Question about E-Machines T1855 PC Desktop
My t1855 power supply is not working. - E-Machines T1855 PC Desktop
    Problem Solver:
  • 13 Answers
Explain not working??? not plugged in , no fan , black screen , blue screen.. ?? If it is just the power supply their is a fuse that may or may not be able to replace inside it .. but been my experience if their appears to be no power the power supply/motherboard may be more likely the fault.. i have eperienced mobo burn up processors and powersupply's.. if u have a blue screen then it could b hardware thats out , virus in the bios possible but not likely, remove any cards u have added an disconnect all but bare minimum then systematically re install each an boot each time until u find the culpit.. if all else try the simple an obvious first..
Posted on Apr 29, 2010
Computer won't turn on.
There must be a problem with your power switch on your computer casing, or motherboard or power supply.
Detach your power supply and try this, to check if your power supply really works. If the auxiliary fan will turn, your power supply is good
25627818-lfqggqo5gl3n2v4xynrvsb5u-5-0.jpg Testing your power supply and motherboard as seen on photo
25627818-lfqggqo5gl3n2v4xynrvsb5u-5-2.jpg If the cpu cooling fan and power supply did not turn the fan, but you have checked already the power supply that is working then you can conclude that your motherboard is need to be replace. But the power supply and motherboard and working, meaning to say your computer casing need to be replace or try fixing the contact of the switches attach to your casing.
Have a good day.
Apr 04, 2015 | Dell Studio Xps 9100 Desktop Computer
No operating system found
it mean your operating system is corrupted or your hard disk is not detected with machine
for operating system re install your operating system and if you face any trouble to installing operating system like hard disk not found or no drive.
so go to setup and check that if there showing any hard drive.
absoultly not so plug your data cable and power cable properly on your hard disk and re check now if problem is not solve yet. so now pull out your hard disk from pc and plug the both wire of power and data and now check that your hard disk is running making some noise you can feel that its running if not so replace your hard disk card and now plug it on pc it will running now and install your operating system . you can operate your pc with your old data. thanks
Jul 16, 2011 | E-Machines T1855 PC Desktop
Ac adapter is red, what should i do?
This problem occurs when the power supply detects a problem. The power supply has several built-in safeguards to help prevent damage to either the console or to the power supply. The power supply will turn off if:
  • There is too much current.
  • The voltage is too high.
  • The temperature of the power supply is too high.
When any of these things happen, the light on the power turns red.
Solution 1: Make sure that the power supply is cool loadTOCNode(2, 'whattotry'); The red light might indicate that the power supply is too hot or that it has overheated. Follow these steps if the power supply light is red:
  1. Turn the console off.
  2. Disconnect your Xbox 360 Power Supply from your Xbox 360 console and from the wall outlet.
  3. Let the power supply cool for two hours in a well-ventilated space. Do not connect the Xbox 360 power supply to the console or to the wall outlet during this time.
  4. After the power supply has cooled for two hours, reconnect the power supply to the console and to the wall outlet, and then turn the console on.
If the power supply light is still red, try the next solution.
Solution 2: Make sure that the power supply is plugged in loadTOCNode(2, 'whattotry'); Make sure that the power supply is directly plugged into a working wall outlet. Problems might occur with the power supply if it is connected through an extension cord or surge protector.
If the power supply light is still red after you connect the power supply directly to a working all outlet, try the next solution.
Solution 3: Plug the power supply into a different wall outlet loadTOCNode(2, 'whattotry'); To check the possibility that the wall outlet you are using is faulty or that there is a blown fuse, plug the power cord into a wall outlet that you know is working.
If this does not solve the problem, try the next solution.
Solution 4: Order a replacement Xbox 360 power supply loadTOCNode(2, 'whattotry'); If you've tried all the solutions above and your power supply light is still red, you should contact Xbox Support to order a replacement power supply.
To help the power supply work correctly, follow these guidelines:
  • Do not block any ventilation openings in the power supply.
