Question about LG Washing Machines
Our washing machine is not empting or using any of the detergent when it washes
  • 33 Answers
You have something in the pump most of the time I find small socks or thongs in them sometimes I find pennys or other small things easy fix if you lift the lid and take it out yourself the pump is on the back bottom right side use putty knife on the front to pop springs to lift the lid
Posted on Apr 29, 2010
Lavamac front loading 28kg commercial washing machine(coin operated). When I press "cold" wash, why is the warm water coming out?
Your washing machine has to release some warm water even when liquid detergent is used. The purpose of the brief release of warm water is to dissolve powdered detergent and/or flush liquid detergent residue.
Jul 19, 2017 | Washing Machines
My washer wont rinse or spin and when its finished washing it gets to rinse cycle and beeps and error code e4 comes up i emptied clothes and it still wont work
No make or model came through with your question... so the FIRST GUESS... is ... THIS IS A NEW RELATIONSHIP with a "HE" (HIGH EFFIEIENCY) washing machine.
You can CONTAMINATE your machine quite badly by not using THE RECOMMENDED "HE" rated detergents... & CLEANERS.
These new machines will rapidly deteriorate in performance... if the APPROPRIATE (HE) detergents ARE NOT USED.
Sensors sample the detergent/dirt in the water to enable the wash cycle to adjust wash time & water levels...
By NOT FOLLOWING the INSTRUCTIONS you are risking PERMANANT DAMAGE to these sensors...
Read your OWNERS MANUAL... There-in (I believe you will find
HE cleaners (not cheap) are recommended to ATTEMPT to restore performance...
Else you are looking at an EXPENSIVE SERVICE CALL on a NEW MACHINE.. Who knows... MAYBE it will be covered under your WARRANTY... Stranger things have happened (these days).
Good luck with that.
affresh WASHER CLEANER 3 Tablet Odor Remover Clean ANY Washing Machine...
Amazon co uk washing machine cleaner
Jul 16, 2016 | Washing Machines
How do you fix too much soap in washing machine?
You are using the wrong detergent for your wash. You probably have a "e" type machine and you probably are using the regular detergent. Some machine are not using too much waster so they have to use special detergent for those machine.Look for the "e" next time you buy .
Mar 25, 2012 | Bosch Nexxt 300 Series WFMC2201UC
Not empting or spinning
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 02, 2011 | Whirlpool Washing Machines
When my washing machine is on the wash cycle and it is using the detergent... water and soap suds pour out of the detergent dispenser and run down the front of the washing machine, why? I use proper front...
There is an article of clothing stuck inside the dispenser housing. Remove the top and the housing to get to the hose and clean it out. Very common issue, I know this unit very well.
Apr 22, 2011 | Washing Machines
The problem with my top loder panasonic washing machine is clothes dont come out clean.the liquid detergevt that i use does not always dissolve during wash and asa result clothes stiil soapyz.there are...
If you have the user's manual for this machine, check to see that you are using the recommended detergent and the correct quantity of detergent. Some machines will actually fail mechanically from using the wrong type of detergent (such as using standard detergent in a high-efdficiency washer). The pH (softness/hardness) of your water also determines how thoroughly the detergent dissolves and rinses from clothes.
Panasonic (
Q2. Why are there black stains on clothes after washing?
A2.May be your washing machine is dirty due to the residual accumulated through times and need to be overhauled. The possibility is that, a build up caused by interaction of fabric softener and detergent which can flake off from washing machine tub and stains the clothes. Try to dilute and dissolve the softener before putting it into the machine to reduce such black stains.
Spotting can also be a reaction between detergent and fabric softener, a leaking washing machine transmission, or excessive deposits of detergent or fabric softener in the tub flaking off during the wash cycle.
Good luck from Detroit, MI, USA.
Mar 01, 2011 | Washing Machines
Reading" de" i tried pulling
its the door open error. its the door not all the way closed you can go to appliancerepairplanet.vstore.ca but thats the problem.
Dec 15, 2010 | LG Washing Machines
My washing machin is not empting the whole water from the washer.
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 03, 2010 | Washing Machines
Washing Machines Logo
21 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
