Question about Denon AVR2310CI 71 Channels Receiver
Connecting audio from pc to receiver.
How do I get audio from my HP pavillion to my avr-2310ci. I am using my lcd tv as a computer monitor. I am using the old blue pin type connetor for my monitor but don't know if there is a connection on my receiver for audio compatible with my pc. Thanks.
    Brigadier General:
  • 8,546 Answers
What does your sound card have for audio outputs? Mine (M7250N Media Center) has all the expected 7.1 analog audio outputs AND a digital S/PDIF audio output that I run to my receiver's coaxial digital input.
Even if you have just 2-channel audio on your PC the headphone output can be used with an adapter that makes it conenct to a standard RCA audio cable. Run it to any available Linme Level input on the Denon. Get into your sound controls on the PC and make sure your Master Volume is unmuted and adjust whatever else applies to your machine that may affect the audio.
Your monitor is not really a player in this scenario.
Posted on Apr 29, 2010
Just purchased denon avr2310 & i cant get menus on screen
How is it connected to the tv ? Hdmi, svideo, etc? Do you have any other issues?
Aug 09, 2016 | Denon Avr-2310ci Home Theater Receiver...
My HP pavillion elite computer does not display correctly on my panasonic 32 inch lcd tv
TV and computer monitors have slightly different aspect ratios. You need to the configure the PC display settings. Check also if there is a panasonic display driver for your TV.
Sep 07, 2014 | HP pavillion elite m9340f core 2 quad...
Connecting to usb port
depends on the connections on the monitor/tv. you can get conversion cables like hdmi to usb for example.
Jul 24, 2013 | ViewSonic VA1912wb 19" LCD Monitor
Visio e370vl says "not support when iplug in my Denon avr-2310ci
dont use your reciever to switch video inputs to your tv, plug player directly into tv, use coax or optical input from player to reciever for audio
Mar 23, 2013 | Denon Audio Players & Recorders
I have a denon avr-485 surround sound receiver i had got from a friend with no manual and i can not seem to figure out how to connect it to my new t.v. i had purched a 32' jvc lt32p679. Can someone please...
Find the manual at retrevo.com.
As far as connecting the TV goes. Consider that the TV is primarily a visual output device so resist the temptation to use it as a sound INput. The TV always gets its programming from somewhere else unless it uses its own antenna, so grab the audio from the source, not the TV.
You WILL need a Monitor Out feed to the TV so you can see what the receiver is doing during setup. It's in the manual.
I personally recommend against routing all video sources' video through an AVR because they add little in the way of improvement and introduce anomalies along the way. If your TV has enough video inputs I'd attach each one directly to the DVD/BD/Cable/Games, etc and run all audio directly to the AVR.
Jun 22, 2010 | Audio Players & Recorders
I am trying to connect my wii to my denon avr-2802 using the wii's composite cables. i get sound but no picture. help.
After connecting the Wii cables, connect a video cable to the "monitor out" connection to a compatible input on the TV.
Feb 15, 2010 | Denon AVR-2802
PC Sound Card Connection to Denon AVR-2805 or Samsung 40B610
  • Should I be connecting my pc sound card directly to the receiver or to the tv then to my receiver to get the best sound output? To your reciver
  • When I get the HD Digital Tuner, does that make any difference for the pc connection?
  • Try to connect everything that is sound onto your reciver then
  • connect all your video to your your TV for now
  • When you get your digital tuner connect all your inputs for video to(in order >reciever>HD Tuner>TV
  • Basicly everything goes to your tuner first.
Jan 16, 2010 | Denon AVR-2805 Receiver
No video/display on TV when using sony str dh 500
If your set up is HDR-AVR and TV all you need to do is go HDMI out from HDR to HDMI in(Sat.) of AVR and monitor out HDMI (or composite video) to TV. and select the Sat. input on the AVR. The sound is only comming from the HDR in this case and the composite video or HD video is being switched out to the TV when you select Sat. on your AVR
Sep 20, 2009 | Sony STR-DH500 A/V Receiver
Trying to connect HP a6230n pavillion to Sony Bravia HD TV
Using the original remote for the TV open the setup menu and select SVGA connection for IMPUT every time you use the tv as monitor i hope this solve the problem.
Mar 21, 2009 | HP Computers & Internet
Denon AVR2310CI 71 Channels Receiver Logo
187 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
