Question about Dell Latitude C610 Notebook
Dell latitude 610 keyboard malfuction particularly letter b,n, left arrow, right arrow, down arrow and windows key. And it does not dispay tv out (s-video). Please Also help me in repacking its battery Thanx a lot..
  • 3,940 Answers
The keyboard fix is easy, replace the keyboard, same for the battery.
Manual is here
http://support.dell.com/support/edocs/systems/latc610/sm_en/index.htm
you can buy a keyboard here
http://cgi.ebay.com/New-Keyboard-Dell-Latitude-C510-C540-C600-C610-C640-/170342472542?cmd=ViewItem&pt=PCA_Mice_Trackballs&hash=item27a933db5e#ht_2468wt_1202
battery here
http://cgi.ebay.com/66WHR-Battery-Dell-Latitude-C500-510-C540-C600-C610-/280475115213?cmd=ViewItem&pt=Laptop_Batteries&hash=item414d9e9ecd#ht_2340wt_1734
S-Video on that model pretty much requires a direct S-Video to TV connection, then enable the TV in the Display properties. If you are trying to use an adapter, it will not work
Posted on Apr 30, 2010
My screen keeps going upside down and my keyboard types other characters
UPSIDE DOWN DISPLAY
An upside down image - this is caused by unintentional pressing Ctrl-Alt plus the down arrow key. Restore by pressing Ctrl-Alt plus the up arrow key. ALSO To change the display from portrait to landscape Press Ctrl-Alt plus a left or right arrow key. Some computers do not have this function.
Oct 06, 2012 | Dell Latitude D530 Notebook
Dell lattitude d620 won't factory restore ?
Please go through the below step, you can able to do it.
1) Shut down the Dell Latitude D620 if it's currently powered on. Click "Start" in the left-hand corner of the screen to access Windows' shut down options. Alternatively, press and hold the Latitude's power button, located on the top edge of the laptop's keyboard.
2) Turn on the computer by pressing the laptop's power button.
3) Press and hold "F8" on the top of the laptop's keyboard immediately after turning the computer on. If the Windows logo appears on the screen, you're too late and must repeat Steps 1 through 3 again. If you pressed it in time, a list of text options will appear on the screen.
4) Use your keyboard's arrow keys to scroll down to "Repair Your Computer." Push the "Enter" key on your keyboard.
5) Choose a language from the next list and select "Next." If you've password-protected your laptop, you will be prompted to enter your user name and password at this time.
6) Press "Dell Factory Image Restore." A new window will appear. Click "Next" and select the option for reformatting the hard drive and restoring the factory condition of the laptop.
Dec 17, 2010 | Dell Latitude D620 Notebook
How do I adjust brightness on my Dell Latitude D6...
Look for a key labeled "Fn" (blue lettering) on the lower left side of the keyboard
Hold the "Fn" key and then use the Up/Down arrows to adjust brightness.
If that doesn't work, reboot your laptop and get into the BIOS. There is a screen for brightness. I don't recall how it is labeled, but it's one of the last pages as you cycle through the BIOS options.
May 20, 2010 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
My dell lattiude keyboard doesnt type correct letters type j and
Go into safe mode and see if the same things happens there, if it does then bring it back into normal windows and go into notepad.
move your fingers across all the keys from left to right on each row. If the keys still aren't typing right then the keyboard needs to be replaced.
Jun 29, 2009 | Dell Latitude D600 Notebook
Left & right arrow keys not working.
Try to connect an external keyboard, see if that one works. If it does, then the problem is most likely a loose ribbon cable from the internal keyboard to the motherboard (especially if you recently installed a new one) - also, while you are examining the cable, look for any tears, cuts, or kinks in the cable. Good luck!
May 10, 2009 | Dell Latitude CPI-D Notebook
Right arrow key writes n- bbb n- n- etc.
Run the 32-bit diagnostics test on your dell computer:
1. Shutdown the system
2. Press and hold "Fn" then turn it on (while holding "Fn")
3. The Pre-boot Self Assessment would run
4. Just follow the steps on the screen
5. When memory test is done just continue
6. Select "Test System" when prompted
7. It will boot to Dell Diagnostics
8. Choose Custom Test
9. Run the keyboard test and follow screen instructions.
10. If the test fails, replace the keyboard.
11. If it passes, reinstall Windows.
Nov 25, 2008 | Dell Latitude D600 Notebook
Remove the keyboard and reseat it. There are three screws to remove and it is very easy.
Nov 14, 2008 | Dell Latitude D820 Notebook
Upside down screen.
Press either Ctrl+Shift+DownKey
or it may be the UpKey. Try both :) one of them will get your screen back to normal
Aug 14, 2008 | Dell Latitude C640 Notebook
Arrow key problem
if its a sensor problem under the keyboard, gently blowing under the key or hoovering the keyboard may bring results, but it may just be the driver, so go to my comuter icon, right click, properties, the hardware tab, device manager and go down the list to keyboard, click the '+' sign to reveal your keyboard make, right click on it and select uninstal. Restart the notebook and the keyboard will be recognised again and the driver automatically installed. If none of that works your problem may be more serious in the way of a faulty circuit under the board
Aug 22, 2007 | Dell Latitude D820 Notebook
Dell Latitude C610 Notebook Logo
362 people viewed this question
Alun Cox