  • Do not put the power supply on a bed, a sofa, or on any other soft surface that might block ventilation openings.
  • Do not put the power supply in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
  • Do not put the power supply on a stereo speaker, an amplifier, or a heat source such as a radiator or a heat register.
  • Do not use an unlicensed accessory, such as a third-party power supply or any accessory that plugs in between the Xbox 360 console and the power supply.
  • Plug the power supply directly into a working wall outlet. The power supply might not work correctly if it is connected to an extension cord or surge protector.
hope this helps.
Apr 10, 2011 | Microsoft Xbox 360 Console
The ac adapter red light stays on and the counsole will not work
This problem occurs when the external power supply has detected a fault. The power supply has several built-in safeguards to help prevent damage to either the console or to the power supply. The power supply will turn off if one of the following conditions is true:
When any of these conditions are true, the light on the power supply turns red. Here are some steps that you can use to try to fix the problem.
Step 1: Make sure that the power supply is cool
1. Make sure that your Xbox 360 console is turned off.
4. After the power supply has cooled for two hours, reconnect the Xbox 360 Power Supply to the console and to the wall outlet.
If cooling the power supply does not resolve the problem or if the problem persists, use the steps in the next section.
Step 2: Make sure that the power supply is plugged in correctly
Make sure that the power supply is directly plugged into a working wall outlet. You may have problems with the power supply if you use an extension cord or a power strip if the extension cord or the power strip is faulty or cannot supply the required power to the console.
If the power supply is still not working as expected, use the steps in the next section.
Step 3: Plug the power supply into a different wall outlet
To eliminate the possibility that the wall outlet you are using is faulty or that there is a blown fuse, plug the power cord into a different wall outlet in a different area of your place of residence.
If this does not resolve the problem, use the steps in the next section.
Step 4: Try another Xbox 360 Power Cord and Xbox 360 Power Supply
If you have a different Xbox 360 Power Cord and Xbox 360 Power Supply, try to use them to test the console. If the console turns on when you use a different power cord and power supply, you need to replace the faulty power cord and power supply. If the console does not turn on, the issue may be with the console itself.
Step 5: Obtain a replacement Xbox 360 Power Supply
If the steps in this article did not resolve the issue and the Xbox 360 Power Supply light continues illuminate red, you need to obtain a replacement power supply.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 18, 2010 | Microsoft Xbox 360 Console
My powerbrick light is red all the time,does it mean i need a new one
it could and maybe not first diagnose the problem with what i oultine below. To see if anything fits into the category of your problem. Then try to hook up the power brick to another outlet in another room. If it does it there you can narrow down the cause of the problem.
THE CAUSE This problem occurs when the power supply detects a problem. The power supply has several built-in safeguards to help prevent damage to either the console or to the power supply. The power supply will turn off if: There is too much current. The voltage is too high. The temperature of the power supply is too high. When any of these things happen, the light on the power turns red. THINGS TO TRY Here are some things you can do to try and fix the problem.
Solution 1: Make sure that the power supply is cool The red light might indicate that the power supply is too hot or that it has overheated. Follow these steps if the power supply light is red: Turn the console off. Disconnect your Xbox 360 Power Supply from your Xbox 360 console and from the wall outlet.
Let the power supply cool for two hours in a well-ventilated space. Do not connect the Xbox 360 power supply to the console or to the wall outlet during this time. After the power supply has cooled for two hours, reconnect the power supply to the console and to the wall outlet, and then turn the console on. If the power supply light is still red, try the next solution. Solution 2: Make sure that the power supply is plugged in Make sure that the power supply is directly plugged into a working wall outlet. Problems might occur with the power supply if it is connected through an extension cord or surge protector.
If the power supply light is still red after you connect the power supply directly to a working all outlet, try the next solution. Solution 3: Plug the power supply into a different wall outlet To check the possibility that the wall outlet you are using is faulty or that there is a blown fuse, plug the power cord into a wall outlet that you know is working.
