Question about Brother HL 1440 Laser Printer
Printing troubles The green ready light and the red alarm light are blinking at the same time when I try to print a document from my Word Perfect program. Nothing prints. This only happens in Word Perfect. What can I do to solve this issue. Thanks! Mimi mbl70435@yahoo.com
    New Friend:
  • 159 Answers
Paper jam:
Clear the paper jam. If the printer does not start printing, press the control panel button.
No paper:
Put paper in the printer. Then press the control panel button.
Misfeed:
Put the paper back in properly, and then press the control panel button. The printer will start printing again.
Posted on Mar 25, 2008
My printer is blinking green light in every 5 seconds. i am give test print but is not came to print
Ready and Error Lights (EPL-6200L only)
The Ready (green) and Error (red) lights on the top of the printer may be the first indication of trouble. The status of the lights, on, off or flashing, indicates your printer status, as described below. The Status Alert window in the EPSON Status Monitor 3 utility indicates what type of error has occurred and offers you a possible solution. Look through this section to find the kind of problem you have, then try the recommended solutions in the order they are presented until your problem is solved.
a. Error light (red)
b. Ready light (green)
Status/Error/Warning
INDICATOR LIGHTS
Ready
Error
Service Required (controller error)
OFF
> Service Required (engine error)
> > Service Required (protocol error)
> > Output Paper Jam
> > Paper Jam
> > Paper Out/Feed Jam
> > No Developer Cartridge Installed
> > Wrong Developer Cartridge Installed
> > Installed Developer Cartridge is Not a Genuine EPSON Product
> > Developer Cartridge Memory Error
> > Toner Out
> > Front Cover Open
> > Output Cover Open
> > Printing on Incorrect Paper Size
> > Unsupported Paper Size
> > Time Out Error
> > Insufficient Memory to Print Current Page
> > Paper Size Warning
> OFF
Not All Pages Are Printed
> OFF
Warming Up
> OFF
Replace Photoconductor Unit
> OFF
Toner Low
> OFF
Installed Developer Cartridge is Not a Genuine EPSON Product Warning
> OFF
Sleep mode
> OFF
Ready
> OFF
Printing
> OFF
Processing Data
> OFF
> Note: > If the problem remains after trying the suggestions in this section, contact your dealer or a qualified service representative for assistance.
Control panel: Error light on
A controller error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If all the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready and Error lights flashing
A print engine error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready light flashing, Error light on
A protocol error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Output Paper Jam
Control panel: Ready and Error lights on
Indicates that there may be a paper jam inside the printer. Open the printer's output cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Jam
Indicates that there may be a paper jam inside the printer. Open the printer's front cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Out/Feed Jam
Indicates that there is either no paper loaded in the printer, or there is a paper jam in the feed slot.
If no paper is loaded, load paper into the MP tray, then open and close the printer's front cover. See Loading Paper for instructions on loading paper.
You can clear the error by pressing Continue on the EPSON Status Monitor 3 window that appears.
If paper is loaded, then there is a paper jam in the feed slot. See Clearing Jammed Paper for instructions on clearing paper jams. The error is automatically resolved upon clearing the jammed paper and opening and closing the printer's front cover.
Either the developer cartridge is not installed or is installed incorrectly. Check to see if the developer cartridge is properly installed and follow the instructions under Developer Cartridge to install or reinstall it.
Either the installed developer cartridge is defective, or it is not the right one for your printer model. Replace it with a new or correct developer cartridge by following the instructions under Developer Cartridge.
Control panel: Ready light on, Error light flashing
The installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
To continue using the currently installed developer cartridge, press Continue on the EPSON Status Monitor 3 window that appears to clear the error.
A memory read/write error has occurred. Try reinstalling the developer cartridge or replacing the current cartridge with a new one by following the instructions under Developer Cartridge. If this still does not resolve the problem, turn the power off and then on again.
Toner Out
The developer cartridge is out of toner. Replace the developer cartridge by following the instructions under Developer Cartridge. To clear this error and print a single sheet, press Continue on the EPSON Status Monitor 3 window that appears to clear the error. After that, this error will occur again until the developer cartridge is replaced. If you set the Toner Out Error setting to Off, you can continue printing even when this error occurs.
Front Cover Open
The printer's front cover is open. Make sure that the printer's front cover is closed properly by opening and closing it again.
