Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Trying to wash a load of clothes and it is saying lid
  • 1,998 Answers
This means you have to replace the lid switch on a top loader its a very easy repair usually the part goes for around 25-50 depending where you buy it from
Posted on Apr 29, 2010
Rusting lid on top-loading Kenmore Washing Machine
that is very possible.the best thing to do is replace the lid or sand all the rust off and you some rust inhibitive paint to helpslow or stop the rusting proccess.
Jan 23, 2010 | Kenmore 24032\24036 Top Load Washer
Clothes look drab after washing them.
Is the machine new or old? How long has this been a problem? Has this been occuring slowly or has it started suddenly? Before you give blame to the machine, I suggest you wash your clothes at a laundromat or a friend/relative washing machine to see the results you get. Also, the detergent could be partially at fault especially if you use too little or too much (too much will cause a film to build-up on the clothes that cannot be washed away enough durung rinse). IF AFTER TRYING THESE SUGGESTIONS YOU STILL HAVE THE PROBLEM, open the lid while your Maytag is washing to see if the water level is sufficient and to see if the aggitator is moving; note- you may have to open quickly and check very fast to see if there is aggitation movement because some models stop the washing if you open lid (all models stop the rinse/spin action if you open lid.Goodluck, Macgivor
Nov 09, 2009 | Maytag HAV2557 Top Load Washer
Washing machine will not spin clothes
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
If you have any questions, please let me know. I hope this helps you.
Jul 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Calypso stops at 26 minutes and throws ob code
first you need to clean your washer
run the washer with no clothes; add 1 cup vinegar, that will cut the soap residue from the hoses do this on hot wash hot rinse
then when you wash your next load of clothes; fill the tub about 1/4 full, add the soap, turn the agitator to disolve the soap, then add the clothes
this problem happens also if you are using too much soap or a heavy duty soap such as Tide.
May 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer stopped after wash cycle
The lid switch is the culprit. Push down on the lid it should start. It needs to be adjusted . the tab on the lid is not activating the switch. Try triming the door bumpers.
Apr 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Smeared clothes
Hi!
You can look at this as to how lint/whitening from your clothes can be removed---
This is due to un-dissolved soap and is worst in a colder climate where the cold water entering the washer is much colder than normal.
Cutting usage to 1/2 of what it says will still wash good and also cut your chances of getting "whiting" on your clothes.
Over loading the washer is another cause: Even if the agitator is suppose to go back and forth, the clothes are not. If you can hold the lid button on your washer so you can watch the clothes wash, they should 'roll" in the basket and not go back and forth like the agitator. The clothes will go down the side of the agitator, across the bottom of the basket, up the side of the basket and across the top of the water in a rolling motion. Overloading is not just too many clothes but also too little water for the size of the load is another way of having a overloaded wash load.
Water temp is also important: Use a thermometer to test the temp of the incoming water in your washer. Hot water should be close to 140 degrees F.
Feb 09, 2009 | Roper RAX4233PQ Top Load Washer
Whirlpool Ultimate Care II washer will not spin...
I would say you have a burnt out clutch. did you over load it with a quilt or comforter?
Time to consider a new washing machine, unless its under warranty I would recommend replacing the washer vs. fixing it.
Whirlpool doesnt build them like they use to!
Jul 11, 2008 | Kenmore 22422 Top Load Washer
Washer stopped
Sounds like might be the lid switch... these washers are  well know for lid switch problems,
Sep 21, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
82 people viewed this question
Dan Webster
Dan Webster
Sal De