If this does not solve the problem, try the next solution. Solution 4: Order a replacement Xbox 360 power supply If you've tried all the solutions above and your power supply light is still red, you should contact Xbox Support to order a replacement power supply.
MORE INFORMATION To help the power supply work correctly, follow these guidelines: Do not block any ventilation openings in the power supply. Do not put the power supply on a bed, a sofa, or on any other soft surface that might block ventilation openings. Do not put the power supply in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated. Do not put the power supply on a stereo speaker, an amplifier, or a heat source such as a radiator or a heat register. Do not use an unlicensed accessory, such as a third-party power supply or any accessory that plugs in between the Xbox 360 console and the power supply. Plug the power supply directly into a working wall outlet. The power supply might not work correctly if it is connected to an extension cord or surge protector
if you need an explanation or further assistance please let me know. I will be glad to help, Thanks -Midwest-tek
Aug 27, 2010 | Microsoft Xbox 360 Console
How to repair power supply? it's not work. how to
I recommend you do not try to repair the switch mode power supply, Mains voltage equipment are dangerous if you do not know what you are doing.
Switch mode power supplies are not expensive to purchase, I suggest you purchase a new ATX switch mode power supply. There may not be many 120 watt available, but higher wattage power supply are more common, the mounting holes are standard.units
Aug 16, 2010 | Compaq (176763001) 120-Watt Power Supply
I purchased a Sparkle SPI270LE power supply as a replacement for a 160W power supply in my HP Pavilion s3220n PC. On installation, the unit would not power up. All connections were hooked up correctly. I...
These power supplies can be tough to test without a bonifide genuine load tester made for these power supplies. Switching power supplies seem to need a load in order to operate. If you have everything plugged in including your hard drives and it still doesnt work then it is likely defective. I have a apparently good power supply that decided to do the same thing to me in a working machine. I swapped out the power supply and it worked again.
Sometimes new power supplies can be no good. Switching power supplies can be somewhat fragile. The newer the power supply the more fragile they seem these days.
Mar 14, 2010 | Computers & Internet
Unknown power supply
I think any up to date psu will work they are pretty much all the same except fo the really small pc's I would get a 400 watt one for your machine.
Aug 10, 2009 | Work Station 250W ATX POWER SUPPLY (=...
Computer does not turn on
you can try your power supply if it works by jumpering its pin. try to insert copper wire in pin 11 and connect it to pin 12. and turn o your power supply. But if it won't works then used tester and test its circuit boards particularly  is capacitors, resistors and even the transformer inside the power supply. Or if you can't make it then you can call a technician either in computer or electrical to test your power supply if it still working or not. In that wy can be sure in making decision if its really your power supply got problem or not.
Thanks
Jun 26, 2009 | Lite On (PA41519B1) 150-Watt Power Supply
Power supply not working
Hello my friend, if one of your power supply's part is burned, your power supply won't work else if its work i has a short time to operate and it will be burned the whole board of your supply. Mainly the reason of burning your supply are the following: 1. The Electric supply  from the source is to high or above the limitation of your Power supply. 2. Your power supply is over capacity. 3. You're power supply board develop a liquid moisture inside that is why it shorted and eventually the board is burned.  4. The load of your power supply is overload due to some device you attach that is beyond to the limit of your power supply's wattage capacity.
Note: try to see the wattage or voltage or the capacity of your power supply can supply the electricity within your computer system. To ensure that it does not exceed the limit of your power supply's limitation.  I therefore reccomend that to avoid burning the entire power supply board from short circuit, it is recommended to replace your power supply to avoid incidents may arise.
Hope this advice helps your problem. If you need more assistance just reply to this post.  If this solution or recommendation is able to solve or help your problem then please rate it.  Thanks
Jun 25, 2009 | Office Equipment & Supplies
E-Machines T1855 PC Desktop Logo
16 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
