Question about Acer Aspire One Netbook 8.9" Notebook
Acer can't connect to wireless network
Hi, I just got a new Acer netbook, but i'm having trouble connecting to the internet. The netbook picks up the network but just won't connect even when i enter the appropriate security codes.
    President:
  • 2,049 Answers
Given the Acer sees the network, the times I have been frustrated connecting a new computer to a wireless network, it's usually been something very simple. I have forgotten one setting, transposed a letter or number. Go back through and make sure everything is exactly right.
Posted on Apr 29, 2010
I recently replaced my old Belkin N150 Wireless Router with a new Cisco E3200 Wireless Router. After doing so, all of my wireless devices work (9 total) EXCEPT for my (2) Acer Aspire One Netbooks. The...
Remove and recreate the wireless network connection
  1. Click on Start, and then Control Panel
  2. Double click on Network Connections
  3. Right-click the wireless network connection, and click Properties
  4. Click the Wireless Networks tab
  5. Under Preferred networks, click the wireless network, and then click Remove
  6. Click View Wireless Networks
  7. Under Network Tasks, click Refresh Network List
  8. Under Choose a wireless network, click the wireless network that you want to connect to, and then click Connect
In Windows, there is a power mode setting for the wireless driver that may help this issue. Follow the instructions below.
  1. Go to Control Panel, System, click the Hardware tab and select Device Manager.
  2. Click the + next to Network Adapters and double click on the wireless network adapter.
  3. Click on the Advanced tab, select Power Save Mode from the list on the left.
  4. Change the Value on the right to Off.
    The default setting is Maximum, which may cause issues similar to those described.
Check to see if this has resolved the connectivity issue. If it has not, the following steps may need to be completed.
  1. Click on Start, Settings, Control Panel
  2. Double click Network Connections
  3. Right-click your wireless network connection, and click Properties
  5. Under Preferred networks, click the wireless network, and click Properties
  6. Click the Authentication tab, click to clear the "Enable IEEE 802.1X authentication for this network" check box, and then click OK twice.
Sep 23, 2011 | Acer Aspire 5100 Notebook
I bought 2 Acer Aspire one netbooks and I can't get either one to connect to wi-fi. They show strong connectivity to the wireless network, but no internet?
you are seeing it strongly connected to the ROUTER---try unplugging the router for a few minutes and plug it back in----Does the netbook "SEE" the network? entered correct ssid? Is the wireless switch enabled on the netbook?
Dec 24, 2010 | Acer Aspire One Netbook
Unable to connect Acer One D250 netbook to 2wire modem. Limited or no connectivity. I can connect through wireless at work and hardwire.Comments: Dec 30, 2009- Netbook sees the network, has excellent...
Replace the Cable and Check.
If the problem still persists then
Give the same network setting to the wireless network adapter as you assigned to your local area connection.
Note: Before doing that remove the IP address of that Local area connection or change it's IP address to some other number.
This will most probably solve your problem.
Otherwise, Used an external USB Wireless Adapter.
Jan 01, 2010 | Acer Aspire One PC Notebook
Acer Aspire One Netbook wireless internet connectivity problem
Try Resetting Your Wireless Router.. turn it off then back on
then run a repair on your wireless network
Nov 15, 2009 | Acer Aspire One AOA110-1113 Netbook
Cannot connect acer aspire one to my tp-link router
go start run type services.msc then go down to the bottom click zero wireless configuration then click start and you should be good to go
Jul 14, 2009 | Acer Aspire One A150-1672 Notebook
ACER 5720 WIRELESS CONNECTION PROBLEMS
Are you using security?
If you are try changing between wep, and wpa
If that still does not work use mac filtering
May 27, 2009 | Acer Aspire 5100 Notebook
Acer Netbook is "Connected" but can't use internet
You first need to establish that you have internet available to your router via cable modem, dsl, etc. Unless your modem is also your wireless router. Take your ethernet connection or cable that resembles a large phone cable and plug in your Acer One directly into the router. You should then be able to get internet. If not, you may have a problem with your internet in general and need to contact your Internet Service Provider. Also if possible try another pc, see if it has internet. Lastly try reinstalling wireless diver in device manager.
Mar 10, 2009 | Acer Aspire One Netbook 8.9" Notebook
Setting up wireless internet connection , my new acer laptop
hi there i have a problem connecting my new acer laptop to the internet..I've tried your suggestion but i can't still connect to the internet..can u help me to connect my new laptop to the internet? is there a program or a disk for me to open the internet connection of my laptop...thanks a lot and i hope u will help me
Jul 11, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
331 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
