Question about Wurlitzer Jukebox CD Player
I have a Rowe Ami cd 100 that we just got.The cd,s skip-music starts and stops, and it seems like the machine is not reading them [sometimes it picks a cd and returns it to rack].Anyone have any ideas-could this have been caused by moving unit[it was briefly laid on it's back to get it in and out of truck]?
    Scholar:
  • 195 Answers
Did you lock down the jukebox mechanism (caurosel) during transportation?
Make sure that all the plugs that go to the all the circuit boards are fully seated, Unplug each in turn and plug back in MAKE SURE YOU UNPLUG THE JUKBOX FIRST if this does not sort out your problem look at the microswitches on the transfer motor (this is the mptor that tranfers the CD onto the deck) the spades on the microswitches are uninsulated so they can short out if pressed together.
The other main problem with Rowe Ami is that the boards are prone to the connection pins having dry joints (cold joints in the USA) on the soldinging to these connection pins.
It may be as well having all the boards tested by a Rowe Ami specialist.
In the USA the best guy is Bruce Wentworth (search for his details on Ebay by putting in Bruce Wentworth jukebox) or you could contact me in the UK.
Regards
Alan Hood
ami-man
UK
Posted on Apr 29, 2010
  • Wurlitzer Expert
  • 567 Answers
If some disc skip then 1 dirty discs,2 defective discs,3mechanism control,4 cd player fault,if all discs skip then 1 dirty lens,2 cd player fault,3 mechanism control
Posted on Jul 05, 2010
I have Rowe AMI 100 CD jukebox. I replaced CDPRO2 Optical Laser-lens and sound still cuts in and out. At times it can't pick up the sound and the cd stops and tries again.
Watch the motor that moves the lens assembly while a CD is playing. It doesn't take much movement to stall the optics so if a gear is slightly binding, that would be enough to cause your problem. Sometimes using a very light machine oil like that is used on a sewing machine on the pivot points will help the gears. A lithium type grease on the rails that the optics moves on may have dried a little, so be sure to check that area too.
May 28, 2016 | Audio Players & Recorders
Rowe Nostalgia jukebox will only play a few of the numbers of the 100 cd;s. Is there anyway to reset it so it will play all numbers?
You will need to go into the programming section on the menu.
I suggest that if you do not have a manual that you obtain one from Rowe Ami, Victory Glass or distribution.
Have you initalised all of the CD's on your jukebox? Every time you replace a CD you have to initalise it.
Regards
Alan Hood
ami-man
UK
Jan 31, 2010 | Wurlitzer Jukebox 1015 One More Time...
WURLITZER OMT CD 100 D picking problem
Hello J.P.,
You need to get the manual for this jukebox.
You have to however confirm what the manufacturer and the model number of this is. The One More Time was made by the following manufacturers:-
Wurlizer, Rowe Ami, Rock Ola, Antique Apperatus and Sound Leisure.
Look for a serial plate on the back of the jukebox in order to get any information.
You can get manuals in the USA from www.victoryglass.com
Regards
Alan Hood
ami-man
UK
Nov 17, 2009 | Wurlitzer Jukebox 1015 One More Time...
How do I slow the speed of the 45s on my rowe r-92 jukebox .The records are playing a little too fast
The turntable motor on the jukebox range of R-84 to R-93 is none adjustable.
If you are in the USA then the motor operates on 60hz but in Europe it would have to be on 50hz to do this a different pulley is used.
The Rowe Ami part numbers are as followes:-
30791907 Turntable Motor Assembly 60hz
30791908 Turntable Motor Assembly 50hz
21817801 Motor Pulley 60hz
21817802 Motor Pulley 50hz
These can be ordered from a Rowe Ami dealer or you could try www.victoryglass.com
Regards
Alan Hood
ami-man
UK
Oct 28, 2009 | Wurlitzer Jukebox 1015 One More Time...
Will jukebox read custom made cds?
Hello donovan_k111,
I should be able to play them since mosy CD jukeboxes play stock CDs anyway.
Thank you,
Shuttle83
Mar 26, 2009 | Wurlitzer Jukebox CD Player
My cd rowe ami jukebox is stuck in scan/transfer mode
You say you do not have the digital display lite up, have you checked all of the breakers on the power supply?
If not do so. Rowe Ami jukeboxes are very prone to dry joints (cold joints in the USA) this is cracking around the soldered pin on the connections to the boards.
If you can solder correctly then check out the printed circuit board on the power supply. I would retest and see if the display now lights after correcting a fault on the power supply.
If that has not made any difference then proceed to the Mechanism Control Board and the Central Control Computer (CCC) and check again for dry joints.
If you can not solder with any confidence then send in your boards to a Rowe Ami specialist for testing/repair.
Regards
Alan Hood
ami-man
UK
Mar 10, 2009 | Wurlitzer Jukebox CD Player
Rowe CD 100 that will not play all Tracks
Are you initalizing the CD's in your jukebox after you install them?
If so it should play all of the tracks.
Regards
Alan Hood
ami-man
UK
Feb 01, 2009 | Wurlitzer Jukebox CD Player
Song Programming
With regards to your problem with the Rowe Ami 100 cd jukebox.
Do you have a manual, if not I suggest you buy a printer manual or one on CD and refer to the Programming and Installation section.
In order for the jukebox to know about the cd's that are installed in the jukebox it has to initialize all or the changed cd's that have been replaced within the jukebox.
Put the jukebox into the Service Mode (the service mode should appear on the display)
Type 3 to select the Initialize sub menu
Type 0 and full initialize will appear on the display
Press Popular to start the initialization
Place the jukebox service switch into the normal mode
Initiazation will take around 30 minutes to complete.
Regards
Alan Hood
ami-man
Jan 05, 2009 | Wurlitzer Jukebox CD Player
Rowe ami jukebox
Check the optical sensor, it may be blocked with dust.
Jun 09, 2008 | Audio Players & Recorders
Rowe jukebox
I take it that the jukebox accepts selections when you type them in. Also that you have tried selecting the A side and the B side records.
Is the switch on the CCC (Central Control Computer) set to Record it should not be set to Video.
Rowe Ami jukeboxes are very pone to dry (cold in the USA) joints.
If you can solder then the following items need to checked for dry joints.
Power Supply PCB (printed circuit board)
CCC
When taking out the plugs pull on the plugs (not the wires)
Look on the soldered side where the connectors pins are fitted for any cracking around the soldered joint ( this is the sign of a dry joint).
Resolder any suspect joints on all of the boards and refit into the jukebox and test.
If this does not cure the problem then the boards will be needed to be sent to a Rowe Ami specalist, I am one of these in the UK.
Regards
Alan Hood
ami-man
UK
May 30, 2008 | Wurlitzer Jukebox 1015 One More Time...
Open Questions:
See all Wurlitzer Jukebox CD Player Questions
Wurlitzer Jukebox CD Player Logo
820 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
phil
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
