to clean the drum, other than removing the toner dust. If you have problems with print quality, firstly check each cartridge in turn and see if the rubber toner roller is smoothly covered in the appropriate colour toner. If all is OK here, then empty the dust container. The dust container is in the back side of the the transfer band (drum), on the right hand side you will find an area where there is tape applied. Remove the tape to reveal the hole into the dust collector. Take care as there is usually a great deal of old toner in there, so it is a good idea to have a container at hand when you empty it. hen you have emptied it, you must of course reseal the hole. I have found the best sealer for this is the self adhesive alluminium tape which one can buy in any hardware shop.
Hopefully therafter all wil be OK.
Oct 20, 2010 | Minolta magicolor 2400W Laser Printer
Minolta 2400W errors
GO and get 4 Konicminolta image units one for each color and replace them do not use third party. NEVER ever use a vacuum cleaner the static electricity can cause sensors to go bad !!!!!!!!!!!! might have destroyed the chips on the image units SO recommend get all new hopefully you did not destroy the control board with static electricity
Apr 27, 2010 | Minolta magicolor 2400W Laser Printer
How to deactivate toner colour errors?
if any toner ends in a printer, then replace it.otherwise error will show continuously.
Apr 22, 2010 | Konica Minolta magicolor 2400 Laser...
The ERROR light of my Minolta magicolor 2400W Laser Printer stays on. I have inserted a new drum and all the cartridges are full. What do I do?
Try to open the blue cover and close it. Then press a few times the "rotate toner" button. After that powerswitch off and on, should run.
If it´s don´t worked, make sure you have every transport secure away from the cartridges.
The contact`s should be clean in Printer and on cartridges.
If still the same prob, start from first tip.
It´s worked by my 2400W feed new toner.
Nov 25, 2009 | Minolta magicolor 2400W Laser Printer
Will the magicolor 2400w stop if one toner cartridge is empty . If yes can it be bypassed??
Sep 03, 2009 | Konica Minolta magicolor 2400 Laser...
Magicolor 2400W error
This happens to me every few months, I have to do a VERY detailed cleaning of all toner sensors. The knowledgebase on KM's website is actually very good about walking you through which sensors to clean and pictures indicating where they are located. This has fixed me up every time. GOOD LUCK!
Jan 19, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Konica Minolta Magicolor 2400W drum cartrige-how to replace?
Did you buy a whole new drum unit, or just change the cartridge? If so, the fuse may still be blown. Also, you may need to empty the spent toner out of the old cartridge.
Oct 07, 2008 | Konica Minolta magicolor 2400 Laser...
Change k toner error message
If you want to use the toner cartridge after the printer decides that it's empty, you can do it by going into the Machine Settings in the menu, and option 8 (at least on my Magicolor 2590MF) says "Toner empty stop?". Just change that to NO, and you're set to go.
May 27, 2008 | Konica Minolta magicolor 2490MF Laser...
Rotate Toner Button Does not Work
How do you change four toner cartridges-Minolta 2400w Printer?
May 20, 2008 | Minolta magicolor 2400W Laser Printer
Rotate Toner Button and Replace Cartridge Messages
Hello
take out all toners and pc drum, use pressure air to clean chip reader under the toner rack (right side) also use some alcohol to clean chips on toners and reinstall.
Minolta magicolor 2400W Laser Printer Logo
96 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
