Question about Panasonic DMR-EZ17 DVD Recorder
The remote control is set to RC2 and is not usable in this mode.
  • 1 more comment
  • npmargie May 01, 2010
    I would like to switch back to the original mode, which is RC1.
  • npmargie May 03, 2010
    Sal,
    It is the original remote that came with the DVR. I was scaninning through the options and moved to RC2, but I did not press enter. When I tried to revert to the main menu, it would not let me do so, I was afraid to press enter when it didn't allow me to go back to the main menu, so I unplugged the unit because I did not want RC2 as my remote option.
    Thanks.
    Marg
  • npmargie May 05, 2010
    Thank you very much - it worked.
  • 4,889 Answers
Ok so you want to revert to another mode so that its usable again? Is this the original remote?
Posted on Apr 29, 2010
  • 1 more comment
  • eagle338
    eagle338 May 02, 2010
    The manual does not list any thing about remote modes. It only lists recording modes. Is that what you mean? If not then please tell me what is the procedure you have followed to select the current mode and I will help you out.
    Sai.
  • eagle338
    eagle338 May 03, 2010
    Thanks for the info. I think I know what you did. In order to make the remote operational again keep the player plugged in and turned on(even though not functional). Press and hold "Enter" and "1" for about 3 - 5 seconds. That should do the trick and remote control should become operational. If that does not work try Enter and 2. One of these must work.
  • eagle338
    eagle338 May 05, 2010
    Glad to hear that. However I would like to know which one of them has worked so that I can guide future customers better.
    Cheers,
    Sai.
Panasonic DMR-EZ28 has RC2 display /l cant see an enter button to try pressing 1 then enter
the unit has been changed to remote control 2 mode. Look in the owner's manual and change the remote to mode 2 and you should be fine.
Feb 20, 2015 | Panasonic Televison & Video
When i push the buttons on the remote it keeps saying set 1
The remote is probably set to another command mode (for example, SET2, DVD2 or RC2 depending on the model unit) or the batteries were replaced recently, so the remote needs to be reset. You can try this: take the batteries out of the remote (as if to replace them), press any button to clear the remote's buffer, then re-insert them. Point the remote at the player, then press and hold 1 and ENTER/OK buttons together for approximately 10 seconds, then release. This should restore the remote's function back to your player. This 'remote reset' must be done whenever the batteries are replaced, otherwise either the remote will not function correctly, or the device will not recognise it.
Very simple, takes a few seconds or so, and costs nothing to try.
Apr 17, 2011 | Panasonic DMP-BD30K Blu-Ray Player
Panasonic DMR-EZ485V. Remote stopped working when
Panasonic website under FAQs. Using code shown on dvd readout,
such as RC2, press 2 & enter or ok, hold for 2 seconds, and machine
will reset connection between remote & dvd recorder. So stupidly simple it works.
Feb 15, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
RC2 keeps appearing on my Panasonc DVD/VHS recorder...What do I do?
Hold down 1 or number after RC (RC1, RC2, or RC3), and enter/ok button on the remote for 6 second while pointing it to the recorder.
Jul 02, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Remote control
re-sync remote by pressing "enter"/"OK" while holding number "1" or "2" or "3" - the proper number should be displaying on unit as RC1, RC2, or RC3
Mar 31, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Universal Remote says ''RC2'' for DMR-EZ27
Question (s): The remote control for my DVD recorder has stopped working. Every time I press a button, the display says "CHK REMOTE 1", "RC1" or "SET1". What is wrong? Answer/Comments: Your DVD recorder remote control can be programmed (with different codes), so it can be used with multiple Panasonic DVD players. When you press a button and the display shows [CHK REMOTE #] or [RC#] or [SET#] it means that the DVD recorder and the remote control are not set to the same code.To set the remote control code to that of the DVD recorder, press and hold [ENTER] as well as the corresponding code number on the display (1, 2 or 3) at the same time for more than 2 seconds.
Mar 14, 2009 | Panasonic DMR-EZ27K
Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Jan 26, 2009 | Panasonic DMR-ES25 DVD Recorder
Panasonic DMRES20 dvd recorder shows RC2 on the display and has no response. My original remote control quit working. Replaced that remote with a universal phillips. that worked fine until I changed the...
Read the manual. Using Panasonic remote hold the enter button down and #1 or #2 for at least 2 seconds until you find the right code combination for the remote and unit.
Sep 02, 2008 | Televison & Video
RC2 problems
That solution works great! Thank you so much...just hold the Enter and 2 down for a couple seconds! Thank You!
Jul 04, 2008 | Panasonic DMR-ES20EG DVD Recorder
DMR--EZ48V
Your DMR is telling you that it is set to listen for RC2 but your remote is transmitting RC1.
Two choices for a fix:
1. Put the remote back into RC2 mode by simply holding both the ENTER and 2 button for at least 5 seconds.
OR
2. Reconfigure the DMR to listen for RC1 by going into the function menus and selecting SETUP. Look for the remote control option. Change it to 1, it will currently display the value 2.
Enjoy.
Mar 19, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EZ17 DVD Recorder Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
