Question about HP OfficeJet V40 All-In-One InkJet Printer
Hp v40 error code keeps showing " remove and check color cartrige" even I change a new one. If you know the solution, please give me advice. Many thanks!!!
After many many tries - I finally cleaned the "new" cartridge and sellotaped a piece of paper over the contact face (making sure the tape stopped before that surface) I then flooded the paper with pure alcohol and re-inserted into position several times. This obviously did a deeper cleaning job than the cotton bud method I have seen. The v40 is quite old so I guess there's no harm in trying just about anything..... There will be reduced cost in throwing it away..
Posted on Aug 03, 2010
Hp officejet v40 printer/fax keeps giving us the error message remove and check color cartridge......I have done all the removing and checking that I know how....any further suggestions?
There may be a problem with the ink cartridge itself or the printer may have overheated. That particular model of printer uses drop-on-demand thermal inkjet to put the ink on the paper. This technique works by heating the cartridge to form an air bubble in the cartridge which pushes the ink out onto the paper. A common problem for this type of technique is overheating because of the heat required to form the air bubble. If that is not the problem, then I would suggest getting a new cartridge and seeing if the problem persists.
May 02, 2011 | Office Equipment & Supplies
7310 All In One - running windows 7 64k OS problem: error blinking msg: error remove and check color cartridge. This is a fairly new cartridge, I have removed color cartridge rubbed it on a damp cloth -...
you need to change it, maybe you damaged it while trying to get it working. the clearly shows a faulty cartridge remember it can be faulty even as new or from the box
Oct 27, 2010 | HP OfficeJet 7310 All-In-One InkJet...
I have a Hp photoshop 3210 printer ink cartrage error empty or
I installed new cartriges, but my printer keeps giving me an error msg, Ink system has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error: Oxc18a0206. What do I do now?
Nov 06, 2009 | HP Photosmart 3210 Printer
Replaced color cartrige twice and says to check color cart..
We have a reset procedure on our web site at:
www.ccl-la.com/hp.htm The problem is cause by air in the ink feed tubes, the reset procedure will purge the lines and clear the error.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair
Jul 17, 2009 | HP OfficeJet 7310 All-In-One InkJet...
"Remove and Check Color Cartridge" won't go away w/ new cartridge
Replaced with brand new HP cartridges. If either one (black or color) is a refilled cartridge, my machine has issues.
Dec 13, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
I just installed a new black ink. The error message keeps on saying wrong color cartridge installed. I replaced with the correct one for my officejet v40. Black 15.
did you try changing the color cartridge too? I had problems with ink cartridges that were not HP cartridges.( not made by HP but some other co.)
Dec 05, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
450c color problem
The 430 ID is B/W, you need to load the 450C driver to get color, renaming the driver isn't enough.
Oct 13, 2008 | HP DesignJet 450c InkJet Printer
Printer Issues
my hp psc 2210 after putting in new cartridge keeps saying press enter to align cartridge. it keeps repeating the same reading.
Apr 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP OfficeJet V40 All-In-One InkJet Printer Logo
104 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
