Question about Toshiba Satellite A100-S8111TD Notebook
How to reset the supervisor password using the 3 pins of the cmos battery of toshiba satellite 1801 laptop. the 1st pin have a color of black the the 2nd pin is vacant not connected to the cmos battery and the 3rd one have a color of red.. what should i do.. please help me.. its about a month that i havent open my unit...
  • 185 Answers
Have you tried removing the clock battery on the motherboard, after you do that you just go back in and reset the time and date on Bios and password is gone. I've done it
if it works don't forget to rate me
thx
Posted on Apr 29, 2010
    Champion:
  • 349 Answers
Just remove the battery
I need to reset my CMOS password U305
OPEN YOUR PC CABINATE REMOVE THE CMOS BATTERY OR JUMPER PIN WAIT FOR 30 MINITS AND REINSTAL THE CMOS BATTERY OR JUMPER PIN. START YOUR COMPUTER ENTER INTO BIOS SET UP BY PRESSING F2 OR DELETE AND SET YOUR CMOS PASSWORD WHATEVER YOU WANT
Feb 17, 2011 | Toshiba Satellite U305-S5097 Notebook
How to remove bios password in toshiba satellite A305-s6905 laptop? i tried removing the battery,but it didnt work... it asked me for a JO pin,which i was unable to find.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don’t have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Jul 20, 2010 | Toshiba Computers & Internet
Need help with toshiba dynabook satellite 1801
Toshiba bios password removal process is meant for use on Toshiba laptops that you own or have had permission from the rightful owner to remove the password. If any of these processes are done incorrectly it may result in complete system failure or permanent system damage (you've been warned!).
Some Toshiba bios passwords can be reset using the Key Disk.exe utility, to do this you need a 1.44Mb floppy disk. Format the disk using Windows and then with a hex editor, change the first five bytes of the second sector to 4B 45 59 00 00.
Then put the floppy into your machine and boot it up, you'll be asked for a password, just press Enter. Then when you're asked to set the password, type Y then Enter, this will get you into the bios configuration where you can then type in a new password.
Aside from the KeyDisk, you can build a parallel Loopback plug, this is a simple device that plugs into the parallel port of the machine and removes the password when you boot it up.
To make it you will need a 25 pin DB25 plug, take the plug apart and join these pins using some old cable;
Pins: 1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15, and 18-25
Plug it into your parallel port and boot up your machine, the password should be removed as soon as it boots.
Note: This will work on majority of older Toshiba's (1995 – 2002) and obviously only ones that have a parallel port.
Apr 28, 2010 | Toshiba Satellite A135-S2276 Notebook
I need to remove the bios password for toshiba Satellite A85-S107
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
Oct 18, 2009 | Toshiba Satellite A85-S107 Notebook
How do you reset a Toshiba Satellite L305D Power on Password?
To reset the password on this model, you need to:
  • Power off the computer, flip it over, and open the ram door
  • Find a small jumper to the left of memory module 0 (the one closest to the board).
  • Use a screwdriver to jump this pad while you turn the computer on
  • Continue jumping the pad until after the splash screen dissappears
  • If successfull the password prompt will go away. If not, try try again.
  • When successful, make haste to update your bios: http://cdgenp01.csd.toshiba.com/cont...s/slb8v140.exe Toshiba's have a nasty habit of setting bios passwords on their own. I'm assuming thats why you're here.
Sep 27, 2009 | Toshiba Satellite L305D-S5881 Notebook
How to get toshiba bios password remover toos
ok what you will need to do is reset the bios. just take out the bios battery for a couple ofseconds then putit back in this normaly resets the password Regards Slitwrists
Jun 08, 2009 | Toshiba Portege S100-S1133 Notebook
BIOS PASSWORD REMOVAL on a toshiba satellite L45 S7409
This link describes the bios password reset for various Toshiba models (it's at the top of the results list), hopefully this will help you take care of your problem.
I would also think that Toshiba support would be able to assist you with this should you call them.
Apr 28, 2009 | Computers & Internet
Is there a backdoor bios password for a Toshiba laptop (model #1805-S253)? A previous employee password-protected the bios but "neglected" to tell us what it is.
The Backdoor passwords are not determined by the laptop manufacturer - the backdoor passwords depend on the manufacturer of the bios itself. Is it an Award biosor an AMI bios etc?
Award BIOS backdoor passwords: ALFAROME BIOSTAR KDD ZAAADA ALLy CONCAT Lkwpeter ZBAAACA aLLy CONDO LKWPETER ZJAAADC aLLY Condo PINT 01322222 ALLY d8on pint 589589 aPAf djonet SER 589721 _award HLT SKY_FOX 595595 AWARD_SW J64 SYXZ 598598 AWARD?SW J256 syxz AWARD SW J262 shift + syxz AWARD PW j332 TTPTHA AWKWARD j322 awkward
AMI BIOS Backdoor Passwords: AMI BIOS PASSWORD HEWITT RAND AMI?SW AMI_SW LKWPETER CONDO
Phoenix BIOS Backdoor Passwords: phoenix PHOENIX CMOS BIOS
Misc. Common Passwords ALFAROME BIOSTAR biostar biosstar CMOS cmos LKWPETER lkwpeter setup SETUP Syxz Wodj
Other BIOS Passwords by Manufacturer Manufacturer Password VOBIS & IBM merlin Dell Dell Biostar Biostar Compaq Compaq Enox xo11nE Epox central Freetech Posterie IWill iwill Jetway spooml Packard Bell bell9 QDI QDI Siemens SKY_FOX TMC BIGO Toshiba Toshiba
Toshiba BIOS Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot
Jan 23, 2009 | Toshiba Satellite 1805-S253 Notebook
How to reset BIOS password - Toshiba Satellite 1605 CDS
you dont have to take the battery off, just unplug the cmos connector which looks like a stereo wiring harness.
Nov 14, 2008 | Computers & Internet
Toshiba Satellite A100-S8111TD Notebook Logo
142 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
