Question about Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX (silver) Lens
I have a Nikon 18-55mm lens. There is a plastic piece loose.
I have a Nikon 18-55mm lens. There is a plastic round piece loose in inside the lens. Help!!
    Problem Solver:
  • 18 Answers
Throw it away
Posted on Apr 29, 2010
I recently bought a sigma 28-80 3.5-5.6 ii macro for my nikon d5300, the lens will not mount to the camera body. I noticed some plastic pieces had broken off the backs of lens. Have I purchased a defective...
Here are 3 pictures of a Sigma lens for Nikon. Your lens should look about the same. Could be a little less connection points, but notice there is no plastic.
e1f0e696-b90c-4dac-882d-bdba89e8d9e8.jpeg 9e6c062e-9233-4de8-bf2b-75c0e0b3414f.jpeg 9c9661f0-e5a8-4b72-a302-fa4b2c3ce532.jpeg
Feb 16, 2014 | Cameras
I dropped my camera, with lens attached, and although the body works fine, the lens will not focus. Take the lens off the camera, and look into the back of it (the lens), and there is a round, black,...
Wow I appreciate your spirit but this is probably a loosing battle. Even if there was a repair manual you would still need the tools. This is a $150.00 - $200.00 lens. I'd probably elect to buy a new one and sell the broken one on EBAY for parts or try to take it apart just to satisfy my curiosity. Sounds like you like adventure.
Good Luck!
Feb 24, 2011 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Lens is stuck, rattles inside lens
these lenses are made with mostly plastic parts to reduce cost. if the lens was bumped on the front it is common to break the cams that move the lens in and out, unfortunately it is more cost to repair versus replace. there should be nothing "loose" inside the lens
Jan 16, 2011 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
My Nikon D-40 has a Nikkor 18-55mm lens is jammed and inside there is a loose piece of black plastic that extends through the bottom of the lens opening. I can move it around with my finger but it is too...
If you are experienced or brave enough, dismantle the lens from the rear until you can recover the loose piece. You will probably find that the rear cluster of lenses has fallen off the other end of the helical cam tracks on which it travels. This happens because the two steel strips have got bent. They should run exactly parallel to the axis of the tube. Remove the two strips (4 screws) and straighten them carefully. Reassembling this lot is difficult. Engage the lens cluster on its tracks--it will fit 3 ways and only one is correct. The loose piece is a light baffle which engages with the back of the lens cluster and again will fit two wrong ways and one correct. It has a projecting lug which travels down a groove in the tube. When I had reassembled mine it still felt stiff and about to seize again and I am sure that excessive friction causes so much force that the steel strips bend and lead to it all falling to pieces. I greased the moving parts with silicone grease (from a plumbers merchant!) --most other lubricants either harden up or damage the plastic. I managed to break the wires to the auto-manual switch but they were easily resoldered. The lens now zooms smoothly and takes good pictures. But take care--it is easy to create more faults as you go.
Aug 01, 2010 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
My Nikkor 18-55mm lens is jammed and inside there
Hi. I have this same problem. Have you managed to fix it yet? I've been told that it would cost £100 to fix it, plus a charge of £20 to send it away.
Nov 18, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
My nikon coolpix S230 was dropped when the lens was out and now it just says lens error and the lens wont go in.
my nikon coolpix s230 was dropped with the lens out and no it wont go in either. in the inside of the lens a piece of plastic was forced in front of the lens that takes the picture. The warrenty will return and exchange my camera. Good Luck with fixing you camera! Im glad im not the only person this happened to !
Nov 02, 2009 | Nikon COOLPIX S230 Digital Camera
I have the 18-55mm lens that came with my D40 kit and found that it has a loose plastic piece that prevents the lens from it's zoom function. It can be seen through the back of the lens and has a tab of...
Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
Aug 10, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Nikon d90 lens plastic mount broke
I feel for you. exactly the same happened to me but i was looking to upgrade lens so i used it as an excuse.the piece is called a bayonet. what lens is it, is it the kit lens. my lens was unfixable so  am afraid as the mount is plastic the whole lens is a right off, if it was a metal mount it would be worth fixing. sorry
Mar 13, 2009 | Nikon D90 Digital Camera with 18-105mm...
18-55mm lens won't zoom
DON'T TRY TO FIX THIS YOURSELF! You will only add to the damage. If your lens is in warranty, contact Nikon for instructions to get it repaired. If it is out of warranty, I would either pay Nikon for the repair or take it to a camera repair man.
Dec 27, 2008 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX (silver) Lens Logo
493 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