Output Cover Open
The printer's output cover is open. Make sure that the printer's output cover is closed properly by opening and closing it again.
The paper loaded in the paper source does not match the required paper size. Replace with paper of the correct size and click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
The specified paper size is not supported by this printer, or the paper feed direction is incorrect. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Time Out Error
Data transmission from the computer to the printer is interrupted and a timeout error has occurred. Click Print Again on the EPSON Status Monitor 3 window that appears to resume printing. If printing does not resume, or if you want to change printer driver settings, click Stop.
The printer does not have sufficient memory to print the current page. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Paper Size Warning
The size of the paper that fed through the printer does not match the specified paper size. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
This warning is displayed if an Insufficient Memory to Print Current Page error has occurred while Auto Continue is set to On. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
Warming Up
Indicates that the printer is warming up to process and print data.
Control panel: Ready light flashing (flashes at longer intervals than usual)
Indicates that the photoconductor unit is close to the end of its service life (less that 5%). Prepare a new photoconductor unit to replace the current one. See Photoconductor Unit for instructions.
To temporarily dismiss the warning, click Close on the EPSON Status Monitor 3 window that appears. Resetting the photoconductor unit also clears the warning.
Toner Low
Indicates that the developer cartridge is nearly out of toner. Prepare a new developer cartridge to replace the current one. See Developer Cartridge for instructions.
This is a warning to inform you that the installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
Sleep mode
Indicates that the printer is in energy-saving mode. The printer goes into standby due to inactivity. If the Sleep mode is enabled, the printer goes into standby in 15 minutes.
Ready
Indicates that the printer is ready to print.
Printing
Indicates that the printer is printing data.
Processing Data
Indicates that the printer is processing data.
Mar 18, 2015 | Epson laser Printer EPL-6200L Laser
Cancel print job with a linux operating system
HI,
You've sent a print job to your printer and the green light is blinking, but the printer is not printing. The light blinks for a very long time.
The blinking light indicates that the printer is recieving your print request and will print shortly. If the document you are attempting to print is very large or contains many graphics or images, the printer must spool this data into its memory before printing. This can take quite a bit longer than usual. PDF files are notorious for taking longer than other document types.
In this case, it is best to wait a period of time before taking action. Give the printer 10 minutes and see if it prints.
If it does not print within this window of time, do the following.
1. In the bottom right corner of your screen, you will see a small printer icon. Double click on this icon to open the printer job menu.
2. You will see your print job located there, with other information, including its status.
3. Select the job by right clicking on it and select Cancel.
4. The job should cancel itself.
5. Unplug the printer, removing all power and leave it sit for a couple of minutes.
6. Plug the printer back in and allow it to go through its start up phase until the "Ready" indicator light is solid. This indicates that the printer is ready to recieve jobs.
7. You may now attempt to print again.
Thanks,
HP Printer Support
Jul 16, 2014 | HP Office Equipment & Supplies
On HL 1440 Laser Printer, ready and alarm lights (red) on control panel are lit.
Don't fiddle with it you'll just mess with it more take it in and see what they can do if not i suggest you by a new one.
Nov 28, 2011 | Brother HL 1440 Laser Printer
Samsung ml1640 laser red light blinking
samsung ml1640 laser red and green light blinking continuously and printing not happening
Jul 02, 2010 | Samsung ML-1640 Monochrome Laser Printer
Printer won't print documents. Green light on
Hmmm, try feeding a sheet of paper into the manual feed slot... you might have inadvertantly sent a Manual feed job, and the printer is waiting for a sheet to be fed by you.
Feb 10, 2010 | Dell 1710n Laser Printer
I replaced the toner cartridge, but I am getting a blinking green ready light with a blinking red alarm light. will not print.
This is a paper jam error. Try reloading the paer if you can not find any paper stuck inside the printer. Then press the start button.
Dec 09, 2009 | Brother HL 1440 Laser Printer
Ready light doesn't stay lit, alarm light is red
Because I was getting gray shading on my pages and data was still being printing, I decided to change the toner cartridge. Now the pages are clean and white and all the lights function properly. Most cartridges that are running on empty don't print any data at all or at least print the data at the top of the page and gradually gets fainter sp? on the page. Who would have thought just by changing the cartridge would solve the problem? So glad that's all it was........wasn't excited about having to buy a new printer.
Jul 22, 2009 | Brother HL 1440 Laser Printer
Brother HL 1440 Laser Printer Logo
186 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
