Question about Refrigerators
Samsung frig- french doors- bottom freezer-ice maker produces to much ice, spilling to the bottom of freezer. Latest problem is freexer is all frosty.
  • 4,059 Answers
The ice maker isn't cutting off when the bin is full. If it's the wire bail type,it's not going high enough to lock in the off position or it's not making the switch inside of the ice maker.
If it's the light type the sensor can be dirty (clean it) or it has quit working and needs to be replaced.
There are two possible causes or types of frosting. One is where the surface of the items in the freezer have frost on them. It may be in one spot or evenly distributed. This is caused by excess room air getting into the freezer because of leaky door gasket which should seal snugly on a dollar bill inserted between the gasket. Frequent or prolonged door opening will also allow room air in. The higher moisture content in the air freezes on the surfaces of the food etc.
The other cause and type of frosting is automatic defrost failure.
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Apr 29, 2010
Samsung rf266aepn bottom french door ice maker arm
Simple but a pain. Unplug the refrigerator. Get out your hair dryers and start de-icing the freezer door. Slowly but surly you will get freezer open. Be gentle. Dry EVERYTHING!!! Tracks, rails.....then replace part, plug back in, restock.
Oct 12, 2013 | Samsung RF266AEPN
I have a Liebherr free standing french door frig (two freezer drawers). The plastic component that shapes the ice cubes has fallen out of the ice maker into the ice receptacle below. I don't know how to...
I don't know about this ice maker, but you could always check the Owner's Manual (either the one that came with fridge, or an online copy) for re-attachment info. That's something basic that the manual may very well cover.
Sep 18, 2013 | Liebherr CS2062 Bottom Freezer French Door...
Samsung french door refrigerator ice maker no dispenser defroster leaking water into bottom and produce drawers
If it is a frost free unit the water collects in a well at the compressor , there is a heater element in the well that boils off the water , this is were the fault is.
Jun 04, 2017 | Samsung RF217ACPN - 20 cu. ft. French Door...
Went on vacation and shut water off in house. Came back from vacation and frig. stop making ice. What do I do?
fill tube is probably clogged with ice you will have to melt the ice in the tube that goes thru the back wall to the ice maker, if you shut off the water turn off the im too
Feb 21, 2011 | Samsung RF265AA Bottom Freezer French Door...
Why is my icemaker not working
My Samsung French-door frig had the same problem - try resetting ice maker - red button on the side of the ice maker. If that doesn't work call Samsung service - I had a bad circuit board which needed to be replaced by local Samsung repair service.
Apr 05, 2010 | Samsung RF265AA Bottom Freezer French Door...
The ice maker is not working
There is a way of testing the ice maker.
Diagnostics for ice maker starts on page 27
Apr 01, 2010 | Samsung RF265AA Bottom Freezer French Door...
Ice Maker Not Making Ice
pls check the thermostat
Jul 23, 2009 | Refrigerators
Ice maker spills ice
SEE IF THE CANAL OR HOSE . WHO FILL THE ICE MAKER INSIDE ITS PROPERLY SET. COULD BE NOT PROPERLY ALIGNED OUT OF THE POSITION OR MISSING
YOUR RATING TO MY ANSWER ITS HIGHLY APPRECIATE
Jun 29, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
20 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
