Question about Kenmore Dishwashers
How do you determine if the thermal fuse is bad the washer filled up and then totally stopped and is not working at all not even turning on
    President:
  • 949 Answers
If you have power to the dishwasher (breaker is okay and outlet are good) then the most likely suspect is the thermal fuse. You will need to open the console by removing the top screws and the next screws down from the inside door panel. With the console open, you will have to remove the black cover on the right side by prying up gently on the tab on left of it. This will expose the circuit board, the thermal fuse is located on the top of the board in a little bracket, it has two wires going to it. You can take the fuse off and test it with an ohm meter. An appliance parts retailer should have an ohmmeter if you do not.
Let me know if you have further questions.
Phil
Posted on May 01, 2010
POWER IS ON--LIGHT ON, BUT DOES NOT HEAT UP
Check to see if the heating element has continuity or if it is even receiving power.
Mar 05, 2016 | DeLonghi TRD0715T Oil Filled Radiator...
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
No lights on, didnt complete the drain cycle, stopped working now
There is a thermal fuse located in the control panel inside the door. It could be blown, but if so what caused it. they come with a retrofit pigtail to prevent loose connectins on the fuse. You may have a short somewhere in the dryer, and just blow the fuse again. Could be bad motor,fill valve, or heater, or even the control board. I'd try one fuse first.
Jul 26, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
My lakewood oil filled heater model 5600/7 just stopped working. It won't turn on..no lights. There is no history of tipping over.
The reason that it stopped is an open circuit. It is probably a blown thermal fuse. However, it could be any of the following if that is not the problem:
bad switch, broken or disconnected wire, burned open heater element, bad connections between terminals and wires, or between wire connectors and the wires within them.
If you take it apart, you will find the heat sensitive thermal fuse device under the heating elements, near the bottom of the unit. If the thermal fuse is good, it will appear as a short to an ohmmeter (zero ohms). If it is failed, it will appear as an open (infinite ohms).
The thermal fuse device can be replaced. Here is where to get one:
http://www.goodmans.net/get_list_632_2.htm
The thermal fuse may be this one, but check the temperature indication on yours first: Item#: TH-TF167C
Good luck.
Apr 06, 2010 | Lakewood (5500) Oil Filled Radiator Heater
Have a roper ax6245 - cold water will not shut off even with washer turned off - HELP
Hello,Sounds like a problem with either the inlet valve or the pressure switch, the way to determine which is bad... while the machine is filling pull the power plug..if the water keeps filling it's the inlet valve that is going to be bad..if it stops filling it's going to be the pressure switch. The pressure switch is located in the control panel and has a small rubber pipe attached.once you have figured which it is replace it good luck.
If you have any other questions or concerns please feel free to comment again..Mike
Oct 14, 2009 | Roper RAX4233PQ Top Load Washer
Frigidaire Washer GLTF530DS0 motor doesn't run ohm test ok
could be a thermal fuse that has blown that protects the motor.Does your washer fill with water and set there? If so its probably your door or lid switch. There is a quick way to find out unhook door switch and connect wires together with electrical tape then try the washer. If it works replace the bad switch
Aug 24, 2009 | Frigidaire Washing Machines
Maytag LSE7806ACE dryer stopped working
pry the top up at the corners and remove attaching screws for the front panel and remove carefully. Now you should be able to see the canister that contains the heat element and the thermal fuse. If your thermal fuse is bad you also need to replace the high limit thermostat switch which is located on the canister itself and check that the heating element is not broken anywhere throughout the coil.
Apr 05, 2009 | Maytag LSE7806A Top Load Stacked...
Blowing high limit fuse
My dryer stopped working, using a multimeter I determined that the thermal fuse was open. I unclogged all the ducts then ordered a high limit thermal kit. After changing the fuse, it blew-up on the first cycle. It turns out that even though the high limit checked ok, it was defective. After changing both the fuse and the thermostat(included in the kit $25), the dryer worked correctly.
Feb 05, 2009 | Amana ALE230RAW Electric Dryer
Washer stopped working
Sounds like an electrical problem, but it can be in any of 3 (or 4, depending on the washer) totally different areas:
1 - The timer could be defective, not sending voltage to the motor.
2 - The motor could be defective.
3 - Something in the wiring (or a fuse or circuit breaker inside the washer) could be defective.
4 - If it's a computer-controlled washer, something in the computer could be defective.
Unless you're familiar (and comfortable) with working with live (110 volt) wiring, have and know how to use a test light or meter and have a schematic diagram of the washer (most of them have schematics on the inside of one of the panels) - and know how to do signal tracing, I'd leave it to a repairman. Electrocution, even if not fatal, can run up some huge medical bills (like from a shattered elbow, when you involuntarily pull back from the wire, and there's a wall stud in the way).
Aug 19, 2008 | Kenmore 22422 Top Load Washer
Washer constantly fills with hot water even when turned off.
Sounds like a bad mixing valve. To verify that it is the valve you need to turn off the washer when it is filling. If water keeps running, replace the valve, Cost is under $50. for most washers.
Jan 03, 2008 | Washing Machines
Dishwashers Logo
261 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
