Question about Sport & Outdoor - Others
My Minn kota bow mount trolling motor turns left & right but the motor won't run. The motor is good and the foot control is good. What is the problem.
  • 1 more comment
  • brentkemptho Apr 29, 2010
    This is a bow mount Minn Kota. The motor is good and the foot control is working I can turn it left & right but there apears to be no power going to the motor.
    It is a PowerDrive 765mx.
  • brentkemptho Apr 30, 2010
    nothing you guys are sending is of any use to me.
  • 324 Answers
If you know the motor and foot controls aren't the issue then I would investigate fuses wiring and connectors.
Posted on Apr 30, 2010
    Genius:
  • 1,040 Answers
Dear Brentkemptho,
Tthis link may solve your problem....
http://www.alltrollingmotors.com/
Posted on Apr 29, 2010
  • 10,515 Answers
For starters, here is a schematic:
http://www.mikesreelrepair.com/schematics/displayimage.php?pos=-4777
Check to see if there is appropriate voltage getting to the switch (with an ohm meter).
You can (please do this carefully) disconnect the battery positive and negative as well as the motor red and motor black wires and connect the Batt positive to the motor red and the Batt negative to the motor black. If the motor runs, the switch is faulty. If it doesn't then I suspect the motor needs looking at.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    My minn kota 70lb thrust motor is 2 years old. Brand new batteries and it will turn left & right, but the prop will not work.????
    Minn kota 74 lbs. prop runs when head turns when rotating motor from centre to right, but stops when you turn motor from centre to left. The light on top stays on.
    Aug 30, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Burning out fuses on trolling motor at battery
    not enough info. I went the the min kota website, they show four maxxum 80's at different voltages.is it a 12v 24v or larger? without a year model I'll have no reference to what wiring schematic Is the fuse connected inline with the trolling motor? what size amp fuse are you burning up? well I can give you some troubleshooting tips. tools to buy (1) amp gauge. if you are unfamilier with amp gauges make sure you get instruction book with gauge or you could burn yourself. Toubleshooting(1) Remove cover off minn kota trolling motor. black cover ontop of unit were the foot control wires go into.turn over foot control remove cover (2) check for corrosion. any exposed terminals should be cleaned.(3) go to your batteries and clean all connections. make sure the batteries are fully charged.(4) take amp gauge and test positive wire for amp draw as you tun on trollling motor and run it through all speeds. if batteries are in the rear away from trolling motor get a 2nd person to control trolling motor. if the trolling motor is more than a 12v system you will have more than one positive lead to test.GOAL. What your trying to find out is how many amps the trolling motor is really pulling. and at what speeds. under a load in the water and out of the water.how many more amps than the fuse raiting? newer trolling motors come with inline breakers not fuses so I'm guessing your using 30 amp fuses. again without more info i can only guess.
    Oct 29, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Can i convert my bow mounted mini kota 40 to a transom mount?
    No you cannot. Due to the hard mounted foot controls, it has to stay a bow mount.
    Oct 18, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    On a Minn Kota All Terrain trolling motor, what should the MOM/OFF/CON switch be set to when using the foot pedal manually?
    You should only use the MOM (or momentary) setting when using the push button the foot pedal. Con will just keep the motor running and your foot control will only allow for direction and speed!
    Jul 06, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    How do you operate the motor? I have no details as to how the motor operates. Its a minn kota trolling motor that mounts on the front of my boat. I need to know how to operate the foot peddle.
    The pedal has generally four functions:
    1) Forward and back on the pedal make the motor go left and right (push forward to turn the motor right, push back to turn it left)
    2) Momentary power - the little 'button' towards the top will engage the motor as long as you press down on it.
    3) Selector Swith - on the side of the foot pedeal there is a switch with the following settings Con - Off - Mom (Continuous - keeps the motor going all the time, Off - well it's off and Mom - will only go when you press the momentary button).
    4) Speed select - the knob on the left controlls how fast the motor goes.
    It takes some getting used to but offers tremendous control and hands free operation!
    Jun 25, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Can you wire a minn kota foot control
    .....I think so ;)
    Here's a schematic, complete with wiring diagram:
    Maxxum 70 Bowmount
    Best of luck!
    Mike
    Jun 04, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Minn Kota power drive trolling motor will not steer to the right **** huard my minnkot will only steer left. I do not have a foot pedal, use the wrist remote control. even goes left when pressing down...
    There is a good chance that he control board is bad. This is a common problem with these units. I have replaced my control board twice.. When the control board goes out, the some function of the unit will not work correctly while other functions work fine. The first time mine went out, the prop motor would not work. The last time the board went out, the unit would only steer right.
    May 29, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Sport & Outdoor - Others Logo
    98 people viewed this question
    Top Sport & Outdoor - Others Experts
    Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
