Question about Compaq tc4200 Tablet PC
My tc4200 screen just went dark while in use
My tc4200 screen just went dark on me while I was rotating it to access the keyboard...I've verified it's not the GPU as external monitor works fine...I wonder if it's the switch that turns the screen on/off...does the tc4200 have a physical trigger to turn it on/off? I've ordered an inverter as that's my cheapest start...I really hope it's not the motherboard as I've heard another post mentioned...
Cannot open my laptop
The latch is magnetic and if it breaks while closed, it will be stuck closed. To open it, you can slip a business card or something similar between the screen and the keyboard at the corner, just inboard of the rubber bumper and slide it across from left to right (I believe) while exerting a slight upward pressure on the screen and this will open it.
Be sure to replace it as soon as you can to avoid breaking the plastic "Screen Alignment Guide Pins" off. This will happen if the screen is not latched firmly and is allowed to rotate while in the closed position. The guide pins are impossible to get, as they are long discontinued. You would have to replace the entire palm rest to have them back.
Apr 09, 2014 | Compaq tc4200 Tablet PC
Ipad screen not rotating
Hit home button 2 times then slide ur finger copper and click the cerved arrows
May 18, 2013 | Apple iPad (16 GB) WiFi Tablet PC
Pen and touch screen
Please repost this with more information on what your problem is. At this point, we have no idea what your problem is, it just says "Pen and touch screen".
Hope this helps, Nathan Taylor
Jul 23, 2011 | Compaq tc4200 Tablet PC
Hp tablet compaq tc4200.The screen is very dark cannot adjust brightness in control panel.
if you have the quick buttons software installed disable the ambient light :)
Nov 12, 2010 | Compaq tc4200 Tablet PC
M280E (41891001) Tablet PC: the screen is very dark, cannot adjust brightness...
hp tablet compaq tc4200: the screen is very dark. cannot adjust in control panel, it's greyed out,
May 16, 2010 | Gateway M280E
Compaq tc4200, does not have a boot drive, can I attach a USB dev
The TC4200 does boot from a USB device, if you connect the USB device to the system it should detect it right away. You may have to change the boot order/
When you booting and you see the Compaq boot screen press F10 to enter the BIOS
Go into the Advanced Menu, there you will be able to set the boot order.
Apr 15, 2010 | Compaq tc4200 Tablet PC
How do you change the display on the HP tablet TC4200 to show Landscape instead of Portrait?
right click on the screen at the bottom is properties
click that then i think you want settings near the bottom are three buttons the one to the right should be advanced you should be able to change that in there
Nov 30, 2009 | Compaq tc4200 Tablet PC
Hp tablet pc has a blank screen
You're first step should be to plug an external monitor to it to make sure the video card still works. In all likelyhood, the video inverter (located behind the bezel for the screen) went bad and needs to be replaced, but it's good to know whether or not the computer itself is still putting out video
Jan 01, 2009 | Compaq tc4200 Tablet PC
Taskmanager popup
Let's start as simple as possible:
Do you have a loose connection / glitch at the power-connector? Check and solder (link to manual for disassembly is further down in this document)
To me this looks like a stuck key (not necessary one on the keyboard):
create live-usb-ubuntu:
1. download and burn ubuntu 8.10 to cd.
2. boot _any_ computer with it, connect >1GB USB stick.
3. System --> Administration --> Install to live usb
4. Boot from live-usb-stick that you just created
5. open terminal (Applications --> Accessories --> terminal)
6. paste this: sudo apt-get install xev
7. paste this: xev
8. hover with mouse over white box
9. make sure not to press any keys or move the mouse. Now flip the screen or try to recreate a situation in which the task manager would pop up in windows.
10. what's the output in the terminal window? Try to pinpoint exactly how and when the events are generated.
There should be no event generated, when you physically flip the display (which means you don't have to replace the hinge).
Press every single key you can find on the laptop. Verify that each key generates exactly one event.
If you find that there is a series of events generated without any key pressed, try to clean the malfunctioning key. (Service manual for disassembly)
It might possibly be a broken hinge (20USD). Flipping the display and pressing soft keys (Q, rotate, e) does not generate events in xev. Any other button does.
Sep 29, 2008 | Compaq tc4200 Tablet PC
HP tablet PC tc4200 latch fixable?
In a pinch, you can pop the lid open on these by sliding a credit card between the screen and base chassis. Typically when the latch breaks on a tc4200/4400 it will need to be replaced unless it is simply jammed.
Aug 05, 2008 | Compaq tc4200 Tablet PC
Compaq tc4200 Tablet PC Logo
77 people viewed this question
Top Compaq Tablets & eReaders Experts
Jerry Umali
Ann
Level 1 Expert
ray gallant
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
