Question about Casio fx-300ES Calculator
How do you change to radian mode? - Casio fx-300ES Calculator
  • Casio Master
  • 8,064 Answers
Press [SHIFT][MODE] to access (SETUP)
Press 3:deg for degree OR
press 4:Rad for radian.
Posted on May 25, 2010
Ti-nspire cx CAS gives answer in degrees even though it is in radians mode.
When you set some configuration parameter you must scroll down the setup until you reach the OK button. Press the OK button to validate.
Oct 09, 2014 | Texas Instruments TI-Nspire CX CAS...
How to change from degrees to radian mode casio fx-cg10
In Run>Mat screen press SHIFT MODE to enter the setup screen. Scroll down to the line Angle. Press F2:Rad to set angle unit to radian, See Screen capture below.
Jul 06, 2014 | Casio FX-300MS Calculator
When i type in a trig function to graph, the mode is set to radians but the calculator continues to use degrees. How do I make it graph using radians on the x-axis?
The calculator OS (the latest version) has 2 angle settings: Graphing angle and geometry angle.
In Graph mode, Press the menu button, then select Settings, set graphing angle to radians.
Here are some screen captures to help you.
Be sure to validate your changes by pressing OK
Jan 25, 2013 | Texas Instruments TI-Nspire Graphic...
How do I change the mode from Degrees to Radians?
Press the DRG key (top row) to cycle through the three angular modes.
Sep 18, 2012 | Texas Instruments TI-30 XIIS Calculator
Finding radium mode on FX.........OG
You probably mean Radian mode. (the Radium is a radioactive chemical element, with symbol Ra on the Periodic table of the elements).
To set angle unit to radians, Go to the RUN screen.Press SHIFT MODE to enter SetUp. Scroll down to line ANGLE; Highlight the line and press F2 to activate the TAB RAD on the screen. Angle unit will be set to radians, until you decide to change it again.
Oct 01, 2011 | Casio FX-9750GPlus Calculator
Not graphing sin(x)
Make sure you're angular mode is set to radians, not degrees. With the default window range, sin(x) in degrees is virtually indistinguishable from zero.
To change the angular mode, press MODE, down-arrow twice, left/right-arrow to highlight Radian, ENTER to set it, and 2ND [QUIT] to exit.
Sep 24, 2010 | Texas Instruments TI-84 Plus Calculator
Don't know how to change it from degrees to radian mode
if you press the |mode| button (at the top right of the calculator) until you see Deg Rad Gra on the screen (I believe 3 presses of the mode button) and just hit the number below the rad option on the display. This will permanently change it to radian mode until you repeat this step, or clear the memory.
There is also a way to change to radian mode for just one operation if you will be mostly using degrees for example
at the bottom there is a DRG> as a shifted function. I would just recommend changing it in the way I initially outlined as there is less room for error when making calculations.
Apr 22, 2009 | Casio FX-300MS Calculator
Now I can only count in Degrees and radians
Press the MODE button to enter the Mode menu, and change the angular measure to suit.
Mar 25, 2009 | Texas Instruments TI-83 Plus Calculator
Graphing trig functions
Put the calculator in radian mode and it will graph trig functions just fine. If you don't know how to change it to radians, then go to mode and cursor over to select radians. I am assuming you know where the sine, cosine, tangent, etc. keys are.
Dec 31, 2007 | Texas Instruments TI-84 Plus Silver...
RADIANS
MODE > then scroll to Angle... and change to Radian.
Oct 25, 2007 | Texas Instruments TI-30 XIIS Calculator
Casio fx-300ES Calculator Logo
343 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
