Question about Timex T46821 Wrist Watch
I have the casio Pathfinder (1376) open
I have the casio Pathfinder (1376) and when I replace the batter it says open, I have tried touching the AC and positive and it returns to date briefly and then back to open, I've tried this several times, along with removing the cover and screwing it back in many many times. What do I do??
    Problem Solver:
  • 6 Answers
I know the secret behind CASIO's "OPEN" problem.  This is not a joke.  You'll be happy to get your watch working again.  Because the procedure is too long to fit in here, send me an e-mail at s.duteau@videotron.ca and I'll send you the solution.  This is no scam.
Posted on Oct 06, 2010
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
    Thank you for contacting FixYa.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    I replaced all four batteries and i still have nothing .inside the watch it says to jumper the A C point with a twizers. what is the AC point and where.this s a casio 2271 2years old had factory batteries...
    Casio battery changes are quite tricky.If you look closely at the watch module there is a place for the battery and a v-small depression usually circular on the silver module .There will be the letters AC in small writing.You need to touch the depression AC and the battery at the same time with a conductive tweezers.This shorts the module and re sets the watch.Make sure any seals go back in to protect from water/dust.
    Regards
    Aug 13, 2010 | Casio PRG-40T-7 Pathfinder
    Where is the ac contact button?
    You can get instructions from the Casio web site.
    Go to the casio web site "casio.com".
    Select "support" and the "manuals", watches;
    Accept terms
    Select "watch manual archive"
    Read the number of the back of your watch and enter it into the search box
    Mar 16, 2010 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
    I need to replace my battery and get my band fixed but i dont know how
    Take it to a jeweler who sells Casion watches and ask them to replace the batter and the fix your band.
    Jan 12, 2010 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
    After battery replacement of casio sea-pathfinder
    If it has "AC" written on the module you may need to short between the AC point and + battery. Also check voltage of battery. It may just be too flat.
    Jul 25, 2009 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
    Battery Replacement
    Do not lay the tweezers across any contacts as you may damage the watch.
    First you need to examine your watch movement and find an AC point (contact). It is embedded on movement. Use an eyeglass, as the writings can be very tiny.
    When found, touch an AC point with one arm of tweezers and battery+ with another arm simultaneously.
    Some watches needs to do that twice, so, to be sure, do that twice.
    If you are not comfortable with tweezers, you can use a thin wire, connecting one end of the wire to AC point and another to battery+.
    Each shortcut should last for 3 seconds.
    Do not forget to rate, please.
    Jan 27, 2009 | Casio Triple Sensor Pathfinder PRG60-1AV...
    Replaced battery and it says OPEN
    I know the secret that CASIO is hiding behind this thing. If your watch shows "OPEN" then you don't have to go to a CASIO retail store. You don't have to send your watch with money to CASIO or go to an Authorized CASIO Service Center. I know how. Just send me an e-mail to s.duteau@videotron.ca and believe me you'll be happy to know the "SECRET" an get rid of this annoying "OPEN" over with. You want this fix! Than don't wait.
    Oct 27, 2008 | Timex T46821 Wrist Watch
    CASIO SPF40 battery replacement
    "AC" means All Clear. This terminal should be marked somehow. Use a magnifying glass to get a good look at what you are working on. My Casio had an arrow pointing to four copper leads. I used a paper clip to connect the AC terminal (I just picked one of the four) to the + side (usually the "up" side) for a couple seconds and my Casio Sea Pathfinder model 2273 powered right up. See the following link for more guidance.
    http://www.geocities.com/watch_crazy/battery/battery.htm
    Feb 24, 2008 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
    Timex T46821 Wrist Watch Logo
    1,227 people viewed this question
    Top Timex Watches Experts
    Ansel Alberto
    Ansel Alberto
    Brett Duxbury
    Brett Duxbury
    Vladimir Frolov
    Are you a Timex Watch Expert? Answer questions, earn points and help others
