I bought my printer and it does not feed the paper and shows alarm and p03
  • 666 Answers
You most likely need to reinstall the drivers for it can you give us the model and make of the printer please. This will enable us to find the appropriate drivers or troubleshooting guides to help you
Robb
Posted on Apr 29, 2010
Turn on machine & alarm immediately comes on. Flashing check printer 6000.
Are the cartridges in working order. I had similar problem with another make of printer when printer lights kept flashing and one of the cartridges was defective.
Feb 26, 2014 | Canon PIXMA MP170 All-In-One InkJet...
Error code p03
Hi
P03 means Line feed error.
The probable cause is: Timing Disk dirty / damaged.
Solution:
1. Check the timing disk sensor located to the left of the printer
2. Check and clean the board.
Thanks for contacting fixya.com
Please do get back to us for further query.
Jan 05, 2012 | Office Equipment & Supplies
Our alarm and green power lights are blinking and LED is showing E 2 3. Any ideas?
This error E2,3 or Error 6000 from your computer; means that there is a paper feed error. it can be caused by a faulty paper feed motor, or a dirty timing disk film. to solve this problem check the paper load section, look inside is there any foreing body that block the paper feed roller.
Dec 09, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
/*mp250 error code p03 alarm and on light flashing, color ink light on. trying to change cartridge but cartridge head will not go to the center so i can change it. help
manual replacing the print cartridges --> try rotating the left white gear back and forward releasing the mechanical lock of the print head it is a small plastic peace in the back of the of the head ...replace the cartridge as you need ...
about the error p03 it indicates a mechanical jam (head carriage - paper jem - paper pickup mechanizm - head cleaning mechanizm ) also clean carfully all sensors from inside ... it can give you a mechanical jam if blocked
Printer shows E and alarm the computer tells me it is a paper jam,it is not The ink will only transport one way
Try to feed manually (printer is in off) and look for any obstruction for possible paper jam, or check hook type mechanism for paper feed sensor for free to move. Or clean up sensor for possible dust.
Mar 21, 2010 | Canon PIXMA MP210 InkJet Printer
The Printer when turned on shows P & 2 plus alarm light is blinking
The machine is out of paper. / Paper does not feed.
Reload the paper on the Rear Tray correctly and press the Black or Color button.
Dec 03, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Alarm on
the mechnism that raises the paper for feeding may be faulty, call in a technician
Sep 10, 2009 | Panasonic Workio DP-2500E Copier
The printer wont pull paper thru
theres a piece of torn paper stuck in the feed path. i used to be a photocopier tech and that was a very common problem. get out a flashlight and a pair of tweezers...
Jun 18, 2009 | Canon PIXMA MP160 All-In-One Printer
Says that there is a paper jam but no paper is in printer
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 06, 2009 | Canon PIXMA MP180 All-In-One InkJet...
Canon MX300 Paper Jam alarm
Forcing a piece of cardstock as far into the feed as I could, then removing it fixed this problem for me.
Hopefully it will work for you!
Oct 25, 2008 | Canon MX300 Office All-In-One Printer
k24674
jasbo
jasbo
