Low gas pressure
Our central heater and hot water service appears to off overnight - sometimes during the day. In particular we have noticed it happens after we get some rain. The pressure seems very low when we light our gas burners on the stove. They splutter and if you turn the level to low the gas will go out.
What could this be and what should we do? It is every appliance.
Thanks
  • Heating & Co... Master
  • 2,597 Answers
HI get the pressure check at the gas meter transco will do this , go from there first they will advise if they find problems
Posted on Apr 29, 2010
I own a salon and have 2 Rheem 60 gal 50,000BTU Gas hot water heaters. I am still running out of hot water during the work day. My question is because the hot water heaters are on the 3rd floor, it is...
I think before I spend the kind of money to get a tankless added I would get the rheems serviced . two should produce more hot water than 30 people could shower with all day
Feb 21, 2015 | Rheem Water Heaters
Can a pressure relief valve cause hot water to run slowly?
The real question is 'How old is the water heater?'... over time, particularly in areas with hard water, sediment builds up in the water heater. Particularly electric models. typically a TPV (temperature/pressure relief valve) won't cause the symptoms you describe, but mineral deposits around the inlet tube (internal) could, by restricting the flow of water into the water heater.
A TPV is designed to prevent over pressurization which could cause the tank to rupture. I have priced new water heaters as low as $308.00 for a gas powered 40 gallon unit with a 3yr warranty. If you have good soldering (sweat fitting) skills, these are relatively easy to replace yourself. Whether electric or gas, make CERTAIN you shut off the heat source before attempting a replacement.
Dec 20, 2014 | Water Water Heaters
Squeeling sound and lower pressure from gas water heater
Probably the factory-installed heat trap nipples are clogged.
Open following links.
http://waterheatertimer.org/Low-hot-water-pressure.html
http://waterheatertimer.org/Low-hot-water-pressure.html#trap
Noisy whistling and humming and low pressure are common problem with heat trap nipples and inserts from factory.
Replace heat-trap nipples with pex-lined nipples, or remove heat trap inserts with screwdriver or needle nose... careful not to break insert so it falls into tank ... which can then get lodged in hot water line elbow or under-sink shut off.
Factory-installed heat traps are part of overall strategy so manufactures can claim more efficient water heaters, without requiring customers to any thinking.
Other strategies include foam insulation instead of fiberglass (so that wires cannot be replaced on electric units), reducing factory-set temperature from previous 130-135 to 100-120, and re-estimating downward the hot water use for average family.
So some of the strategies are useful, while others problematic or imaginary.
Call manufacturer to pay-for or provide new pex-line nipples. Warranty for fist year covers Labor and parts, and after 1st year, warranty covers parts
http://waterheatertimer.org/Water-heater-manufacturers.html
Save $10 a month in future replacement costs: maintain water heater so it lasts longer:
http://waterheatertimer.org/How-to-maintain-water-heater.html
Apr 25, 2013 | Rheem Tankless water heater for 1-2...
Rheem 22V50F1 pilot won't stay lit. Changed thermo couple & it lit, ran then went out. Let it sit overnight & it lit, ran then went out. What next? p.s. The unit is 5 years old. Thanks
If pilot lights and flame is robust and clear blue, and pilot goes out later, then some suspects can be excluded: air in gas line, low gas pressure, thermocouple is overtightened (finger-tight + 1/4 turn), thermocouple not positioned correctly in the flame, dirty pilot tube.
If flame is yellowish and small: then clean pilot tube and combustion parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Remaining suspects can include: air in gas line, low gas pressure, bad gas control valve, tight house so household vent fans pull air down water heater vent that blows out pilot, hot attic with inadequate ventilation, water dripping down vent.
Open following links to read troubleshoot resources.
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 16, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem RTG-64DVN model, brand new unit installed during the weekend. fired up but shout down automatically within about 5 seconds. showed error code 12.
contact your gas company if the error code is "12," indicating that the gas supply was interrupted.
have a good day !! In LP models, the 12 error code may also appear if the LP gas supply has gotten low. To clear the code, replace or refill the LP gas supply.
go here for a list of codes for rheem tankless water heaters-- www.ehow.com/list_7833182_error-rheem-gas-water-heater.html
May 09, 2011 | Rheem Tankless Hot Water Heater...
The water is luke warm and the pressure is lower than ususal.
We probably need more information to give a good answer.
You report 2 different problems occurring at once: Low pressure and Low temperature.
If this is tankless water heater, then Low pressure and Low temperature might be related, and you probably need a service technician to diagnose and repair cause.
If this is tank-type water heater, look at label on side of tank for type and brand of heater.
Is it gas or electric water heater? Troubleshooting is totally different for each.
Is water pressure pressure low on just the hot side faucet, or is cold side faucet affected too?
Are all hot faucets affected by low pressure?
If you have a dual handle faucet, open hot side only and check if hot water that comes out is hot as normal.
This will say if problem is pressure or temperature.
Tank-type water heater usually won't have both these problems occur at one time, but water heaters work in funny ways sometimes.
Add a comment to this post, or re-post your question with details so the experts can give a solid answer and not guess.
Also you can post water heater questions on pro water heater forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 05, 2011 | Water Heaters
No water coming from hot valve on faucets
Have you thought about possible calcium buildup in your hot water tank/pipes? I am helping a friend in Palm Springs CA (California not Canada) and we are going to pour a really huge pile of vinegar into the hot water tank (let it sit for a day) then open up the hot water taps to the kitchen (where we don't have hot water flowing very well), then going to let everything sit for another day. Remove the aerator from the kitchen faucet after letting the vinegar/water solution sit in the pipes for a day, and turn on the kitchen hot water tap. Once all the **** is drained out, you must of course drain out the vinegar/water solution from your hot water tank or you will smell like French Fries (in Canada we put vinegar on French Fries) when you shower for a few days.
If you don't understand what the basic chemistry of dissolving calcium via this method is all about, then please call a professional plumber. Hope this helps, and remember that Google is your friend (sometimes), but be careful...
Apr 27, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Gas smell during startup of GE hot water heater
yes, provided there is no excessive build up. The gas and air mix must be right before the mixture will ignit. a household stove will do this each time it's turned on. That's why yhe igniter sparkk hits about three times before it lights. proper venting will confine any fumes to the cimbustion chamber to be carried out the exhaust. If the odor is strong then have the appliance checked for safety sake.
May 02, 2009 | General Electric GE SmartWater Household...
The hot water and central heating wont work together
what size of gas line is going into boiler and water heater? is it black iron ? natural gas or propane? have you checked gas pressure at water heater and furnace ? if they work fine individually then you have a problem with incoming gas pressure. Call gas company and ask them if they would come out and check gas pressure.
Feb 03, 2009 | Water Heaters
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
