Question about Dewalt DW744S 10" Portable Table Saw with Stand
I have a DW744. It was working fine when I shut
I have a DW744. It was working fine when I shut it off. Then when I flipped the switch back on nothing happened. I used a volt meter and traced the power all the way to the motor. What is my next step?
I have a intermatic T104m pool timer. The clock works but it doesn't shut off. I have to flip the breaker to shut it down. The manual override switch flips back and forth but nothing happens. ...
If you are flipping it off manually and it still won't shut off then the contacts are burnt together internally.
This means that you need to change this timer out....
If you switch it with the same timer you will not need to change the whole box... the old board will snap out and the new board will just snap in the old box, making the change out much more simple.
heatman101
Aug 15, 2011 | Intermatic T104M 208-277Volt 40-amp Timer...
I have a hoover windtunnel upright vacuum, It will not shut off and I have to unplug it to do so. If I take apart the upper handle and manually flip the internal switch it works just fine, only when using...
This is a common problem with this machine. The switch has too much resistance to be turned on and off with the switch button and rod. If you put in a new switch, ( # 28161075 ), your problem should be fixed.
Mar 23, 2011 | Vacuums
My computer will not start up, the LED light on the power unit will not come on. It was working fine. I shut it down so that i could connect it to my TV when i plugged it back in...nothing...please help...
Look on the back of your PC. Is there a switch with a I and O on it? Flip it to O and back to I and try to turn your power back on.
If you are plugged into a power strip you may want to try cycling the power on the strip as well.
Feb 28, 2011 | Computers & Internet
Porter Cable 7800 Drywall Sander ran fine, stopped and ate supper, went back to work and motor will not come on. Vacuum is working fine but cannot get motor to turn on when flipping the switch. Did not get...
Sounds like a problem with the ON/OFF switch. Hit it with a bit of contact cleaner or WD40 and work it a dozen or so times, it may just be dirty...... at least if you are lucky.
Paul
Sep 18, 2010 | Black & Decker Black Decker/ Porter Cable...
I have a Rheem gas furnace that shuts off
POssible feed back thru tstat. This sometimes happens. Take a look at tstat disconnect w or white wire that goes to heater. Turn from heat to cool and abck and see if it does it again if not change tstat. You can get a good one at Home depot or Lowes about 20.00 easy to install Keep in touch Rus
Nov 25, 2009 | Heating & Cooling
Burners shut down at set temp but fan continues lowering temp
the reason he told you not to cycle the power is because some where there is a flashing light that he can decode and tell him where to start looking for the problem. Call him next it happens and don't touch the power or the stat until he gets to see the unit.
Aug 03, 2009 | Heating & Cooling
Flip Video Mino keeps freezing up, can't shut down or upload
At least the following works on my first generation Flip Ultra camcorder (not Mino). Remove battery, put it back next morning. After that be careful not to touch "on" slider switch on the side of the camcorder while Flip logo is still on the screen. I mean turn the device on by using the slider switch and do not touch that switch again until Flip logo on the screen is gone. Doing the opposite (trying to use the "on" switch again while device is still "booting" and Flip logo is on the screen) will lead to the Flip Ultra freeze.
Jul 27, 2009 | Pure Digital Flip Video Ultra Camcorder
GE spectra xl44 - Oven not working, broiler & stove-top burners fine
replace the ignitor for the oven. it's the lower one and not the one on top.
Oct 28, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Dewalt DW744S 10" Portable Table Saw with Stand Logo
53 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
